Go to Post You might even learn something! - Tom Bottiglieri [more]
Unread 24-02-2014, 17:31
feverittm's Avatar
feverittm feverittm is offline
FRC #0997 (Spartans)
feverittm will become famous soon enoughfeverittm will become famous soon enough
Easy way to turn off radio on router?
Our area had a Week 0 scrimmage a week ago and had a number of radio issues. Running WiFi in school cafeteria with the other associated WiFi noise and the interference from the other robots on the floor can cause many issues.
Is there a simple way to tell a router to turn off it's radio? This can be done but it requires that you go in via the web interface and change the configuration.
This would go a long way to clean up the radio noise.
Thanks
Floyd Moore
Mentor Electrical and Pneumatics
Team 997 - Spartan Robotics
Corvallis High School, Corvallis Oregon
Unread 24-02-2014, 17:35
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
Re: Easy way to turn off radio on router?
Not really. Maybe you could make a Faraday cage around the AP?
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 24-02-2014, 17:56
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
One way that I have found to reduce the WiFi interference is to run your robot radio under a hidden network. When you run the radio in AP mode for practice, it broadcasts an SSID (your team number) that allows other devices such as smartphones and computers to get information about the network. Hiding the SSID makes it so that you have to know the SSID in order to see and connect to the network.
To set up the hidden network:
  • Go into the radio's wireless settings, and check "Enable Hidden wireless."
  • Follow this tutorial to find and connect to the hidden network.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
