Go to Post With three robots, I was expecting better scores but I guess more robots means more penalties, not more points. - sanddrag [more]
Unread 25-02-2014, 09:03
O-H
FRC #0048 (Delphi E.L.I.T.E.)
pic: 2014 Team 48 Robot - xtremachen17
Unread 25-02-2014, 09:04
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
Re: pic: 2014 Team 48 Robot - xtremachen17
Looks good, looking forward to being able to see it in person in California
Unread 25-02-2014, 09:51
mathking's Avatar
mathking mathking is offline
Coach/Faculty Advisor
AKA: Greg King
FRC #1014 (Dublin Robotics aka "Bad Robots")
mathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond repute
That is a really nice design Travis. I am glad you are going to Crossroads so I will get to see it in person.
Thank you Bad Robots for giving me the chance to coach this team.
Rookie All-Star Award: 2003 Buckeye
Engineering Inspiration Award: 2004 Pittsburgh, 2014 Crossroads
Chairman's Award: 2005 Pittsburgh, 2009 Buckeye, 2012 Queen City
Team Spirit Award: 2007 Buckeye, 2015 Queen City
Woodie Flowers Award: 2009 Buckeye
Dean's List Finalists: Phil Aufdencamp (2010), Lindsey Fox (2011), Kyle Torrico (2011), Alix Bernier (2013), Deepthi Thumuluri (2015)
Gracious Professionalism Award: 2013 Buckeye
Innovation in Controls Award: 2015 Pittsburgh
Event Finalists: 2012 CORI, 2016 Buckeye
Unread 25-02-2014, 09:54
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
Looking pretty nice....
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
Unread 25-02-2014, 09:55
Racer26 Racer26 is offline
So if I'm understanding correctly:
The cocking mechanism is wound up and released by spinning the motor in the same direction (until it hits the cut-off teeth, where release happens)?
Neat approach. I assume there'd have to be some position feedback on where the launcher is currently cocked to.
Also like the pneumatic claw rotater. How are you getting it to stop in the various positions mid-travel? Some sort of center-off valve? I'm sure you remember 1075's 2007 arm, where we had to do crazy things with multiple valves valving the exhaust because of pneumatics rules at the time.
Unread 25-02-2014, 10:08
O-H
You are correct. The idea originated from a similar mechanism inside a Nerf Stampede ECS fully automatic dart blaster.
Just endpoint sensing. We retract full speed for a pre-set time then retract slowly until the retract prox is made. Re-$@#$@#$@#$@# [<<--- HAHAHAHAHA] time is in the sub 1.5 second range, I think. I'd personally prefer angle position awareness of the pinion at all times, but it seems to work really well as-is.
Center-exhaust valve. When the arm is locked, we kill both tilt cylinder solenoid outputs, connecting both sides of the tilt cylinder to exhaust. Until we get that valve in (today, I believe), we've been using single solenoid valves tied to each air line going to the tilt cylinder to facilitate the same function. Can't wait to tear that hot mess out of the practice bot.
Unread 26-02-2014, 08:05
D_Price's Avatar
D_Price D_Price is offline
Engineer/Mentor
AKA: Derek
FRC #1708 (Amp'd Robotics (formally Natural Selection))
D_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant futureD_Price has a brilliant future
Can't wait to see you guys again in Pittsburgh. Very nice robot as always!
Team member 2004-2008
Team mentor 2008-20XX
http://team1708.steelcityrobotics.or...tics/Home.html
"Education is a powerful tool. Always use it to better someone else's life"
Unread 26-02-2014, 08:45
O-H
Now with intentionally horribly-edited video!
https://www.youtube.com/watch?v=eegVXysXSjA (probably blocked on mobile and PC's in most industrialized nations) - all of the practice field footage in this vid was from our Monday night practice session.
Here's an uncut video of an extended battery-drainer run from the end of Monday's practice - https://www.youtube.com/watch?v=kjrBeGeOCcU
Unread 28-02-2014, 23:30
O-H
Added some new claw features today.
http://youtu.be/VKqFY-zxGjE
