Go to Post Every single team in FRC has had a rookie season. All those... have stories. Some are sad, some are funny, some are inspiring - but all the teams have stories to be told... Each year is a chapter in the team's history book with stories to be told and shared. - JaneYoung [more]
Unread 26-02-2014, 23:55
yash101 yash101 is offline
AKA: null
Driver Station Automatic Disabling
Whenever I switch to a different window, a safety feature in the DS triggers the system to disable the robot. This is very annoying because I am using a separate application for vision processing, written in C++ with OpenCV, and it requires a bit of labor. I don't want the robot to disable in the middle of a match because I switched windows. How can I disable this feature?
Unread 27-02-2014, 00:36
kylelanman's Avatar
kylelanman kylelanman is offline
Programming Mentor
AKA: Kyle
FRC #2481 (Roboteers)
kylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to allkylelanman is a name known to all
Re: Driver Station Automatic Disabling
We have not noticed the behavior you are describing exactly. We are able to switch to other programs but the [Enter] key and the [SpaceBar] are still captured. This means hitting [SpaceBar] will E-Stop your robot and hitting [Enter] will disable you robot. This is very annoying if you program on the same laptop as your driver station. At any rate simple changing which window is active shouldn't be disabling the robot. Is it possible you are pressing [SpaceBar] or [Enter] ?
"May the coms be with you"
Is this a "programming error" or a "programmer error"?
Unread 27-02-2014, 05:44
The other post described it well. When not connected to the field, space and enter are used to estop and disable the robot. There is no turning that off.
When connected to the field -- when the FMS Connected string is present on the DS, only the F1 key will be honored. Enter and Space will no longer trigger anything to happen on your robot.
Greg McKaskle
