My love is autonomous when you enter the room.
Unread 26-02-2014, 00:48
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
pic: Team 696 Teaser #3
Unread 26-02-2014, 00:49
Adamz_'s Avatar
Adamz_ Adamz_ is offline
Who wants coffee?
AKA: Connor Adams
FRC #4519 (Kings Mechavaliers)
Adamz_ is a splendid one to beholdAdamz_ is a splendid one to beholdAdamz_ is a splendid one to beholdAdamz_ is a splendid one to beholdAdamz_ is a splendid one to beholdAdamz_ is a splendid one to beholdAdamz_ is a splendid one to behold
Re: pic: Team 696 Teaser #3
These have to be some of the nicest wheels ive seen in a long time, and id love to see them implemented.
Great work!
2016 North Bay Regional Finalists
2016 Greater Toronto Central Regional Semi-Finalists
2015 Windsor Essex Great Lakes Regional Quarter-Finalists
2014 Windsor Essex Great Lakes Regional Semi-Finalists
2014 Waterloo Regional Quarter-finalists
2013 Waterloo Regional Highest Rookie Seed
2013 Waterloo Regional Rookie All Star Recipient
Unread 26-02-2014, 01:13
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Absoutely stunning. Can you give us some more details on how you held the part, especially for machining the tread grove?
-Plutarch
Unread 26-02-2014, 02:05
Thanks for the complements. I should mention you're looking at the backs (insides) of the wheels. The outside is not as deep, and has corner rounding on the spokes.
Last year, I'm pretty sure we did nearly identical wheels in two operations only on the CNC mill. This year, I forgot exactly what I did last year to finish them off, while having only very little left to hold. So, I did them in two operations in the CNC mill, and left a little bit of the groove unmachined, so I could hold them. Them I finished off the groove in the manual lathe. You can see where the surface finish changes.
In the mill, I held them just in some aluminum softjaws, and went around the outside with a really el cheapo junk HSS woodruff keyway cutter. It took much longer than I'd like due to the HSS cutter, but it worked fine. I'd like a bigger carbide T-slot cutter or something like it to do the tread grooves., but they're $$$.
On the manual lathe, it was actually a pain to finish off the groove, because the wheel is so thin and light that it just resonated and chattered like crazy, leading to horrible surface finish there. But, it's under the tread, so you'll never see it.
Unread 26-02-2014, 07:59
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
They look beautiful.
I would like to know what drives your make buy decision on a part like this?
We switched to just buying wheels a few years ago due to cost and freeing up machines to make other parts, and I'm curious to know other teams rationale for making that type of decision.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 26-02-2014, 10:22
Good question. We evaluated the same question kickoff day. Here's what we came up with.
  • Custom wheels let us do a 7/16" hex, to use 1/2" round bearings. (Primary reason).
  • Over 15 wheels between two robots and spares, we were able to save a significant amount of money (about $350) by making our own.
  • These are significantly lighter than a wheel such as the AndyMark Performance Wheel. With other wheels, our robot would be overweight.
  • The hub on the back of these is set back about 1/8", so the wheel actually encompasses the bearing block. This let's our robot frame be 1/4" wider.
  • Since we had the capability to do this ourselves, we figured we might as well. We want to teach our students to be designers and fabricators, not just catalog consumers.
Unread 26-02-2014, 23:29
S2K JDM's Avatar
S2K JDM S2K JDM is offline
FRC #1378 (Hilo Viking Robotics)
S2K JDM is an unknown quantity at this point
Those wheels are awesome. They kind of look like Volk CE28 rims.
Team 1378 Hilo Viking Robotics| student | 2007-2009
Team 1056 Warrior Pride| Alumni | 2009-2010
Team 1378 Hilo Viking Robotics| Mentor |2011-present
Unread 26-02-2014, 23:35
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
You anodized in house?
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 27-02-2014, 03:14
Chowmaster4695 Chowmaster4695 is offline
Lathe Master
AKA: Jerry Wright
FRC #4695
Team Role: Tactician
Chowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond reputeChowmaster4695 has a reputation beyond repute
we have used this before, and it works great. Many anodizing shops leave parts in too long, which adds extra weight . By anodizing ourselves, we can control the entire process, and saved 1.7lbs last year. Also we have experimented with adding oils in when anodizing our sprockets. this is one of the reason our mecanums are so fast this year.
Unread 27-02-2014, 04:00
OK, we did not Anodize in house. Anodizing and powder coating are the two processes we leave to the pros.
Unread 27-02-2014, 10:30
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Are you thinking of powdercoat? There is no possible way you saw a mass increase through anodize.
2001-2004: Team 100
2006-Present: Team 254
