Go to Post Yes, I try to win matches, but you don't want to disrespect opponents......just get on their nerves an awful lot! :D - Josh Goodman [more]
Unread 27-02-2014, 15:09
TenaciousDrones's Avatar
TenaciousDrones TenaciousDrones is offline
FRC Team 4780
FRC #4780 (The Tenacious Drones)
TenaciousDrones is an unknown quantity at this point
Bunch of Different Issues
Ok so I'm done posting a ganzillion different threads about different problems, so I'm just going to make one with everything together.
Our problems include but are not limited to:
- spikes not working
- unsure of how to use pressure switch
- unsure if our gyro is programmed correctly
- unsure if our potentiometer is programmed correctly
- unsure if our Talon motor controller is programmed correctly
- unsure if our solenoids are programmed correctly
- unsure how to get vision into Netbeans
- unsure how to test any of our programming now.
If you have anything that might be useful, please just say it because my partner and are in desperate need right now. We are using RobotBuilder exported to Java. For Vision we have the tape detected in RoboRealm but we are willing to use another program if someone isn't used to RoboRealm. Thanks in advance.
Last edited by TenaciousDrones : 27-02-2014 at 15:33. Reason: I forgot the "s" in threads and my partner wouldn't stop annoying me.
