Go to Post Are we really at the point where the only useful thing we can discuss is Dean's choice in timekeeping apparel? The man has a watch. He uses it to tell time. Do we really care how much it is worth, or who made it? I would be much more interested in what he does, not what he wears. - dlavery [more]
Unread 27-02-2014, 21:42
AM694 AM694 is offline
AKA: Ameya Majmudar
FRC #0694 (Stuypulse)
AM694 is an unknown quantity at this point
Problem with CIM-VersaPlanetary Setup (Choo-Choo motor)
Hi, our idea, for the choo-choo motor, was to have a modified CIM motor (shaft cut to approximately 1/2") mounted to a VersaPlanetary 50:1 reduction, and to use the key (approx. .4") as opposed to a set screw, as we thought a set screw would not be able to adequately transfer the torque.
Eventually, after a day of testing, the setup became unable to pull down the Choo-Choo. My gut feeling, from what my ears were telling me, was that something was skipping, as there was this grinding sound that seemed like something was hitting against something else.
This could possibly be because the 2mm key is failing to transfer torque to the gearbox (e.g, it's skipping or breaking somehow), it could be because of a failing CIM motor (on a previous one that broke, the CIM operated almost perfectly, but on occasion, its rotation faltered).
It was very easy to put one's hand on the "output sprocket", and rotate the VP output shaft, albeit with the knocking sound occurring.
We've tried increasing the length of the key (by artificially pushing out the CIM's keyway relative to the keyway of the gearbox with extra face plates), and that helped, but this setup needs to be more sustainable and rugged than it is. What are your thoughts? Did anyone have similar issues? Thanks a lot for your help!
Unread 27-02-2014, 21:51
Volunteer, WPILib Contributor
no team (Waiting for 2021)
Re: Problem with CIM-VersaPlanetary Setup (Choo-Choo motor)
Have you taken the gearbox apart to see if there is any problem with the gears? Also, what ratio's are you using?
Team 4488 - Mentor 2013-2016
Unread 27-02-2014, 21:55
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
We are running a 50:1 and we have taken it apart. The problem almost surely lies in the key skipping because when we opened things up there was a mark on the shaft of the CIM all the way around that was likely made by the key spinning round and round.
Also the main issue is the free spinning of the motor which is related to the connection between the shaft of the CIM and the collar from the gearbox. We are trying to figure out a better way to connect the two than the set screw and key options that we have already played with.
I will say that the key held up for a solid amount of testing and practice before giving way.
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
Unread 27-02-2014, 21:56
Exla357's Avatar
Exla357 Exla357 is offline
Certified Joystick Pusher
FRC #0159 (Alpine Robotics)
Team Role: Electrical
Exla357 will become famous soon enoughExla357 will become famous soon enough
We've had a very similar problem with our choo-choo mechanism.
We have a bag motor on a 250:1 reduction and our problem has been that the orbital gears inside the box, somewhere, have been shattering. The box still functions (as the pieces of the gears are held in place by friction) but there is a skipping motion as well as some wierd noises. We had to replace it twice in the 3 days before bag day. I would suggest opening up the VersaPlanetary and checking it out.
Also, make sure you've got a hard stop on your catapult that ISN'T the choo-choo. This causes incredible torquing and can eventually break the whole assembly. We use a steel cable.
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
It sounds to me like you have damaged splines on the output shaft of the planetary or broken a sun or pinion gear. You should take it apart to assess the issue to know for sure. If there are broken gears, the torque applied to the planetary exceeds its point of failure and you should look into alternate solutions.
2015 GKC Engineering Inspiration
2015 Colorado Winners
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Use a motor/gearbox combination that more naturally interfaces with each other. Consider replacing your CIM motor with a 775, or replacing the VersaPlanetary with a GEM500. Perhaps the fine folks at Vex can make suggestions as to how to modify a CIM to better fit their planetaries, but it is not designed to integrate with a CIM off the shelf.
Unread 27-02-2014, 22:07
jblay's Avatar
AKA: Joe Blay
We want to get the power that a CIM provides us, the other motors won't do the job at the speeds we need if at all with our current ratio and a ratio change would mean major mounting adjustments in something that has holes setup at the base of our robot which is pretty impossible at this stage in the game.
It was working really well for a while before the problem so we are pretty confidant that if we can connect the collar to the CIM better it will hold up through competition. We just need the clever engineers of the CD world to give us a better idea than mine of, just put a pin through both.
Unread 27-02-2014, 22:31
If using the correct type key, it does fit into the opening on the collar, and the only thing that would cause it to fail is if the key actually breaks, or the key moves. Maybe putting the key in, then using some Loctite 609 to hold it in place could stop it from moving.
Also, with that ratio off of a CIM, at stall you are actually over the torque rating of the gearbox. With the 10:1 gearset, it can only take 74 ft-lbs, where a CIM at that ratio can output 89 ft-lbs. So I would defiantly be worried about actually breaking the insides of the gearbox with that much reduction.
Unread 28-02-2014, 00:29
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
It sounds like pinning the CIM motor could be your best option at this point.
Without knowing the exact details on your setup, it's hard to give specific (and relevant) advice, but here are some ideas worth thinking about and/or questions worth asking:
Which CIM motor are you using? One of the newer ones, or one of the older ones? I'm not entirely sure when - but at one point or another (I think somewhere around 2007/2008, maybe earlier) CIM motors went from having a 'full'(ish) keyway on the output shaft, to the current milled slot sort of setup. I don't have a motor in front of me at the moment, but I'd imagine that if you cut the CIM output down to 1/2" long, then you're only getting a 1/4" key there - if you're lucky. If this is the case, finding an "older" cim motor with the full (More full) keyway might be worthwhile. Or, on the same train of thought, if you've got a halfway decent mill, you could always extend the keyway another .125-.25" towards the CIM's mounting boss, but that could get a bit tricky (Need to fixture the CIM just right). The longer keyway would allow you to run a longer key, which should be able to take a bit more abuse - assuming that the versaplanet's input isn't the limiting factor in key length. **see edit below
Otherwise, since your failure seems to be rooted in the CIM to VersaPlanet interface, you're only real option seems to be to make the interface stronger via some other mechanical method. Pinning the CIM to the input doesn't seem like a half bad idea to be quite honest - I'd imagine you can get a reasonably large pin through both shafts without issue. At that point assembly/dis-assembly might become problematic/annoying/etc, but if you've got the money/resources to have multiple motor/gearbox assemblies on hand, then it could be a non-issue.
Edit: Did some digging on older CIM motors, and came up with this drawing from ~2002. It appears that back then, CIM motors had a keyway that was ~.125" (3mm) longer than the current ones, at least when looking at where the keyway stops relative to the CIM mounting boss.
Old CIM: http://www.team1322.org/chip.jpg
Current CIM: http://files.andymark.com/CIM-motor-curve.pdf
Also, there's part of me that thinks that the 2007/2008ish BaneBot's Supplied CIM motors may also have a longer keyway too. Can't find a drawing to get conclusive proof, but it might be worth looking through old CIM motors, just in case - there are a bunch of legal part numbers that are legal, so you may get lucky and find the 'right one.'
-Dustin Benedict
Unread 28-02-2014, 10:38
ryaneogilvie's Avatar
ryaneogilvie ryaneogilvie is offline
Student
AKA: Ryan Ogilvie
FRC #3847 (Spectrum)
ryaneogilvie is on a distinguished road
Im pretty sure (you can check the wattage) You can get more power by using the dual motor mount for versa-planetary with two 775's if it fits with your setup.
Assuming that your key is shearing you may try finding a key made of stronger material that wont shear. you might also be using the incorrect key in which you should find the correct one. ( the correct key should be a press fit in the keyway of the motor).
Spectrum 3847
FRC and VRC
FRC Main Driver
Mechanical,CAD,Design,Electrical
Unread 28-02-2014, 12:18
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Check to make sure the tiny tiny pin in the sun gear didn't fall out. The pin is staked in and will easily fall out. After you'll hear a grinding noise and the transmission will bind and then free rotate.
We had that problem on our intake transmissions.
To solve the high power needed for the winch we are using the dual 18V -RS-775 on our Choo Choo at 300:1 plus the 18:84 gears. It takes 8 seconds to wind but it is strong. We designed our whole ChooChoo mechanism to be a drop in module cause we know how much torque is needed for these high powered catapults. They are bound to break.
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 28-02-2014, 12:20
That depends on the load and the gearing. You can't just compare the max power ratings of the motors. You have to figure what the operating point would be, given the load and the gearing.
Unread 28-02-2014, 12:26
What's the output torque rating of that 300:1 gearbox?
Stall torque of 775-18 is 113 ozin.
113*2*300 = 67,680 ozin = 352 ft_lb
Unread 28-02-2014, 13:09
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
Here is our spec for our Choo Choo. We know the rating is out of spec that VexPro recommends. But it works
http://www.chiefdelphi.com/forums/at...9&d=1393529241
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 28-02-2014, 13:34
What does VexPro recommend for a 300:1 setup?
