Go to Post Amazing what you can find with a quick video and the unlimited power of the internet! - AveryLevin. [more]
Unread 17-02-2014, 16:12
RamZ's Avatar
RamZ RamZ is offline
Project Manager & Driver
AKA: Ram Zallan
FRC #0004 (Team 4 ELEMENT)
RamZ will become famous soon enoughRamZ will become famous soon enough
Vision Processing
This year, my team wants to use vision processing, specifically using the retroreflective material near the goals to help us aim this year.
Two ways that I've seen this done is using OpenCV, and also with RoboRealm.
Which of these, or any other, vision processing utility would you guys recommend, and why?
We program in Java if it helps.
Also: onboard, offboard, or coprocessor?
Thanks.
Team 4 ELEMENT
team4element.com facebook twitter instagram
Unread 17-02-2014, 16:14
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: Vision Processing
Thanks
There is a sample vision project provided with the Netbeans plugins. We've decided to use that this year. It's mostly set up for you already, just have to tune the color values depending on your LED light ring.
Unread 17-02-2014, 17:48
RamZ's Avatar
AKA: Ram Zallan
Thanks!
Team 4 ELEMENT
Unread 17-02-2014, 18:10
mwtidd's Avatar
mwtidd mwtidd is offline
AKA: mike
FRC #0319 (Big Bad Bob)
If you have the weight for a coprocessor, it may be adventageous to go that route.
I've still got to wire my code into network tables, but that should be easy.
We spent days trying to get the onboard stuff working but as many have warned, it's really tough to do it well on the crio. We went to week zero with onboard code and had no problems seeing hot, anything more than that I would be concerned about.
If you're using robotbuilder / subsystems / commands, I can help you get up and running with some hot camera code. Shoot me an email and I'll invite you to my dropbox (mwtidd@gmail.com).
Here is the current version of my opencv code for java:
import java.awt.image.BufferedImage;
import java.util.ArrayList;
import java.util.List;
import javax.swing.JFrame;
import javax.swing.JSlider;
import org.opencv.core.Core;
import org.opencv.core.Core.MinMaxLocResult;
import org.opencv.core.CvType;
import org.opencv.core.Mat;
import org.opencv.core.MatOfByte;
import org.opencv.core.MatOfPoint;
import org.opencv.core.MatOfPoint2f;
import org.opencv.core.Point;
import org.opencv.core.Rect;
import org.opencv.core.Scalar;
import org.opencv.core.Size;
import org.opencv.highgui.Highgui;
import org.opencv.highgui.VideoCapture;
import org.opencv.imgproc.Imgproc;
public class MatchingDemo {
	public static void main(String[] args) throws InterruptedException {
		System.loadLibrary(Core.NATIVE_LIBRARY_NAME);
		JFrame frame1 = new JFrame("Camera");
	    frame1.setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
	    frame1.setSize(1260,720);
	    frame1.setBounds(0, 0, 1260, 720);
	    Panel panel1 = new Panel();
	    frame1.setContentPane(panel1);
	    frame1.setVisible(true);
	    VideoCapture capture =new VideoCapture(0);
	    capture.set(Highgui.CV_CAP_PROP_FRAME_HEIGHT, 720);
	    capture.set(Highgui.CV_CAP_PROP_FRAME_WIDTH, 1260);
	    Mat src=new Mat();
	    //BGR
	    Scalar rgb_min = new Scalar(0,0,50,0);
	    Scalar rgb_max = new Scalar(250,250,250,0);
		while(true){
			Thread.sleep(10);
			capture.read(src);
			Mat dest = new Mat();
			Core.inRange(src.clone(), rgb_min, rgb_max, dest);
	        Mat erode = Imgproc.getStructuringElement(Imgproc.MORPH_RECT, new Size(3,3));
	        Mat dilate = Imgproc.getStructuringElement(Imgproc.MORPH_RECT, new Size(5,5));
	        Imgproc.erode(dest, dest, erode);
	        Imgproc.dilate(dest, dest, dilate);
	        List<MatOfPoint> contours = new ArrayList<MatOfPoint>();
	        Imgproc.findContours(dest, contours, new Mat(), Imgproc.RETR_LIST, Imgproc.CHAIN_APPROX_SIMPLE);
	        MatOfPoint2f mMOP2f1 = new MatOfPoint2f();
			MatOfPoint2f mMOP2f2 = new MatOfPoint2f();
			List<Rect> filteredTargets = new ArrayList<Rect>();
	        for(MatOfPoint contour : contours){
	        	contour.convertTo(mMOP2f1, CvType.CV_32FC2);
	        	Imgproc.approxPolyDP(mMOP2f1, mMOP2f2, 2, true);
	        	Rect rectangle = Imgproc.boundingRect(contour);
	        	int area = rectangle.width * rectangle.height;
	        	double verticalRatio = rectangle.height / rectangle.width;
	        	double horizontalRatio = rectangle.width / rectangle.height;
	        	if(rectangle.width * rectangle.height > 2500 && (verticalRatio > 2 || horizontalRatio > 2) ){
	        		filteredTargets.add(rectangle);
	        		System.out.println("The target is: " + rectangle.width + " x " + rectangle.height);
	        		Core.rectangle(src, rectangle.tl(), rectangle.br(), new Scalar(0,111,255,0));
	        System.out.println("Targets found: " + filteredTargets.size());
	        panel1.setimagewithMat(src);
			frame1.repaint();
			if(true) continue;
Unread 17-02-2014, 22:55
CreativeName55 CreativeName55 is offline
FRC #2729 (Storm Robotics)
CreativeName55 is an unknown quantity at this point
For our team, we use OpenCV with all detection analysis and such being done off the robot on the driver station, then sent back to the robot via the network table. OpenCV works nicely, however it can be a bit tricky to get the hang of, especially if you're on a small time limit. And doing it on the driver laptop requires a bit beefier of a laptop than some things would, but it makes sure there's no lag on the robot.
Unread 18-02-2014, 19:12
RamZ's Avatar
AKA: Ram Zallan
	    Mat src=new Mat();
	    //BGR
		while(true){
			Thread.sleep(10);
			capture.read(src);
			frame1.repaint();
			if(true) continue;
Thanks a ton! I'll shoot you an email in just a second.
We were looking at OpenCV as well, but when I downloaded it, my computer refused to open it, so I wasn't sure what to do.
Team 4 ELEMENT
Unread 25-02-2014, 14:29
NotInControl NotInControl is offline
Controls Engineer
AKA: Kevin
FRC #2168 (Aluminum Falcons)
NotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond repute
Thanks.
Performing vision on the Dashboard is very successful, and depending on your laptop you can achieve near 30fps processing. DasiyCV from 2012 is probably then best dashboard vision system I have witnessed. The code was released by Team 341. This may be useful for teams to keep in their codebase. When my teams takes on a new coding challenge, I like the system implemented to be robust enough that it becomes apart of our arsenal we can use year after year. Vision process on the dashboard is a very smart way to go.
However, a valid reason to go with a co-processor onboard the robot is if you may end up at an event where FTA's turn off your dashboard/camera to help reduce network issues.
I know many teams had this happen to them last year, and teams relying on vision processing on their dashboard were forced to play handicapped. This would be avoided if you had vision processing on board, and reduced/removed any streams back to the dashboard. However, you need to provide space/weight/power for the onboard processor. If disabled dashboards at your events may be a concern for you, then I recommend a co-processor. This is the method my team employs. We use a beaglebone white on board, and open tcp sockets between the bone and the crio, no data is sent to the driverstation so we don't have to worry about bandwidth limitations or FTAs shutting down cameras. We can achieve 10fps real-time successfully with FFMPEG, OpenCV, and a 320x240 resolution image from the Axis M1011 camera.
A third option floating around on chiefdelphi that some teams are using is a class 1 lasers detector and aiming it at the hot target, they get a true/false reading in the presents of a hot taget after the match starts. No vision camera required. If it works, it would be a very simple, elegant solution.
Hope this helps,
Kevin
Controls Engineer, Team 2168 - The Aluminum Falcons
[2016 Season] - World Championship Controls Award, District Controls Award, 3rd BlueBanner
-World Championship- #45 seed in Quals, World Championship Innovation in Controls Award - Curie
-NE Championship- #26 seed in Quals, winner(195,125,2168)
[2015 Season] - NE Championship Controls Award, 2nd Blue Banner
-NE Championship- #26 seed in Quals, NE Championship Innovation in Controls Award
-MA District Event- #17 seed in Quals, Winner(2168,3718,3146)
[2014 Season] - NE Championship Controls Award & Semi-finalists, District Controls Award, Creativity Award, & Finalists
-NE Championship- #36 seed in Quals, SemiFinalist(228,2168,3525), NE Championship Innovation in Controls Award
-RI District Event- #7 seed in Quals, Finalist(1519,2168,5163), Innovation in Controls Award
-Groton District Event- #9 seed in Quals, QuarterFinalist(2168, 125, 5112), Creativity Award
[2013 Season] - WPI Regional Winner - 1st Blue Banner
Unread 25-02-2014, 16:41
fovea1959's Avatar
fovea1959 fovea1959 is offline
Herder of programmers
AKA: Doug Wegscheid
FRC #3620 (The Average Joes)
fovea1959 will become famous soon enough
Kevin: your coprocessed OpenCV solution: what language?
Unread 25-02-2014, 21:03
faust1706's Avatar
faust1706 faust1706 is offline
FRC #1706 (Ratchet Rockers)
faust1706 is infamous around these partsfaust1706 is infamous around these parts
Am I the only one who is doesn't like how the solution is already given for teams through these demos? I feel like teams that do vision this way don't actually understand what is happening.
"You're a gentleman," they used to say to him. "You shouldn't have gone murdering people with a hatchet; that's no occupation for a gentleman."
Unread 25-02-2014, 22:53
Controls Engineer
AKA: Kevin
C++ on the beaglebone, Java on the CRIO, simple TCP stream between both
Unread 26-02-2014, 11:07
mwtidd's Avatar
AKA: mike
The same could be said about many of the other features in wpilib. Whether it be a field-centric mecanum drive, converting a pwm rangefinder into analog, or creating a pid using robotbuilder.
Remember that many teams may not have access to the same resources (education/mentors) that you have.
I for one find the wpi samples a nice starting point, and certainly not a "solution". The code pretty much works "Out of Box", but getting them working well with your actual code base is not a menial task (especially if you're using robot builder).
Unread 26-02-2014, 11:10
Flywheel Police
We're for the most part using the out of the box vision code. But, we went through all of the code and discussed the process that it is using. We did have to make some changes to get it to work the way we want in our system. And to do that we needed at least a basic understanding of how it works. So I wouldn't say we don't understand what is happening.
Unread 26-02-2014, 14:43
faust1706's Avatar
Thanks for this explaination. I see a lot of teams say "we are using the sample vision code" and then they leave it at that. I'm very pleased to be proved wrong on this, given how I just completely finished vision yesterday and this is my third year doing opencv.
