Go to Post The robot uprising is coming for your chairs first, people. - bobbysq [more]
Unread 27-02-2014, 14:38
Phygon Phygon is offline
FRC #0004
Phygon is an unknown quantity at this point
Exclamation Issues with arm PID
Our programmers have been working on re-writing the code for our robot, and they're currently working on a PID loop to keep the arm raised at a certain position. To get a reading of the arm's position they have a pot. This code is supposed to hold the arm as it is when it reaches 3v, a value that we measured out beforehand. However, when we execute this code, all the motor does is weakly turn to push the arm down once the pot exceeds 3v, without attempting to lift it at all. This is baffling to me, as this is almost the exact same code as we use for out drivestraight function, which works perfectly.
Attached is the command for the arm subsystem
package org.usfirst.frc4.Team4Descent.commands;
import edu.wpi.first.wpilibj.AnalogChannel;
import edu.wpi.first.wpilibj.command.Command;
import edu.wpi.first.wpilibj.interfaces.Potentiometer;
import org.usfirst.frc4.Team4Descent.Robot;
import org.usfirst.frc4.Team4Descent.RobotMap;
import org.usfirst.frc4.Team4Descent.subsystems.Shooter;
 * @author Rachel
public class ArmPosition extends Command {
   public double
            speed,
            turn,
            angleMod,
            Kp,
            Kd,
            potRaw,
            botAngle,
            previousP;
    AnalogChannel shooterPOT = RobotMap.shooterPOT;
    public ArmPosition() {
        requires(Robot.shooter);
    // Called just before this Command runs the first time
    protected void initialize() {
       //Kp and Kd values for tuning
        Kp          = 0.07;
        Kd          = 0; //Percent
    // Called repeatedly when this Command is scheduled to run
    protected void execute() {
        //PID loop
        double
            setPoint = 3.00,
            processVariable = shooterPOT.getVoltage(),
            PID_P = -(setPoint - processVariable),
            PID_D = (PID_P - previousP),
            PID = (PID_P * Kp) + (PID_D * Kd);
        //Sets the arm pivot motor equal to the output PID value
        Shooter.shooterTalon.set(PID);
//Limits arm speed for testing
if(Shooter.shooterTalon.get() >= 0.05)
    Shooter.shooterTalon.set(0.05);
}else if(Shooter.shooterTalon.get() <= -0.05)
    Shooter.shooterTalon.set(-0.05);
	//Sets the previous process variable to the current one
        previousP = processVariable;
        System.out.println(shooterPOT.getVoltage());
    // Make this return true when this Command no longer needs to run execute()
    protected boolean isFinished() {
        return false;
    // Called once after isFinished returns true
    protected void end() {
    // Called when another command which requires one or more of the same
    // subsystems is scheduled to run
    protected void interrupted() {
Unread 27-02-2014, 14:48
bartv bartv is offline
FRC #4946
bartv is an unknown quantity at this point
Re: Issues with arm PID
Hi,
You have a very small kP value, likely just enough to move the arm when gravity helps (hence the observed motion on the way down). You also don't have an integral. The integral term is used to increase the effort the longer a position error exists.
I.e., lets say you start with the poteniometer at 0v -> an error of 3v. The controller will apply 3*.07 = .21% - > 2.1v at the talon. What would move the arm? If 2.1v is not enough, it will never move. If you had an integral, it would start adding more power the longer the error existed. The kD term is only useful for sudden changes (derivate) in position, which you are not getting at the moment (plus you zeroed it).
Try increasing the kP variable, and adding an integral. Have you looked at the PID class provided?
Cheers,
Bart
Unread 27-02-2014, 14:50
foote stepped in
AKA: E. Foote
FRC #0868
I have a few questions about your design (a picture of your arm would greatly help understand your system!)
Can the motors to the arm be back driven?
Are the motors to the arm fighting gravity in one direction?
Should the motors still be "on" and stalled once the arm reaches the position at 3v?
Be Healthy. Never Stop Learning. Say It Like It Is. Own It. Like our values? Flexware Innovation is hiring!. We're looking for Senior Automation, Software, and System Engineers. Check us out!
Unread 27-02-2014, 14:52
Is sending 0.2 to the motor enough to raise it? Your Kp constant doesn't look nearly large enough to control an arm against gravity, and I don't see an I term to overcome the steady-state error you'll have.
Start by increasing Kp until it oscillates, then dial it back just enough to stop the oscillations. If that doesn't keep the arm where you want it to be, consider adding I to what's now just a P controller.
Unread 27-02-2014, 15:22
FRC #0004
Originally Posted by bartv View Post
Hi,
Cheers,
Bart
The value is definitely not enough to move the arm, we had an issue earlier where the code was always sending a high value to the motor and it swung hard enough to almost break someone's arm/the robot, so we cut it down for testing. However, the issue is that the arms are getting literally 0 power before they pass that 3 mark- When I print the pid value I get 0 and the motor lights don't turn on till it passes that mark.
Unread 27-02-2014, 15:29
TRWSHSHLX TRWSHSHLX is offline
AKA: Henry Lei
TRWSHSHLX is an unknown quantity at this point
What kind of arm is it? For a lot of lifting / arm systems, it might be more beneficial to add a spring instead.
Unread 27-02-2014, 15:37
FRC #4946
What voltage does your pot read at your low point (before passing 3)?
Stupid question, but just making sure the pot reads in advance.
In the low/start position, what are the other variables reading?
Unread 27-02-2014, 15:45
You are sending conflicting commands to the motor by having multiple calls to shooterTalon.set. If you want to limit the speed, you need to do that before calling set.
Unread 27-02-2014, 16:00
Jared Russell's Avatar
Taking a year (mostly) off
Besides which, you are limiting power to +/-5% of maximum. I don't know your gear ratio, but that may simply not be enough to hold position.
Unread 27-02-2014, 16:23
Bruceb's Avatar
Bruceb Bruceb is offline
FRC #0706 (Cyberhawks)
Bruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to beholdBruceb is a splendid one to behold
we arent using PID at all on our arm.
PG188 in brake mode is all it takes to hold position.
Mentor Team 706 The CyberHawks
2010 Wisconsin Regional Rockwell Automation Innovation in Control Award
2010 Wisconsin Regional Finalist
2013 Buckeye Regional Finalist
2014 Superior Regional Industrial Design Award
2014 Superior Regional Finalist
2014 Wisconsin Regional Finalist
2014 Wisconsin Motorola Quality Award
2015 Wisconsin Regional Motorola Quality Award
2015 Queen City Creativity Award
2016 Buckeye Regional Finalist
2016 Wisconsin Regional Finalist
2016 Wisconsin Regional Industrial Safety Award
2016 Wisconsin Regional Excellence in Engineering Award
https://www.youtube.com/user/Cyberhawks706
Unread 27-02-2014, 16:57
FRC #0004
The pot is reading ~3.5 at the lowest position of the arm and 1 at the highest
Even without the limiting code, the exact same movements are observed.
And I know the voltage is too low- the problem is that it isn't outputting anything at all until the value is below 3 (arm up)
Unread 27-02-2014, 17:38
FRC #4946
Given all those things, I would suggest finding out what the variables are actually reading; output each variable, and see where in your equation you are getting zero. Could you post those?
Unread 27-02-2014, 17:51
connor.worley's Avatar
connor.worley connor.worley is offline
connor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond reputeconnor.worley has a reputation beyond repute
These limits keep your values barely outside of the Talon's deadbands, and your output could be getting deadbanded depending on calibration.
Also,
should be
        previousP = PID_P;
although this won't have any effect while Kd = 0.
EDIT: saw OP's last post. Did you increase Kp?
Team 973 (2016-???)
Team 5499 (2015-2016)
Team 254 (2014-2015)
Team 1538 (2011-2014)
2014 Driver (25W 17L 1T)
日本語でOK
Unread 27-02-2014, 17:58
kiettyyyy's Avatar
kiettyyyy kiettyyyy is offline
FRC #1538 (The Holy Cows)
kiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond repute
Send a message via AIM to kiettyyyy
Rachel, just as previous posts have stated, your kP value looks way too small. I'd recommend setting your kP to 1 and work from there. The goal is to make your P component barely oscillate. Once the P component oscillates, remove the oscillation by increasing your kD constant from 0 to what ever value achieves the goal with minimal or no oscillation.
Assuming you've implemented Connor's recommendations, you should be fine. Feel free to contact us if you'd like some additional help.
-Kiet Chau
2004-2008 - Software Developer/Driver on Team #968
2008-2011 - Software Developer/Coach/Mentor/"Engineer" on Team #968
2011-Present - Mentor & Engineer on Team #1538
www.team1538.com
Unread 28-02-2014, 02:44
FRC #0004
The issue was with the arm kP. Thanks!
