Go to Post We put our alumni to work. That either benefits all or drives them out for good. :) - Wayne C. [more]
Unread 27-02-2014, 21:55
jblay's Avatar
jblay jblay is offline
Here comes StuyPulse
AKA: Joe Blay
FRC #0694 (StuyPulse)
jblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond reputejblay has a reputation beyond repute
Re: Problem with CIM-VersaPlanetary Setup (Choo-Choo motor)
Originally Posted by sst.thad View Post
Have you taken the gearbox apart to see if there is any problem with the gears? Also, what ratio's are you using?
We are running a 50:1 and we have taken it apart. The problem almost surely lies in the key skipping because when we opened things up there was a mark on the shaft of the CIM all the way around that was likely made by the key spinning round and round.
Also the main issue is the free spinning of the motor which is related to the connection between the shaft of the CIM and the collar from the gearbox. We are trying to figure out a better way to connect the two than the set screw and key options that we have already played with.
I will say that the key held up for a solid amount of testing and practice before giving way.
It's pronounced StighPulse like HighPulse
2016 Curie Champions
2016 New York City Champions
2016 New York City Engineering Inspiration
2015 New York City Finalists
2013 New York City Champions
2012 Connecticut Chairman's
2011 Connecticut Chairman's
2010 Connecticut Chairman's
2010 New York City Champions
2008 New York City Engineering Inspiration
2007 New York City Finalists
2006 New York City Finalists
2005 New York City Chairman's
2003 New York City Champions
2002 New York City Engineering Inspiration
2001 New York City Finalists
