Re: Motors Only Work When Being Calibrated
I would just like to say that I accidentally read the title as "Mentors Only Work When Being Calibrated". Needless to say, I was quite intrigued, and then slightly disappointed.
Carry on. |
If it really is a problem with the Victor you really want to replace it. If something has gone wrong inside the speed controller to reverse the motor inputs it is damaged, something else could easily happen. Before you do that you should check the voltage going into and coming out of that Victor in order to make sure it is actually reversed. (In other words, make sure it is actually the Victor and not some other problem in wiring.)
me too, but i was thoroughly confused.
I did the same thing. Maybe the title got changed from when I clicked it? Or maybe we're all just crazy since week 1 is so near (way more likely). In any case... Carry on
I think the fact that we are all crazy is far more probable. I'm glad to know that I am not alone in this. Last edited by Calvin Hartley : 26-02-2014 at 14:05. |
#7
Not all motors from the same manufacture are wound in the same direction. This could mean two separate motors from the same manufacture can spin in opposite directions when applied voltage in the same orientation. We have personally notice this on CIM motors. You should make it a habbit to check each motors direction of travel off board and mark them, especially when placing two or more motors in the same gearbox. It sounds like your problem was just driving both motors into each other causing them to fight. I don't think your victor is broken, but you can check it by unplugging the motor and reading the voltage out of it as you scale the sticks. The voltage should move near linearly from 0 to full battery voltage. Swapping the boolean value in code, is exactly what you should have done to rectify your situation, so don't think you did a quick fix, it was the correct way. Hope this helps, Kevin |
