Go to Post remember FIRST is just an extracuricular activity in which most of the work is technichan's work...what gets you into college are good grades and a good course load...as my mom always said, "getting good grades gives you the freedom to chose to be whatever you want and go wherever you want" - abeD [more]
Unread 02-26-2014, 07:10 PM
Joey1939's Avatar
Joey1939 Joey1939 is offline
AKA: Joey Holliday
FRC #1939 (Kuhnigits)
Joey1939 has a spectacular aura aboutJoey1939 has a spectacular aura aboutJoey1939 has a spectacular aura about
Re: Creating a folder on the cRIO
Maybe, instead of calling .delete() and .create() on the same object, try making a new instance of the FileConnection with the same file path to call .create() after you called .delete() on the first FileConnection. (Don't forget to close the first file connection before you make a new one; FileConnection.close()).
I don't know exactly how the delete() method works, but it may make the create() method then unusable.
