Go to Post Isn't FIRST robotics the answer to life, the universe, and everything? - weberr [more]
Unread 26-02-2014, 08:54
OwenVanTiem OwenVanTiem is offline
Code Monkey
FRC #0453 (Rock Em Sock Em Robotics)
OwenVanTiem is an unknown quantity at this point
Motors Only Work When Being Calibrated
We have been attempting to test code on our practice bot, but the left side motors only work when we are calibrating. On top of that, the left side motors are inverted when we calibrate the second motor. Right now we are stumped on what the problem could be. We ruled out code because the drive code hasnt been touched since it was written, and it worked fine until recently. We would really appreciate any help that can be provided.
Unread 26-02-2014, 09:15
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Re: Motors Only Work When Being Calibrated
Which motor controller are you using?
Unread 26-02-2014, 09:27
Code Monkey
We are using victors
Unread 26-02-2014, 09:31
Tem1514 Mentor's Avatar
Tem1514 Mentor Tem1514 Mentor is offline
FRC #1514
Tem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to behold
You are holding down the cal button when performing the cal I hope.
Unread 26-02-2014, 09:33
Jon Stratis's Avatar
Electrical/Programming Mentor
FRC #2177 (The Robettes)
I'm going to spell out what I think your setup and observations are, then give you the problem and solution, assuming my understanding of the setup and observations are correct.
Setup: You have two motors going into a single gearbox to power each side of the robot. This would be for a normal "tank" drive robot, for example having 6 wheels on each side all chained together.
Observations:
- One side does not move when the code tells it to
- When calibrating the motor controllers, you see:
1. Calibrating controller "1" makes the wheels spin forward when you want them to go forward in the calibration
2. Calibrating controller "2" makes the wheels spin backwards when you want them to go forward in the calibration - ie it acts opposite of controller "1"
Is all of that correct? If so, then I've got another test for you. Unplug controller "2" and try driving. Does that side work as expected? Now, plug that controller back in and unplug controller "1" and try driving. Does that side work as expected?
I suspect you somehow got the motor leads "swapped" for controller "2". As a result, when you try driving forward on that side, motor "1" sees a +12V signal, while motor 2, with the leads swapped, seeings a -12V signal. The motors run against each other and stall in the gearbox. Unplug the motor leads from controller "2", swap them, and plug them back in.
2016: Lake Superior WFFA
Unread 26-02-2014, 09:58
Code Monkey
Observations:
We tried something similar, we unplugged 2 and tried driving, and it worked perfectly fine. We traced the leads, and they are all plugged in fine and everything is where it should be. For now I fixed the problem by inverting the motor in the code, which seems to make them both travel in the correct direction. We suspect that there is a problem with the victor but we cant be sure.
Unread 26-02-2014, 10:16
Calvin Hartley's Avatar
Calvin Hartley Calvin Hartley is offline
FRC #4967 (That ONE Team)
Calvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud ofCalvin Hartley has much to be proud of
I would just like to say that I accidentally read the title as "Mentors Only Work When Being Calibrated". Needless to say, I was quite intrigued, and then slightly disappointed.
Carry on.
FRC 4967 That ONE Team 2013-Present, Founder, CAD/Everything Mentor
FRC 2771 Code Red Robotics 2012 and 2013 Drive Team, 2014 Drive Coach, Executive Leadership
FLL Team member 2005-2010, LEGO In Paradise,
FLL Mentor 2009-Present Paradise Teams (nine teams)
FLL Coach 2014-Present - The Lightning Bugs
Gracious Professionalism isn't a set of rules to follow, it's an attitude.
Unread 26-02-2014, 11:12
mathking's Avatar
mathking mathking is offline
Coach/Faculty Advisor
AKA: Greg King
FRC #1014 (Dublin Robotics aka "Bad Robots")
mathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond reputemathking has a reputation beyond repute
If it really is a problem with the Victor you really want to replace it. If something has gone wrong inside the speed controller to reverse the motor inputs it is damaged, something else could easily happen. Before you do that you should check the voltage going into and coming out of that Victor in order to make sure it is actually reversed. (In other words, make sure it is actually the Victor and not some other problem in wiring.)
Thank you Bad Robots for giving me the chance to coach this team.
Rookie All-Star Award: 2003 Buckeye
Engineering Inspiration Award: 2004 Pittsburgh, 2014 Crossroads
Chairman's Award: 2005 Pittsburgh, 2009 Buckeye, 2012 Queen City
Team Spirit Award: 2007 Buckeye, 2015 Queen City
Woodie Flowers Award: 2009 Buckeye
Dean's List Finalists: Phil Aufdencamp (2010), Lindsey Fox (2011), Kyle Torrico (2011), Alix Bernier (2013), Deepthi Thumuluri (2015)
Gracious Professionalism Award: 2013 Buckeye
Innovation in Controls Award: 2015 Pittsburgh
Event Finalists: 2012 CORI, 2016 Buckeye
Unread 26-02-2014, 11:15
DanielPlotas DanielPlotas is offline
FRC #1984 (Raider Revolution Robotics)
DanielPlotas will become famous soon enoughDanielPlotas will become famous soon enough
Carry on.
me too, but i was thoroughly confused.
Unread 26-02-2014, 11:18
pntbll1313's Avatar
pntbll1313 pntbll1313 is offline
2052 Coach, Build/Electrical Mentor
AKA: Pete
FRC #2052 (KnightKrawler)
pntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud ofpntbll1313 has much to be proud of
Carry on.
I did the same thing. Maybe the title got changed from when I clicked it? Or maybe we're all just crazy since week 1 is so near (way more likely). In any case... Carry on
2016 (mentor/drive-coach)
Quarter-Finalist-Einstein, Winner-Carson Division Champs, Winner-10K Lakes, Chairman's Award-10K Lakes, Finalists-Lake Superior,
Winner-MSHSL Robotics Competition
2015 (mentor/drive-coach)
Finalists-10K Lakes, Finalists-Lake Superior, Finalist-MSHL Robotics Competition, Quarter-Finalist-Galileo Division Champs
2014 (mentor/drive-coach)
Winner-10K Lakes, Winner-Lake Superior Winner-MSHSL Robotics Competition, Quarter-Finalist-Galileo Division Champs
2013 (mentor/drive-coach)
Winner-10K Lakes, Winner-Lake Superior, Winner-MSHSL Robotics Competition, Quarter-Finalist-Newton Division Champs
2012 (mentor/drive-coach)
Finalists-Lake Superior, Semi-Finalist-MSHSL State Championship, Semi-Finalists at 10,000 Lakes
2008-2011 (college mentor)
2007 (driver)
Quarter Finalist-Milwaukee
Unread 26-02-2014, 11:54
What motors are you using? If it's a motor where your team soldered wires, it's easy to get them backwards.
Unread 26-02-2014, 14:02
I don't think the title was ever changed. After my mistake I realized that I had already seen the thread before, but without the confusion.
I think the fact that we are all crazy is far more probable. I'm glad to know that I am not alone in this.
Unread 26-02-2014, 14:18
NotInControl NotInControl is offline
Controls Engineer
AKA: Kevin
FRC #2168 (Aluminum Falcons)
NotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond reputeNotInControl has a reputation beyond repute
Your Victor may be fine. The direction a motor spins when apply 12V on the + side and ground on the - side is dependant upon how the motor is wound internally.
Not all motors from the same manufacture are wound in the same direction. This could mean two separate motors from the same manufacture can spin in opposite directions when applied voltage in the same orientation.
We have personally notice this on CIM motors. You should make it a habbit to check each motors direction of travel off board and mark them, especially when placing two or more motors in the same gearbox.
It sounds like your problem was just driving both motors into each other causing them to fight. I don't think your victor is broken, but you can check it by unplugging the motor and reading the voltage out of it as you scale the sticks. The voltage should move near linearly from 0 to full battery voltage.
Swapping the boolean value in code, is exactly what you should have done to rectify your situation, so don't think you did a quick fix, it was the correct way.
Hope this helps,
Kevin
Controls Engineer, Team 2168 - The Aluminum Falcons
[2016 Season] - World Championship Controls Award, District Controls Award, 3rd BlueBanner
-World Championship- #45 seed in Quals, World Championship Innovation in Controls Award - Curie
-NE Championship- #26 seed in Quals, winner(195,125,2168)
[2015 Season] - NE Championship Controls Award, 2nd Blue Banner
-NE Championship- #26 seed in Quals, NE Championship Innovation in Controls Award
-MA District Event- #17 seed in Quals, Winner(2168,3718,3146)
[2014 Season] - NE Championship Controls Award & Semi-finalists, District Controls Award, Creativity Award, & Finalists
-NE Championship- #36 seed in Quals, SemiFinalist(228,2168,3525), NE Championship Innovation in Controls Award
-RI District Event- #7 seed in Quals, Finalist(1519,2168,5163), Innovation in Controls Award
-Groton District Event- #9 seed in Quals, QuarterFinalist(2168, 125, 5112), Creativity Award
[2013 Season] - WPI Regional Winner - 1st Blue Banner
