Go to Post The obvious solution is to only allow the real world to have negative jade induction coefficients. - EricVanWyk [more]
Unread 26-02-2014, 20:47
Thatnerdygiant's Avatar
Thatnerdygiant Thatnerdygiant is offline
AKA: Edward Holicky
FRC #1806 (S.W.A.T)
Team Role: Driver
Thatnerdygiant is an unknown quantity at this point
FTC Storage
Hey, Im with an FTC team and we have multiple autonomous that we would like to put on our NXT Brick, but we do not have the room for multiple autonomous on it. How can we do this? Thank you
Unread 26-02-2014, 21:30
ehochstein's Avatar
ehochstein ehochstein is offline
Coach, Volunteer & Mentor
AKA: Evan Hochstein
FTC #5943 (ESGM)
ehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant futureehochstein has a brilliant future
Re: FTC Storage
If you have a second NXT, you can name the first XXXXA and the second XXXXB (where XXXX is your team number).
Minnesota FIRST Senior Mentor | 2013-?
Stratasys Applications Engineering Technician | 2016-?
2009 Regional Win – 2470 @ 10k Lakes (Thanks 2826 and 1714)
2013 WFFA Recipient – 2470 @ 10K Lakes
2016 Ri3D: 'Snow Problem Reveal
2017 Ri3D: 'Snow Problem Reveal
The opinions expressed above are the personal opinions of the author and do not necessarily represent the views and opinions of any organization the author is affiliated with.
Unread 26-02-2014, 21:39
DRH2o's Avatar
DRH2o DRH2o is offline
AKA: Dan Waters
FRC #1598 (Team Talon)
DRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of lightDRH2o is a glorious beacon of light
Re: FTC Storage
What we do is download the program -- it becomes a file on the nxt that you can pull off through NXT Terminal -- save those small files to a folder and it is very quick to upload those through Terminal without the need to compile and download. We also keep a copy of teleop, chooser and samostat to put back on if there is a problem.
Unread 26-02-2014, 21:53
orangemoore orangemoore is offline
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
Re: FTC Storage
First you may want to defragment your NXT Memory it should be one of the options on the NXT Terminal.
Second you may want to attempt to program a single program and select which one your want to use before you enable.
If you are using labview I would be happy to send over our code from this year.
Hope This Helps!
Side Note: In the future you may want to put FTC Related Threads in the FTC Thread.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
