Go to Post (Funding will be plentiful...) Where is this magical land? We can move our team there! - Tungrus [more]
Unread 26-02-2014, 12:55
ashb1025 ashb1025 is offline
FTC #6095
ashb1025 is an unknown quantity at this point
FTC Block Party IR-Sensor
Hi, I am the main programmer for 6095, we are having some trouble with using if statements on our IR autonomous program. I am familiar with RobotC but am having some trouble. Some help would be greatly appreciated.
Unread 26-02-2014, 15:53
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Re: FTC Block Party IR-Sensor
Can you post your code in its current state? Or at the least, give us a better idea of what you're trying to do and where you're having problems.
FRC 766, 2015-, Mentor
Unread 27-02-2014, 12:45
FTC #6095
This is the code, the idea of it is to work like a check list for each of the buckets, say you have buckets 1-4 it'll check bucket 1 for a infrared signal if it doesn't get one it moves on to bucket 2, if it does then it dumps the block in the bucket and moves to the closest ramp.AutonomousIR.c, I apologize I don't know how to get the code to display in the post
Unread 27-02-2014, 13:09
RyanCahoon's Avatar
It looks like you're pretty close; you just need to repeat the check for each of the buckets. You can either copy-and-paste the code as many times as you need (probably 4 in this case), but a more maintainable way would be to use a loop.
for(int i = 0; i < 4; i++)
    // put code for a single basket here
--Ryan
P.S. You can use tags to inline code in your post. Look for the button with the # symbol in the post editor
Unread 27-02-2014, 13:14
FTC #6095
Thank you, and 1 more question, would you happen to know how to read the returning values from the sensor and then how to use those values for a 2 conditional if statement? For example if the first conditional returns true and the second conditional returns > 100 then run the if statement
Unread 27-02-2014, 13:35
FTC #6095
I was thinking it would be something like this but I don't know for sure
task main()
    if (conditional1(sensor)==2)
       if(conditional2(sensor) > 100)
           //run bucket commands
       else
          //move on to next bucket
Unread 27-02-2014, 13:49
RyanCahoon's Avatar
That would definitely work, and there's no problem with that, but you would need to have two identical else {} blocks (one on each of the two if statements) so that the "move on to next bucket" code would be run if either of the conditions was false.
An easier way to do this is to use the "and" operator to combine both if statements. In ROBOTC, you write this as &&
task main()
   if (conditional1(sensor)==2 && conditional2(sensor) > 100)
   else
Unread 27-02-2014, 13:51
FTC #6095
Thank you very much
