Go to Post In the real world nothing is ever to spec. Just another part of the challenge. - Koko Ed [more]
Unread 12-02-2013, 17:04
CEO_TRAMMELL's Avatar
CEO_TRAMMELL CEO_TRAMMELL is offline
CEO_TRAMMELL
FRC #4295 (HudsonISD Robotics)
CEO_TRAMMELL is an unknown quantity at this point
XBOX Controller JAVA Programming
I need help programming Xbox 360 Wired controller in Java to get it to drive, move, turn, program buttons, etc.
Unread 12-02-2013, 20:24
AKA: Brad
#0190 ( Gompei and the Herd)
Re: XBOX Controller JAVA Programming
Is it just the Xbox controller you're having trouble with or the whole robot program?
If you're not sure how to program the robot check out this web site: http://youtube.com/user/bradamiller and look at the playlists for the Command Based Programming videos or the RobotBuilder videos.
Brad
Brad Miller
Robotics Resource Center
Unread 13-02-2013, 01:41
gixxy's Avatar
gixxy gixxy is offline
Programming and Arduino Mentor
AKA: Gustave Michel III
FRC #3946 (Tiger Robotics)
gixxy is on a distinguished road
If it is programming the robot in general you are having problems with See Brad's videos(linked above).
If it is getting the Xbox to work with your robot code you can always use the default Joystick class, or optionally you could use an Xbox class like the one I designed: https://github.com/frc3946/UltimateA...ontroller.java
In either case the process of use is nearly Identical, just more abstraction with the XboxController class.
Programmer - A creature known for converting Caffeine into Code.
Studying Computer Science @ Louisiana Tech University
Associate Consultant @ Fenway Group
2012-13: 3946 - Head of Programming, Electrical and Web
2014 - 3468 - Programming Mentor
2015 - Present - Lurker
Unread 28-02-2014, 01:56
James Lightfoot James Lightfoot is offline
Programming & Electrical Mentor
FRC #3737 (Rotoraptors)
James Lightfoot is just really niceJames Lightfoot is just really niceJames Lightfoot is just really niceJames Lightfoot is just really niceJames Lightfoot is just really nice
OK. In trying to "clean up" the parts we are not using (e.g. some of the buttons, the right stick's x-axis), I think I got it where I want it, except for 1 thing. The intial class declaration "public class XboxController extends GenericHID implements IInputOutput" is returning "XboxControlleris not abstract and does not override abstract method GetRawButton (int)in GenericHID” error. As I am crashing into Java, I'm not swift enough to realize what I need to do later in the class when I am pulling button true/false states.
 * To change this license header, choose License Headers in Project Properties.
 * To change this template file, choose Tools | Templates
 * and open the template in the editor.
package org.usfirst.Rotoraptors.controls.hids;
import edu.wpi.first.wpilibj.DriverStation;
import edu.wpi.first.wpilibj.GenericHID;
import edu.wpi.first.wpilibj.parsing.IInputOutput;
 * A nearly drop in replacement for Joystick using an XBOX USB Controller
 * @author Gustave Michel @edits Kaveen Herath & James Lightfoot
public class XboxController extends GenericHID implements IInputOutput {
    private DriverStation m_ds;
    private final int m_port;
     * Represents an analog axis on a joystick.
    public static class AxisType {
    * The integer value represents the axis enumeration
    * Axis 1 is the Left Joystick X axis value Left to Right = -1 to 1
    * Axis 2 is the Left Joystick Y axis value Up to Down = -1 to 1
    * Axis 3 is the Rear Triggers axis value Left = 0 up to 1 & Right = 0 down to -1
    * Axis 4 is the Right Joystick X axis value Left to Right = -1 to 1
    * Axis 5 is the Right Joystick Y axis value Up to Down = -1 to 1
    * Axis 6 is the Direction Pad X axis value Left to Right = -1 to 1
    public final int value;
        public static final int kLeftX_val = 1;
        public static final int kLeftY_val = 2;
        public static final int kTrigger_val = 3;
        public static final int kRightX_val = 4;
        public static final int kRightY_val = 5;
        public static final int kDLeftRight_val = 6;
        public AxisType(int value) {
            this.value = value;
            // Axis: Left X
            public static final AxisType kDRIVEltRT = new AxisType(kLeftX_val);
            // Axis: Left Y
            public static final AxisType kDRIVEfwdREV = new AxisType(kLeftY_val);
            // Axis: Triggers
            public static final AxisType kBBarmMANctrl = new AxisType(kTrigger_val);
            // Axis: Right X
            public static final AxisType kRightX = new AxisType(kRightX_val);
            // Axis: Right Y
            public static final AxisType kBParmsUPdwn = new AxisType(kRightY_val);
            // Axis: D-Pad Left-Right
            public static final AxisType kDLeftRight = new AxisType(kDLeftRight_val);
   * Represents a digital button on a joystick.
    public static class ButtonType {
        * The integer values for each of the Xbox Controller's buttons
        public static final int kA_val = 1;
        public static final int kB_val = 2;
        public static final int kX_val = 3;
        public static final int kY_val = 4;
        // public static final int kLB_val = 5;
        public static final int kRB_val = 6;
        // public static final int kBack_val = 7;
        // public static final int kStart_val = 8;
        public static final int kLeftStick_val = 9;
        // public static final int kRightStick_val = 10;
        // public static final int kRTrigger_val = 11;
        // public static final int kLTrigger_val = 12;
        public ButtonType(int value) {
            this.value = value;
            //  Button: A
            public static final ButtonType kBParmsCLOSE = new ButtonType(kA_val);
            //  Button: B
            public static final ButtonType kBParmsPROCautoSTART = new ButtonType(kB_val);
             //  Button: X
            public static final ButtonType kBParmsOPEN = new ButtonType(kX_val);
            //  Button: Y
            public static final ButtonType kBParmsPROCautoCANCEL = new ButtonType(kY_val);
            //  Button: LB
            // public static final ButtonType kLB = new ButtonType(kLB_val);
            //  Button: RB
            public static final ButtonType kBBarmFIRE = new ButtonType(kRB_val);
            //  Button: Back
            // public static final ButtonType kBack = new ButtonType(kBack_val);
            //  Button: Start
            // public static final ButtonType kStart = new ButtonType(kStart_val);
            //  Button: Left Joystick
            public static final ButtonType kDRIVEspeedSLOW = new ButtonType(kLeftStick_val);
            //  Button: Right Joystick
            // public static final ButtonType kRightStick = new ButtonType(kRightStick_val);
            //  Button: Right Trigger
            // public static final ButtonType kRTrigger = new ButtonType(kRTrigger_val);
            //  Button: Left Trigger
            // public static final ButtonType kLTrigger = new ButtonType(kLTrigger_val);
     * Constructor
     * @param port USB Port on DriverStation
    public XboxController(int port) {
        super();
        m_port = port;
        m_ds = DriverStation.getInstance();
     * Get Value from an Axis
     * @param axis Axis Number
     * @return Value from Axis (-1 to 1)
    public double getRawAxis(int axis) {
        return m_ds.getStickAxis(m_port, axis);
     * @param axis AxisType
     * @return
    public double getAxis(AxisType axis) {
        return getRawAxis(axis.value);
     * Retrieve value for X axis of both joysticks
     * @param hand Hand associated with the Joystick
     * @return Value of Axis (-1 to 1)
    public double getX(Hand hand) {
        // if(hand.value == Hand.kRight.value) {
            // return getAxis(AxisType.kRightX);
        // } else if(hand.value == Hand.kLeft.value) {
		   return getAxis(AxisType.kDRIVEltRT);
        } else {
            return 0;
     * Retrieve value for Y axis of both joysticks
    public double getY(Hand hand) {
            return getAxis(AxisType.kBParmsUPdwn);
            return getAxis(AxisType.kDRIVEfwdREV);
        } else {
            return 0;
     * Unused
     * @param hand Unused
     * @return 0
    public double getZ(Hand hand) {
        return 0;
     * Gets Value from D-Pad Left and Right Axis
     * @return Axis Value (-1 to 1)
    // public double getTwist() {
       // return getAxis(AxisType.kDLeftRight);
     * Gets Value from Back Triggers
    public double getThrottle() {
        return getAxis(AxisType.kBBarmMANctrl);
     * Gets value from a trigger functioning as a button
     * @param button number of the button
     * @return State of the button
    // public boolean getRawButton(int button) {
        // if(button == ButtonType.kRTrigger.value) { //Abstracted Buttons from Analog Axis
            // if(getThrottle() <= -.6) {
                // return true;
            // else {
                // return false;
        // if(button == ButtonType.kLTrigger.value) { //Abstracted Buttons from Analog Axis
            // if(getThrottle() >= .6) {
                // return true;
            // else {
                // return false;
        // return ((0x1 << (button - 1)) & m_ds.getStickButtons(m_port)) != 0;
     * Get Value from a button
     * @param button Button Type
     * @return
    public boolean getButton(ButtonType button) {
        return getRawButton(button.value);
     * Get Trigger Value as Button
     * @param hand Hand associated with button
     * @return false
    // public boolean getTrigger(Hand hand) {
        // if(hand == Hand.kLeft) {
            // return getButton(ButtonType.kLTrigger);
        // } else if(hand == Hand.kRight) {
            // return getButton(ButtonType.kRTrigger);
        // } else {
            // return false;
     * Get Button from Joystick
     * @param hand hand associated with the button
     * @return Button Status (true or false)
    public boolean getTop(Hand hand) {
        // if(hand == Hand.kRight) {
            // return getButton(ButtonType.kRightStick);
        // } else if(hand == Hand.kLeft) {
            return getButton(ButtonType.kDRIVEspeedSLOW);
        } else {
            return false;
     * Get Value from Back buttons
     * @return state of left or right
    public boolean getBumper(Hand hand) {
            return getButton(ButtonType.kBBarmFIRE);
            // return getButton(ButtonType.kLB);
        } else {
            return false;
     * Get State of Select Button
     * @return State of button
    // public boolean getStart() {
        // return getButton(ButtonType.kStart);
     * Get State of Back Button
    // public boolean getBack() {
        // return getButton(ButtonType.kBack);
     * Get State of A Button
    public boolean getAButton() {
        return getButton(ButtonType.kBParmsCLOSE);
     * Get State of B Button
    public boolean getBButton() {
        return getButton(ButtonType.kBParmsPROCautoSTART);
     * Get State of X Button
    public boolean getXButton() {
        return getButton(ButtonType.kBParmsOPEN);
     * Get State of Y Button
    public boolean getYButton() {
        return getButton(ButtonType.kBParmsPROCautoCANCEL);
Any help will be greatly appreciated.
Unread 28-02-2014, 09:12
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Here's the Xbox controller class we use: https://github.com/team1306/Badgerbo...ontroller.java
We haven't needed to modify it in 4 years.
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
*snip*
You're running into issues because you're extending the class GenericHID. If you do that, you'll have to implement your own version of every method on this page listed as abstract.
My suggestion would be to extend Joystick instead, as all that will be done for you (The XBox controller functions as a Joystick anyway), then you can implement your own methods for detecting specific buttons.
Unread 28-02-2014, 11:43
Thanks for the replies. So if I change the code to this:
// import edu.wpi.first.wpilibj.parsing.IInputOutput;
public class XboxController extends Joystick {
            this.value = value;
            // Axis: Left X
            // Axis: Left Y
            // Axis: Triggers
            // Axis: Right X
            // Axis: Right Y
            this.value = value;
            //  Button: A
            //  Button: B
             //  Button: X
            //  Button: Y
            //  Button: LB
            //  Button: RB
            //  Button: Back
            //  Button: Start
     * Constructor
        super();
        m_port = port;
     * @return
        } else {
            return 0;
        } else {
            return 0;
     * Unused
     * @return 0
        return 0;
                // return true;
            // else {
                // return false;
                // return true;
            // else {
                // return false;
     * @return
     * @return false
        // } else {
            // return false;
        } else {
            return false;
        } else {
            return false;
The original error goes away, but a new one pops up under the constructor for the XboxController's super();:
no suitable constructor found for Joystick(no arguments) constructor Joystick.Joystick(int) is not applicable (actual and format argument lists differ in length
constructor Joystick.Joystick(int, int, int) is not applicable
I'm thinking that my lack of knowledge of the FRC's Java library is what is killing us, in addition to not being super familiar w/ Java. My programming comes from a much different place (PLC's/PAC's, HMI's, SCAD, DCS) which often calls for platfor specific scripting.
Thanks again,
Unread 28-02-2014, 11:48
AKA: Josh P.
*snip*
Thanks again,
So, in Java, what super() does is if you're extending a class, it calls the constructor of the class you're extending (or superclass). So, right now, it's trying to call Joystick(). If we look at the javadoc for Joystick, we can see the valid constructors for Joystick. You probably want to sue the 1-argument one, and change it to super(port).
Unread 28-02-2014, 11:49
Questions: 1) Where does the axxes and button numbers get assigned to names, for easier use in the rest of the programming? 2) What is the significance of the line: return ((0x1 << (button - 1)) & m_ds.getStickButtons(m_port)) != 0; Does this only apply if we want to use the back triggers as buttons instead of axis 3, or do we need the line either way?
Thanks
Unread 28-02-2014, 15:12
Thanks and thank you , BigJ. I have bought a couple of books to use in teaching our programmers Java post-season, but I am still looking for one that can give a "Cliif Notes" intro into Java. As a programmer of other languages for 25+ years, I get the concepts of programming, but OOP, specifically Java, are new to me; hence, I am looking for something that gives a high level breakdown of the various structures (e.g. class, method, variable, construct, instance, etc.), what each typically requires, how each uses or feeds the others, etc. Any advice will be pput to use post-haste.
Unread 28-02-2014, 15:27
AKA: Josh P.
http://docs.oracle.com/javase/tutori...aOO/index.html is an OK guide to the OO stuff in java. Be aware that these pages are for Java SE, the Java we use on the robot for at least this year is still pretty old. I think all the OO stuff (classes, inheritance, etc) is the same aside from enums. They also have some pages in there on things coming in Java 8 which we definitely don't have.
Unread 28-02-2014, 16:27
Thank you again, Big J. I think I saw the Oracle tutorial site at some point but thought it was going to a big/long thing, so I saved the link and moved on. Once you suggested it, I took a quick look around and saw that it does kepp it pretty brief but w/ looks like all of the context. I have passed it along to our senior programmer, and I am going through them right now.
