Go to Post How many robotics kids does it take to turn on a light? - demosthenes2k8 [more]
Unread 26-02-2014, 09:31
Canon reeves Canon reeves is offline
FRC #4490
Canon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud of
Drivers Stopping Scoring
So upon further reviewing the game, I began to question would it be possible for one of the drivers to hit the opponent’s ball back onto the field when it is shot in the high goal or low goal. I know this sounds absurd but look at these rules. The only thing I found was talking about human player not touching the opponent’s ball and coaches not being allowed to touch the balls, but there are two drivers? So could one of the drivers hit the ball back out because and according to section 3.1.4,
A BALL is considered SCORED in an ALLIANCE’S GOAL if
A. a ROBOT causes one (1) of their ALLIANCE’S BALLS to cross completely and remain completely through the opening(s) of one (1) of their ALLIANCE’S GOALS without intervening TEAM member contact,
B. the ALLIANCE ROBOT last in contact with the BALL was entirely between the TRUSS and their ALLIANCE’S HIGH GOALS, and
C. the BALL is not in contact with any ROBOT from that ALLIANCE.
So the only rule that might cause a violation is G12, I’m not sure if this means your alliance’s robots or anyone on the alliance.
G12
An ALLIANCE may not POSSESS their opponent’s BALLS. The following criteria define POSSESSION :
A. “carrying” (moving while supporting BALLS in or on the ROBOT or holding the BALL in or on the ROBOT),
B. “herding” (repeated pushing or bumping),
C. “launching” (impelling BALLS to a desired location or direction via a MECHANISM in motion relative to the ROBOT), or
D. “trapping” (overt isolation or holding one or more BALLS against a FIELD element or ROBOT in an attempt to shield them).
Violation: TECHNICAL FOUL per instance. If extended, another TECHNICAL FOUL. If strategic, RED CARD for the ALLIANCE.
Examples of BALL interaction that are not POSSESSION are
A. “bulldozing” (inadvertently coming in contact with BALLS that happen to be in the path of the ROBOT as it moves about the FIELD) and
B. “deflecting” (a single hit to or being hit by a BALL that bounces or rolls off the ROBOT or a BALL slips through the grips of a ROBOT without arresting the BALL'S momentum).
A BALL that becomes unintentionally lodged on a ROBOT will be considered POSSESSED by the ROBOT. It is important to design your ROBOT so that it is impossible to inadvertently or intentionally POSSESS an opponent’s BALL.
G32
Strategies employing HUMAN PLAYER actions to deflect opponents’ BALLS are not allowed.
G34
COACHES may not touch BALLS. Inadvertent or inconsequential contact will not be penalized.
Violation: FOUL
G39
During the MATCH, TEAMS must remain in contact with the area of the FIELD (ALLIANCE STATION or HUMAN PLAYER AREA) in which they started the MATCH. Exceptions will be granted for inadvertent, momentary, and inconsequential infractions and in cases concerning safety.
Violation: FOUL
G41
TEAMS may not contact any ROBOT or any BALL in contact with a ROBOT at any time during the MATCH.
Please don’t judge, I’m probably missing something huge here, I’m not sure so I would love it if someone directed me towards the rule prohibiting this. Thanks!
Unread 26-02-2014, 09:39
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: Drivers Stopping Scoring
I looked through the manual, and it seems that you're correct, according to the rules as they are written, only the Human Player and/or Coach is specifically prohibited from touching an opponents ball. I couldn't find any specific mention of a 'driver' touching an opponents ball either.
That being said, I'm willing to bet that if you bring this up in Q&A, or try it as an event (specifically a driver reaching up to block a shot), it'll be ruled as being illegal, or not within the 'spirit of the rules' and a team update will follow.
-Dustin Benedict
Unread 26-02-2014, 09:43
Tem1514 Mentor's Avatar
Tem1514 Mentor Tem1514 Mentor is offline
FRC #1514
Tem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to beholdTem1514 Mentor is a splendid one to behold
Originally Posted by Canon reeves View Post
G32
G34
Violation: FOUL
G39
Violation: FOUL
G41
You already have the answer in the rules that you can not contact an opponents ball (G32). However G34 allows you inconsequential contact, no effect on outcome and really for safety reasons to stop a ball from droping on a drivers head (ouch).
Unread 26-02-2014, 09:45
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
G32 only covers the HUMAN PLAYER. The DRIVER is not considered a human player if I remember correctly. The wording of the rules affecting it just seems a little ambiguous and I'm sure that the moment that someone tries it or asks about it the wording will be changed.
Unread 26-02-2014, 09:54
FRC #1514
Please, then go ask the official source at the Q&A.
For me and our team we would not even consider trying to have a driver/coach/human player stop a score unless it was done with the robot
Unread 26-02-2014, 09:56
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
I would think these actions would be "un-civil" and thus illegal per [G13]. I would consider "civil" to mean "courteous and polite" and I would consider using drivers to block or un-score BALLS to be neither courteous nor polite.
G13
All Teams must be civil towards other Teams, competition personnel, and event attendees.
Violation: Potential RED CARD for violations in the ARENA.
Unread 26-02-2014, 10:02
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Not necessarily. Following that train of thought defense would be illegal as blocking/pushing someones robot around would be considered uncivil.
I think the GDC wrote these rules and assumed the HP and Coach would be the only two people with hands available to do something and overlooked the possibility of drivers contacting balls.
I expect a team update to come out.
1058 PVC Pirates 2016 - xxxx
Unread 26-02-2014, 10:06
FRC #4490
I think I'm going to Q and A this, while yes I can't find anything substantial prohibiting it I do believe it is not in the spirit of the law rather than the letter of the law. Bummer that it will be ruled illegal more than likely, it would be a pretty funny thing to watch in the elimination matches!
Unread 26-02-2014, 10:07
FRC #4490
I agree, it was just something I found interesting because I have no life now that build season is over!
Unread 26-02-2014, 10:17
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
I think you're getting a little too lawyer-y on this. One is expected and has decades of precedent in FIRST, as well as being specifically mentioned in the manual:
FRC is a full-contact ROBOT competition and may include rigorous game play. While Game and ROBOT Rules limit severe damage to ROBOTS, Teams should design their ROBOTS to be robust.
and the other is a cheap way of trying to de-score an opponents ball in a manor very much against the principles of FRC and GP.
Unread 26-02-2014, 10:25
FRC #4490
Alright, I posted a question on Q and A
Unread 26-02-2014, 10:28
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
As the rules are written right now, the OP's strategy is legitimate and legal.
It also used to be legal to leave parts of the robot behind - "capping goals" was a popular strategy before rules specifically disallowed it - as were wedge robots.
Let's not castigate this fellow for suggesting a valid strategy. He put it out here in the open forum, open for discussion, and he did not say he intends for his team to use this strategy.
I say kudos to Canon for thinking outside the 54x25 box.
Hi!
Unread 26-02-2014, 10:32
I take the use of "Team Member" in A to mean a member of any team.
Unread 26-02-2014, 11:57
Have you tried this? It's fairly difficult when the ball has a lot of momentum. You'd have to dedicate a driver to doing this, and risk interfering with the drivers.
Unread 26-02-2014, 12:14
FRC #4490
If someone were to execute this strategy I can't see it interfering with the other drivers. Because of the roof the un-scorer would never have to be right on the drives, and the whole driver station technically goes back 10 feet. I think the grey area here would be how long would remaining in the goal completely be? Because the ball eventually would be returned to game play? would it be when the field staff gets the ball?
So basically unless you didn't require an operator, you could do it, but the person would have to be strong enough to hit it back out, and line up with the opposing robot before it shoots? I wouldn't be ok with it if my team did it, but that's just me. It will definitely be deemed illegal in the next update.
