Go to Post You can either suck up a lot of oxygen, or you can contribute to our communal knowledge. The choice is yours. - dlavery [more]
Unread 24-02-2014, 19:00
nickansh1 nickansh1 is offline
FRC #4777
nickansh1 is an unknown quantity at this point
Reloading Launcher
So I know most people are using catapults or some other type of spring loaded launcher, and I was wondering how teams chose to reload their launcher and release the stored up energy quickly. Oddly enough, this seemed to be the toughest challenge for our team this year.
On a related note, many teams are using winch systems or a cam actuated radial release mechanism (the choo-choo) but how do you get the launcher to stay down until you want to launch (other than precariously stopping the motor at the exact moment the launcher is fully retracted)?
Unread 24-02-2014, 19:09
Austin2046's Avatar
Austin2046 Austin2046 is offline
Design, Strategy & Scouting Mentor
FRC #2046 (Bear Metal)
Austin2046 has a spectacular aura aboutAustin2046 has a spectacular aura about
Re: Reloading Launcher
On our catapult we use a winch to pull the arm down into a gate latch held closed by a pneumatic cylinder. When we fire it first disengages the winch using a ball shifter (so the drum can spin freely) then we open the gate latch and it fires.
Unread 24-02-2014, 19:23
zachrobo1's Avatar
zachrobo1 zachrobo1 is offline
AKA: Zach Cloud
FRC #1002 (The CircuitRunners)
zachrobo1 is a glorious beacon of lightzachrobo1 is a glorious beacon of lightzachrobo1 is a glorious beacon of lightzachrobo1 is a glorious beacon of lightzachrobo1 is a glorious beacon of light
We have a spring catapult that is pulled down with Andymark's Shift-to-Neutral Winch (am-2774). The winch has a ratcheting wrench inside of it to prevent it from backdriving, and a dog gear to disengage. To release the dog gear inside, we have a rotating cam on a window motor that provides all the force we would ever need. We were thinking of using the recommended pneumatics, but our robot doesn't have any pneumatics in the design so the cam made more sense.
Unread 24-02-2014, 19:35
mott's Avatar
mott mott is offline
AKA: Mike Ott
FRC #1619 (Up-A-Creek Robotics)
mott is on a distinguished road
One way to accomplish this (especially simple if you are using a 1/2" Hex shaft in your mechanism is to just slip a 1/2" ratcheting box-end wrench on the shaft somewhere. This prevents back-driving. Another option is to use a worm gearbox somewhere in the mix which also tends to prevent back-driving.
Unread 24-02-2014, 19:40
pfreivald's Avatar
AKA: Patrick Freivald
Winch + ratchet + custom dog gear = infinitely adjustable launch mechanism for multiple shots from multiple locations.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 24-02-2014, 20:01
motor -> 50:12 speed reduction -> ratchet -> 40:28 speed reduction -> dog clutch -> winch
Disengage the dog clutch and the winch can spin freely.
Unread 24-02-2014, 20:13
ArzaanK ArzaanK is offline
FRC #1325 (Inverse Paradox)
ArzaanK is an unknown quantity at this point
We have a bolt coming down from our firing mechanism that triggers a limit switch on its way down. The firing mechanism is programmed to stop at when the limit switch is pressed, and then, when a firing button is pressed, the motors engage again, running continuously until the limit switch is engaged again.
Arzaan Khairulla
Programmer/Driver
2013 Greater Toronto Regional East Winners with 1114 and 2056
2013 Galileo Division
Unread 24-02-2014, 20:23
J. Stofflett's Avatar
J. Stofflett J. Stofflett is offline
FRC #0123
J. Stofflett has a spectacular aura aboutJ. Stofflett has a spectacular aura aboutJ. Stofflett has a spectacular aura about
We use a cam cleat like you find on a sailboat.
Unread 24-02-2014, 22:46
xXhunter47Xx's Avatar
xXhunter47Xx xXhunter47Xx is offline
Lord of Lazy
AKA: Austin $wagmaster1337
FRC #4738 (Patribots)
xXhunter47Xx will become famous soon enough
We have a custom dog gear run by two window motors. It rolls down the catapult arm (low pivot with springs). It is actuated by a piston.
We have a button on the remote to roll the window motors, and will continue to roll them indefinitely either until the driver stops pressing it or the limit switch on the bottom is pressed.
Unread 24-02-2014, 23:25
Clever: Team68 uses a pneumatically-actuated automotive brake shoe to hold and release.
Unread 11-03-2014, 08:23
810 Builder's Avatar
810 Builder 810 Builder is offline
FRC #0810
810 Builder is an unknown quantity at this point
We used a ratchet strap and a custom dog gear powered by two CIM motors. Has great power and really gets the catapult down fast.
Unread 11-03-2014, 08:34
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
We are an inline shooter, so we have a tube in a tube, and a "truck" that pushes back the "T-bar" and lock a wedge between to fingers that stick out of the end of the pipe. Here is a video when we was debugging the software before we loaded it all the way with surgical tubing still works pretty good with 4 bands (1 band doubled over on each side), about 90 lbs on a fish scale to pull it back and the lock holds it no problem. Small air cylinder to move the wedge out of the way.
http://www.youtube.com/watch?v=Lbv_auENyTM
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 11-03-2014, 09:33
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
You have other options as well if you are using sailing line for your winch. There are a whole host of rope clutches by different manufacturers that can be actuated pneumatically with little force. That's how we did it in 2010.
Unread 11-03-2014, 11:22
nlj007 nlj007 is offline
FRC #0900
nlj007 has a spectacular aura aboutnlj007 has a spectacular aura about
900 also uses a customized Modulux Gearbox with a shift-to-nuetral. With the forces at play, we had to get creative with shifting the dog gear, but it has worked quite well.
-Team 900 Zebracorns
http://www.youtube.com/user/FIRSTRobotics900
