Go to Post Act humble, avoid hubris, and post widely and thou shalt receivith postive rep. ;) - artdutra04 [more]
Unread 25-02-2014, 22:08
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
pic: Cyber Blue 234 - 2014 Robot -
Unread 25-02-2014, 22:10
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
Re: pic: Cyber Blue 234 - 2014 Robot -
Which Augment are you using?
Unread 26-02-2014, 09:03
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
One roller has wheels, one doesn't. Interesting...
Unread 26-02-2014, 09:26
eddie12390's Avatar
AKA: Eddie
FRC #3260 (SHARP)
The side with wheels also seems to be a lot more beefy. The cylinder seems to have a much larger bore and the attachment method for the cylinder is different.
Unread 26-02-2014, 09:32
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Maybe they are using it for catching?
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
Unread 26-02-2014, 09:33
Pat Hart Pat Hart is offline
Pat Hart has much to be proud ofPat Hart has much to be proud ofPat Hart has much to be proud ofPat Hart has much to be proud ofPat Hart has much to be proud ofPat Hart has much to be proud ofPat Hart has much to be proud ofPat Hart has much to be proud ofPat Hart has much to be proud ofPat Hart has much to be proud of
The pick-up is wrapped with tread on both sides.
The pnuematics on the front side are larger because there is surgical tubing mounted on the front pickup to the ball launcher inside the robot. The tubing is not present in this picture, but you can see the eyelets where the tubing is attached.
Unread 26-02-2014, 11:36
Rookie Year: 1942
The rear roller is covered the same as the front, it just wasn't in this photo.
The rear pneumatic is a two stage. Most of the time is is back 2" and acts as a stabilizer for the ball when driving or when ready to launch. IT also extend out fully for ball collection.
The front cylinders are larger to keep the arm in place when we retract the launcher. There is a lot of pull against that arm and the smaller cylinder like on the back was marginal.
The main reason for the mounting differences was to make the geometry work on the back - inside the footprint for start, back 2" for most, and at the right angle for ball collection when both stages are extended.
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
