Go to Post Your opions and statements DO reflect on your team and its' reputation, regardless of what your disclaimer says. - Chris Fultz [more]
Unread 26-02-2014, 11:20
mwtidd's Avatar
mwtidd mwtidd is offline
AKA: mike
FRC #0319 (Big Bad Bob)
Re: Did Vision Tracking Work?
We are using a robot builder based project. So we created a subsystem called HotCamera. We changed the filter from HSV to RGB, look for a width to height particle ratio greater that 3:1, and look for a particle wider than a defined size.
// RobotBuilder Version: 1.0
// This file was generated by RobotBuilder. It contains sections of
// code that are automatically generated and assigned by robotbuilder.
// These sections will be updated in the future when you export to
// Java from RobotBuilder. Do not put any code or make any change in
// the blocks indicating autogenerated code or it will be lost on an
// update. Deleting the comments indicating the section will prevent
// it from being updated in the future.
package org.usfirst.frc319.AerialAssistComp.subsystems;
import edu.wpi.first.wpilibj.camera.AxisCamera;
import edu.wpi.first.wpilibj.camera.AxisCameraException;
import org.usfirst.frc319.AerialAssistComp.RobotMap;
import org.usfirst.frc319.AerialAssistComp.commands.*;
import edu.wpi.first.wpilibj.command.Subsystem;
import edu.wpi.first.wpilibj.image.BinaryImage;
import edu.wpi.first.wpilibj.image.ColorImage;
import edu.wpi.first.wpilibj.image.CriteriaCollection;
import edu.wpi.first.wpilibj.image.NIVision;
import edu.wpi.first.wpilibj.image.NIVisionException;
import edu.wpi.first.wpilibj.image.ParticleAnalysisReport;
public class HotCamera extends Subsystem {
    // BEGIN AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=DECLARATIONS
    // END AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=DECLARATIONS
    // Put methods for controlling this subsystem
    // here. Call these from Commands.
    //Camera constants used for distance calculation
    final int Y_IMAGE_RES = 480;		//X Image resolution in pixels, should be 120, 240 or 480
    final double VIEW_ANGLE = 49;		//Axis M1013
    //final double VIEW_ANGLE = 41.7;		//Axis 206 camera
    //final double VIEW_ANGLE = 37.4;  //Axis M1011 camera
    final double PI = 3.141592653;
    //Score limits used for target identification
    final int  RECTANGULARITY_LIMIT = 40;
    final int ASPECT_RATIO_LIMIT = 55;
    //Score limits used for hot target determination
    final int TAPE_WIDTH_LIMIT = 50;
    final int  VERTICAL_SCORE_LIMIT = 50;
    final int LR_SCORE_LIMIT = 50;
    //Minimum area of particles to be considered
    final int AREA_MINIMUM = 200;
    //Maximum number of particles to process
    final int MAX_PARTICLES = 5;
    AxisCamera camera;          // the axis camera object (connected to the switch)
    CriteriaCollection cc;      // the criteria for doing the particle filter operation
    public void initDefaultCommand() {
        // BEGIN AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=DEFAULT_COMMAND
        setDefaultCommand(new CameraSleep());
    // END AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=DEFAULT_COMMAND
        // Set the default command for a subsystem here.
        //setDefaultCommand(new MySpecialCommand());
    public void initialize() {
        camera = AxisCamera.getInstance();  // get an instance of the camera
        cc = new CriteriaCollection();      // create the criteria for the particle filter
        //cc.addCriteria(NIVision.MeasurementType.IMAQ_MT_AREA, AREA_MINIMUM, 65535, false);
        cc.addCriteria(NIVision.MeasurementType.IMAQ_MT_BOUNDING_RECT_WIDTH, 8, 65535, false);
    public boolean isHot(){
        //initialize();
        camera.freshImage();
        boolean hot = false;
        try {
                 * Do the image capture with the camera and apply the algorithm described above. This
                 * sample will either get images from the camera or from an image file stored in the top
                 * level directory in the flash memory on the cRIO. The file name in this case is "testImage.jpg"
                ColorImage image;                           // next 2 lines read image from flash on cRIO
                image = camera.getImage();
                int redLow = 0;//0
                int redHigh = 10;//100;
                int greenLow = 0;//110
                int greenHigh = 10;//255;
                int blueLow = 50;//235
                int blueHigh = 110;//255
                BinaryImage thresholdImage = image.thresholdRGB(redLow,redHigh,greenLow,greenHigh,blueLow,blueHigh);
                BinaryImage filteredImage = thresholdImage.particleFilter(cc);
                System.out.println("particle count: " + filteredImage.getNumberParticles());
                if(filteredImage.getNumberParticles() > 0)
                    int targetWidth = 0;
                    for (int i = 0; i < MAX_PARTICLES && i < filteredImage.getNumberParticles(); i++) {
			ParticleAnalysisReport report = filteredImage.getParticleAnalysisReport(i);
                        double widthRatio = report.boundingRectWidth / report.boundingRectHeight;
                        if(widthRatio > 3 && widthRatio < 12){
                            targetWidth = report.boundingRectWidth;
                        System.out.println("particle height: " + report.boundingRectHeight);
                        System.out.println("particle width: " + report.boundingRectWidth);
                        System.out.println("particle size: " + report.particleArea);
                    int minWidth = 30;
                    hot = targetWidth > minWidth;
                 * all images in Java must be freed after they are used since they are allocated out
                 * of C data structures. Not calling free() will cause the memory to accumulate over
                 * each pass of this loop.
                filteredImage.free();
                thresholdImage.free();
                image.free();
                return hot;
            } catch (NIVisionException ex) {
                System.out.println(ex.getMessage());
                ex.printStackTrace();
            catch (AxisCameraException ex) {
        return false;
We then created a WaitForHot command. Also we only call the isHot function once every 10 loops and this helps to avoid any Robot Drive Not Updated Enough issues.
package org.usfirst.frc319.AerialAssistComp.commands;
import edu.wpi.first.wpilibj.command.Command;
import org.usfirst.frc319.AerialAssistComp.Robot;
 * @success cameraDrive
 * @fail stopDrive
public class  WaitForHot extends ConditionalCommand {
    public static final String name = "WAIT_FOR_HOT";
    private static final int MIN_POSITIVE_SAMPLES = 2;
    private long startTime = 0;
    public WaitForHot() {
        super(name,CameraDrive.name,StopDrive.name);
            // Use requires() here to declare subsystem dependencies
        // eg. requires(chassis);
        // BEGIN AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=REQUIRES
        requires(Robot.hotCamera);
    // END AUTOGENERATED CODE, SOURCE=ROBOTBUILDER ID=REQUIRES
    // Called just before this Command runs the first time
    protected void initialize() {
        startTime = System.currentTimeMillis();
    // Called repeatedly when this Command is scheduled to run
    private int hotCounter = 0;
    private int loopCounter = 0;
    protected void execute() {
        //for the first half second, wait for the targets to flip
        if(System.currentTimeMillis()- startTime < 500){
            return;
//      //only run vision code once every 10 iterations
        loopCounter++;
        if(loopCounter > 10){
            //if camera sees hot, increment the hot camera
            if(Robot.hotCamera.isHot()){
                hotCounter++;
            loopCounter = 0;
    // Make this return true when this Command no longer needs to run execute()
    protected boolean isFinished() {
        //if the camera has seen hot for 3 iterations finish
        if(System.currentTimeMillis()- startTime > 5000){
            return true;
        return hotCounter > MIN_POSITIVE_SAMPLES;
    // Called once after isFinished returns true
    protected void end() {
    // Called when another command which requires one or more of the same
    // subsystems is scheduled to run
    protected void interrupted() {
We are also using a blue LED ring light and the exposure is turned way down on the camera.
You can see it working here: http://www.youtube.com/watch?v=AUCYI...ature=youtu.be
