Go to Post No one can improve your team's situation but your team. - Ryan Dognaux [more]
  #31   Spotlight this post!
Unread 26-02-2014, 22:24
IVAN IVAN is offline
FRC #2429
IVAN is on a distinguished road
Re: Is your robot defense ready?
I expect to see alot of hit and run D
  #32   Spotlight this post!
Unread 26-02-2014, 22:37
Wayne TenBrink's Avatar
Wayne TenBrink Wayne TenBrink is offline
<< (2008 Game Piece)
FRC #1918 (NC Gears)
Wayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond reputeWayne TenBrink has a reputation beyond repute
With all the overhanging appendages and high speeds, I hope the referees strictly enforce the "contact inside the bumper zone" rule. Breaking your own bot when you run into somebody is one thing. Trashing the innards of the bot you hit is quite another.
NC Gears (Newaygo County Geeks Engineering Awesome Robotic Solutions)
FRC 1918 (Competing at St. Joseph and West MI in 2017)
FTC 6043 & 7911
  #33   Spotlight this post!
Unread 26-02-2014, 22:50
mwmac's Avatar
mwmac mwmac is offline
JWBWIFWWWADD
AKA: Mike MacLean
FRC #2122 (Team Tators)
mwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond reputemwmac has a reputation beyond repute
Originally Posted by Bob Steele View Post
I thought there would be only one human player in the alliance station. Two are stationed up by the truss in those positions. I also note that human players cannot pass the ball between each other from station to station. Now... that was assuming human players were dispersed on the field and not all behind the alliance area.
Anyone else want to chime in on this? Can an alliance use all of its alliance human players in the drive station area? Would you want to?
G8
Each TEAM member must be in designated areas:
COACHES and DRIVERS must be in the ALLIANCE STATION and behind the STARTING LINE.
HUMAN PLAYERS must be either in one of their HUMAN PLAYER AREAS or in the ALLIANCE STATION and behind the STARTING LINE.
G38
HUMAN PLAYERS may not pass the BALL to a HUMAN PLAYER in another HUMAN PLAYER AREA (passing the BALL within an ALLIANCE STATION or HUMAN PLAYER AREA is permitted).
IMO, an alliance that chooses to leave one human player area empty is taking a large risk especially if one of their balls leaves the field on that side as it would introduce a longer delay in the ball being returned to the nearest human player.
2016 Carson W 2122, 2052, 3538, 41, AZ North W 2122, 125, 498, MQA, Idaho F 2122, 3250, 3513, MQA, CCC W 2122, 9122, 6174, ICA
2015 Tesla SF IDA 2122, 3360, 2960, 1311 IRI SF 2338, 2122, 107, 234 UT F 2122, 3230, 3405, EEA, WFFA, AZ West W 2122, 3309, 5059, ICA
2014 Galileo QF 1717, 2122, 3683, 193 UT W 2122, 2996, 3191, ICA, CCC W 1678, 2122, 9073, ICA
2013 CalGames W 2122, 1678, 4171, Judges Award
2012 Newton QF 2122, 610, 488 Spokane W 2122, 1983, 4082, EEA
2011 Newton SF 1730, 2122, 11 IRI F 3138, 16, 2122, 1730, UT W 2122, 399, 3239, MQA, Seattle F 2122, 488, 2850, MQA
2010 Galileo SF 78, 51, 2122 UT W 1696, 2122, 3405, IDA, Sacramento F 2122, 2035, 1834, IDA,
2009 Sacramento F 2144, 692, 115, 2122, MQA
2008 Newton Sacramento W 2122, 1662, 115, CA
2007 PNW Regional Highest Rookie Seed
"Enjoying traveling to more distant events" since 2007
  #34   Spotlight this post!
Unread 26-02-2014, 23:54
Max Boord Max Boord is offline
FRC #0179 (The Children of The Swamp), FRC #1592 (Bionic Tigers)
Team Role: Tactician
Max Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant future
Our team takes a different approach to dealing with defense:
1. 20 fps
2. Mecanum
3. 3/4 inch ground clearance
4. 8 square inches of tread jammed into the ground with pnumatics.(anti-push feet)
5. A 6 cim powered arm called a "shooter" that defends the entire inside of our chassis. If a mechanism enters our chassis that mechanism may exit the field at high speed. (Or at least be persuaded into an upright and locked position).
  #35   Spotlight this post!
Unread 27-02-2014, 00:01
cmwilson13's Avatar
cmwilson13 cmwilson13 is offline
AKA: Christopher Wilson
cmwilson13 has a spectacular aura aboutcmwilson13 has a spectacular aura aboutcmwilson13 has a spectacular aura about
1. 20 fps
2. Mecanum
1 and 2 are exclusionary from my experience you may be geared for that but i highly doubt you even approach that speed with Mecanum.
if so id love to see a video
"Like the WWF, but for smart people." -George HW Bush
Team Member 1771 2008-2009
Team Mentor 1771 2010-2012 2014-2016
Team Mentor 4509 2013-2014
Team Mentor 3998 2013-2014
  #36   Spotlight this post!
Unread 27-02-2014, 00:08
pfreivald's Avatar
AKA: Patrick Freivald
I believe the winning alliances will have robots wherein the ball rarely if ever touches the ground.
Otherwise, defense will likely school you if played well.
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
  #37   Spotlight this post!
Unread 27-02-2014, 08:41
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
1. 20 fps
2. Mecanum
I second seeing a video of a mecanum robot geared for 20ft/s. Unless you have a crazy drive motor setup you're going to have a hell of a time getting to 20ft/s
  #38   Spotlight this post!
Unread 27-02-2014, 08:44
RonnieS's Avatar
RonnieS RonnieS is offline
Just a tad washed up
AKA: Ronnie Sherrer
FRC #0314
RonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond reputeRonnieS has a reputation beyond repute
How many people actually have to stop and/or lower intake to shoot? I guess when we designed ours to stay in the frame the whole time I didn't realize how big of a problem it would be for people if not kept inside! Oh snap
"Do not argue with an idiot. He will drag you down to his level and beat you with experience"
  #39   Spotlight this post!
Unread 27-02-2014, 08:51
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
I would guess 1/4-1/3 of reveal videos show teams that deploy their intake, or some other mechanism, before they shoot. That's the impression that I get anyway.
  #40   Spotlight this post!
Unread 27-02-2014, 08:52
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
I'm concerned about that as well. Large hammers swinging outside the bumper perimeter, intakes outside the bumper perimeter. I also hope that the refs are keeping a VERY close eye on intentional damage. Playing good solid D does not equal intentionally taking full speed runs at other robots and slamming into them.
  #41   Spotlight this post!
Unread 27-02-2014, 10:20
pfreivald's Avatar
It can, though--and as long as the contact is all inside the bumper zone, it's entirely legal.
Team 1551
I write books, too!
  #42   Spotlight this post!
Unread 27-02-2014, 10:26
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
An interesting hypothetical situation would be: a defending robot rams an offensive robot and the defensive robot skewers itself, and become disabled, on a mechanism deployed by the offensive robot. Is that a foul on the offensive robot for contact inside the bumper zone? Is it a foul on a defensive robot for trying to incur a foul? Is it nothing because the defensive robot got what it was asking for by charging a deployed mechanism?
  #43   Spotlight this post!
Unread 27-02-2014, 10:57
E Dawg E Dawg is offline
... is not done with FRC yet.
AKA: Ethan
FRC #0159 (Alpine Robotics)
E Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud ofE Dawg has much to be proud of
I fear for the structural integrity of anything that extends outside of the standard frame perimeter. That includes the tall blocking mechanisms on goalie bots.
  #44   Spotlight this post!
Unread 27-02-2014, 11:02
Joining the 900 Meme Team
FRC #0079
Wait, teams showed everything off in their reveal videos?
  #45   Spotlight this post!
Unread 27-02-2014, 11:13
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Some fairly obviously needed to get their collector out of the way.
Smart-arse
