Go to Post I swear, sometimes it seems like FIRST has got a room full of monkeys writing code. Maybe the monkeys should spend less time flinging fecal matter at each other and more time testing the code before posting it :-). - Kevin Watson [more]
Unread 20-02-2014, 21:34
2185Bilal's Avatar
2185Bilal 2185Bilal is offline
Driver, Ld. Programmer, Electrical
AKA: Bilal Majeed
FRC #2185 (Ramazoidz)
2185Bilal will become famous soon enough
F310 Joystick and Jaguar Problems
So I am having a few difficulties programming the robot in java this year.
so my first problem is that I am using acrade drive on our robot, so the left y axis on the f310 is the forward/backward and the right x axis is the rotation axis. But we have a problem, when I press forward it goes forwards but when we try to turn left it goes right. Any possible reasons, solutions?? thanks
Also another problem we have is the our left jaguars (connect to our motors that control our left side) for some reason flash red, when connected and enabled while the right jaguars are normal. The most confusing part is that the left jaguars still work flawlessly but that red light is for some reason there. Solutions, comments, etc thanks
thanks for the help
RAMAZOIDZ
2009 Toronto West Regional - Regional Winners
2009 Waterloo Regional - Regional Winners
Unread 21-02-2014, 11:01
nickmcski nickmcski is offline
AKA: Nicholas McCurry
FRC #1482 (Grandin Ghosts)
nickmcski has a spectacular aura aboutnickmcski has a spectacular aura aboutnickmcski has a spectacular aura about
Can you post your code on how your getting the joysticks the axis's?
Unread 21-02-2014, 11:04
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
Re: F310 Joystick and Jaguar Problems
thanks for the help
Are they always flashing red? What happens when you try to turn right? Does it turn left? What do you consider "normal" for the lights?
Unread 23-02-2014, 19:07
AlexBrinister AlexBrinister is offline
AKA: Alex Brinister
FRC #1768 (RoboChiefs)
AlexBrinister will become famous soon enough
Are you using closed-loop control? Check the forward and reverse limit switch jumpers on the Jaguars. If those are not properly set up, the Jaguar will flash steady red.
Alex Brinister
Unread 25-02-2014, 23:24
2185Bilal's Avatar
AKA: Bilal Majeed
Alex Brinister
could u expand on that, however i dont think its the actual hardware thats the problem.
We tried inverting our drive system, so the left talons controlled the right side and the right talons the controlled the left side, we noticed it was only on the left jaguars.
so example if the talons are numbered 1,2,3,4 (1,2 = left, 3,4 = right). talon 1,2 would blink red and 3,4 are good. when inverted (1,2 = right, 3,4 = left) 3 and 4 are the ones blinking
so i have feeling that it might be the program, but i dont see anything in the code that might be ticking these red lights
RAMAZOIDZ
Unread 26-02-2014, 12:14
AKA: Alex Brinister
When you enable closed-loop control on the Jaguar, it expects input from a sensor (either an encoder of some kind or an analog sensor of some kind like a potentiometer). Optionally, you can use normally-closed limit switches to act as hard stops for the Jaguar. You can wire these to the Forward and Reverse limit switch ports on the Jaguar. Since the switches need to be normally closed, jumpers need to be placed on the Jaguar so that it reads a closed position. If you don't have jumpers plugged in but are using closed-loop control without limit switches, it will go to blinking red because it detects a limit switch fault condition.
Also, for your first problem with the wrong direction for everything. If you invert your values, it will work. Put a negative in front of your speeds.
Alex Brinister
Unread 26-02-2014, 12:48
dvanvoorst dvanvoorst is offline
FRC #2771 (Code Red)
dvanvoorst is an unknown quantity at this point
You're intermingling motor controller terminology (Jaguars and Talons). It's important to know which you are actually using. I'm guessing you actually have Talons since you mentioned them also.
An uncalibrated Talon can flash red (or green) when it's just sitting there because it's slightly out of calibration. You should go through the calibration process for each Talon and see if that takes care of your issue.
Basically press and hold the calibrate button on the Talon, then run your controller full forward and full reverse a couple of times, then release the calibrate button.
Unread 02-03-2014, 20:35
ProgrammerMatt ProgrammerMatt is offline
Programmer-Electrical-Mechanical
FRC #0228 (Gus)
ProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really niceProgrammerMatt is just really nice
why not just invert your x axis?
drive.arcadeDrive(joystick.gety(),-joystick.getX());
2015-2016 CSA
Software Engineering Student @ Johnson & Wales University
Team 228, Gus Robotics Inc.
Facebook
FLL Mentor for 1107, Edison Eagles!
2015- CT State Champions
2012- WPI Finalist(Thanks 1884 and 549), Spirt, Best Website
2011- WPI Chairman's award winners!
2010- WPI Champions! (thanks 230 & 20), WPI Engineering Inspiration, CT Best Website, CT VEX Champions (VRC228, VRC228b) (21-1-0)
2009- QCC VEX Champions (VRC228) (11-0-0), Innovate Award (VRC228)
