Go to Post Life is more fun if you take some risks every so often. - Andy Baker [more]
Unread 26-02-2014, 23:26
nickansh1 nickansh1 is offline
FRC #4777
nickansh1 is an unknown quantity at this point
Loader Wheels
I was just wondering...what are those green/orange wheels that everyone seems to be using for their loader?
Unread 26-02-2014, 23:27
mrnoble's Avatar
mrnoble mrnoble is offline
teacher/coach
FRC #1339 (Angelbotics)
mrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond reputemrnoble has a reputation beyond repute
Re: Loader Wheels
Banebots!
Unread 26-02-2014, 23:28
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Loader Wheels
http://banebots.com/c/WHB-WS
Do note that each team receives a $30PDV for Banebots, and that you can purchase (unfinished bore) wheels with it.
http://banebots.com/c/FIRST
Unread 26-02-2014, 23:29
FRC #4777
Re: Loader Wheels
thanks!
Unread 27-02-2014, 14:58
Oblarg Oblarg is offline
AKA: Eli Barnett
Re: Loader Wheels
Having used both the banebots wheels and a PVC roller wrapped in grippy material, I've found the latter works better (though both work very well). You might want to consider that.
"The breakfast of champions!"
Unread 27-02-2014, 15:44
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Loader Wheels
What was your "grippy material?" What diameter was your PVC roller? What diameter and width wheels did you use? What wheel spacing did you use? Was the compression on the ball in both cases identical?
Unread 27-02-2014, 15:49
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
Re: Loader Wheels
we have used both orange and green BB wheels on our intake. Both are the larger 3 7/8 inch wheels because we had them laying around.
The color of the BB wheels indicates their hardness. The green being the softest/grippiest. We have not seen any difference in ball acquisition between the green or orange. Compression is minimal as the BB wheels really grab the ball as long as you dont try to be to low on it.
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 27-02-2014, 16:37
AKA: Eli Barnett
Re: Loader Wheels
Compression was fairly similar. The roller was 2.5'' diameter, covered in blue TheraWrap. The banebots wheels were similar size, maybe somewhat bigger (don't remember offhand). Unfortunately, as this was with different teams, we were running them off of different motors, but the roller consistently seemed to outperform the wheels both in hand drill-driven prototypes and on the final mechanisms. The roller was driven with a RS550 on a 26:1 reduction. The wheel pickup used a BAG motor on a reduction that I don't remember offhand.
No, it's not the most controlled of comparisons, I am aware.
