Go to Post Needless to say, lots of smoke came out, and I debated using its terrible smell as a deterrent. - Snapshot [more]
Unread 26-02-2014, 16:15
DjScribbles DjScribbles is offline
Programming Mentor
AKA: Joe S
FRC #2474 (Team Excel)
DjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to behold
Re: Impressions: Command Based Robot
As an example of what I mean by business logic, here is the bulk of code from our collector:
We need to know the state of the collector when we control our arm (the two can collide while the collector is up). So having the collector subsystem know it's state seems like the appropriate way to manage this.
void Collector::MoveCollector(bool extend)
	if (extend == true)
		if (collectorLifter->Get() != DoubleSolenoid::kForward)
			timeTravel.Reset();
			timeTravel.Start();
		collectorLifter->Set(DoubleSolenoid::kForward);
	else
		if (collectorLifter->Get() != DoubleSolenoid::kReverse)
			timeTravel.Reset();
			timeTravel.Start();
		collectorLifter->Set(DoubleSolenoid::kReverse);
Collector::CollectorState Collector::GetState()
	if ((timeTravel.Get() >= TIME_TRAVELING_UP) && (collectorLifter->Get() == DoubleSolenoid::kReverse))
		return UP;
	if ((timeTravel.Get() < TIME_TRAVELING_UP) && (collectorLifter->Get() == DoubleSolenoid::kReverse))
		return TRAVELING_UP;
	if ((timeTravel.Get() >= TIME_TRAVELING_DOWN) && (collectorLifter->Get() == DoubleSolenoid::kForward))
		return DOWN;
	if ((timeTravel.Get() < TIME_TRAVELING_DOWN) && (collectorLifter->Get() == DoubleSolenoid::kForward))
		return TRAVELING_DOWN;
	return IDLE;
It doesn't seem appropriate to tuck the state into a command somewhere. I could see setting the currentState on the End of command though; however the logic of how long it takes to actuate still seems more appropriate in the subsystem, because it is an attribute of that subsystem, not of the command that triggered the action.
