Go to Post Has FIRST ever made a game that was easy to do? - Koko Ed [more]
Unread 28-02-2014, 22:48
miw14 miw14 is offline
FRC #4840
miw14 is an unknown quantity at this point
URGENT:Auto Problem trying to fix before tomorrow
On our first day of competition, we ran into some problems with our shooter. The shooter does not seem to be functioning right in autonomous, but it functions fine in teleoperated. We use the same methods for both, but they both yield different results. Any ideas as to why it works well in one and not the other? The launcher barely moves when we try it in auto, but works fine in teleoperated. The driving is fine in auto. Here is the code:
Autonomous method:
public void autonomous()
{ myDrive.setSafetyEnabled(false);
myDrive.drive(-.5, 0.0);
Timer.delay(3.5);
myDrive.stopMotor();
Timer.delay(1.5);
startRaisingLauncher();
Timer.delay(3.5);
stopMovingLauncher();
stopAll();
Raising launcher method:
private void startRaisingLauncher()
setLiftPower(-1);
set power method:
private void setLiftPower(double power)
M1.set(-power);
M2.set(power);
Unread 28-02-2014, 22:54
Domenic Rodriguez's Avatar
Domenic Rodriguez Domenic Rodriguez is offline
FRC #0316 (LuNaTeCs)
Domenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura aboutDomenic Rodriguez has a spectacular aura about
Re: URGENT:Auto Problem trying to fix before tomorrow
Without seeing more of the code, it will be difficult to determine what the issue is. Are you having problems both on and off the field? Is there any way the power values to the motors could be different between Autonomous and Teleop modes?
Also, if you wrap your code in [code][/code] tags, it will format nicely, like this:
public void autonomous() {
    Timer.delay(3.5);
    Timer.delay(1.5);
    Timer.delay(3.5);
    stopAll();
// Raising launcher method:
private void startRaisingLauncher() {
    setLiftPower(-1);
// set power method:
private void setLiftPower(double power) {
    M1.set(-power);
    M2.set(power);
LuNaTeCs - Learning Under Nurturing Adults Teaching Engineering Concepts and Skills - Small and Mighty!
FRC 316 LuNaTeCs - Student (2011-2014), Lead Programmer (2011-2014), Team Captain (2013-2014), Operator (2013), Drive Coach (2014), Mentor (2015-????)
'11 Philly Regional Finalists, '13 Chestnut Hill Finalists, '13 Lenape Champions, '13 Archimedes Division, '14 Chestnut Hill Champions, '14 Lenape Champions
FTC 7071 EngiNerds - Founding Advisor (2013-2014) | FRC 5420 Velocity - Founding Advisor (2015)
Grove City College Class of '18, Electrical/Computer Engineering (B.S.E.E)
Unread 28-02-2014, 23:14
FRC #4840
Thanks, here is the full code:
 Copyright (c) FIRST 2008. All Rights Reserved. */ /* Open Source Software - may be modified and shared by FRC teams. The code */ /* must be accompanied by the FIRST BSD license file in the root directory of */ /* the project. */ /*-------------------------------------------------------------------*/ package edu.wpi.first.wpilibj.templates;
 import edu.wpi.first.wpilibj.SimpleRobot;
import edu.wpi.first.wpilibj.RobotDrive;
import edu.wpi.first.wpilibj.Talon;
import edu.wpi.first.wpilibj.Timer;
import edu.wpi.first.wpilibj.Victor;
/** * * The VM is configured to automatically run this class, and to call the * * functions corresponding to each mode, as described in the SimpleRobot * * documentation. If you change the name of this class or the package after * * creating this project, you must also update the manifest file in the resource * * directory. */
public class Drive extends SimpleRobot
private RobotDrive myDrive, Shooter;
private Joystick driveStick;
private Talon FrontRight, FrontLeft, BackRight, BackLeft;
private Victor M1, M2;
/** * * This function is called once each time the robot enters autonomous * mode. */
 public void robotInit()
FrontRight = new Talon(4);
 BackLeft = new Talon(1);
FrontLeft = new Talon(3);
BackRight = new Talon(2);
myDrive = new RobotDrive(FrontLeft, BackLeft, FrontRight, BackRight);
myDrive.setInvertedMotor(RobotDrive.MotorType.kFrontLeft, true);  myDrive.setInvertedMotor(RobotDrive.MotorType.kRearLeft, true);
M1 = new Victor(5);
 M2 = new Victor(6);
Shooter = new RobotDrive(M1, M2);
driveStick = new Joystick(1);
Timer.delay(3.5);
Timer.delay(1.5);
Timer.delay(3.5);
 stopAll();
public void operatorControl() {
myDrive.setSafetyEnabled(true);
while (isOperatorControl() && isEnabled())
myDrive.arcadeDrive(driveStick);
 checkLauncherControl(); Timer.delay(0.01);
stopAll();
 private void checkLauncherControl() {
int RAISE_BUTTON = 1;
int LOWER_BUTTON = 2;
 if (driveStick.getRawButton(RAISE_BUTTON) == true)
{ startRaisingLauncher();
else if (driveStick.getRawButton(LOWER_BUTTON) == true)
{ startLoweringLauncher();
 else
{ stopMovingLauncher();
 private void stopAll()
{ myDrive.stopMotor();
stopMovingLauncher(); }
private void stopMovingLauncher()
{ setLiftPower(0);
setLiftPower(-1); }
private void startLoweringLauncher() {
 setLiftPower(0.5); }
 M1.set(-power);
M2.set(power);
Unread 28-02-2014, 23:19
FRC #4840
It did not seem too powerful when I tested it in the pits. I don't see how the power values can be different. They are set in the code at the max. I really don't understand how the same method could produce different results. Are our timer delays in the right spot?
Unread 28-02-2014, 23:32
Caleb Sykes's Avatar
Caleb Sykes Caleb Sykes is online now
FRC #4536 (MinuteBots)
Did the driving movement for autonomous work properly?
Unread 28-02-2014, 23:35
Since the motor power is a constant, it should always behave the same. I did notice you have the myDrive.setSafetyEnabled() line commented out. Sometimes the MotorSafety timing out can cause the robot to behave oddly. Do you receive any error messages at the Driver Station or Netbeans while running autonomous, and have you tried it with that line uncommented?
You could add some System.out.println()s to verify the timing. My team uses IterativeRobot, so I'm not super familiar with SimpleRobot, but the timing looks ok to me. Have you ensured that the delay values are long enough for the robot to physically respond? You cold try increasing the delay between raising and stopping the arm to see what kind of effect time has.
FRC #4840
Yes, it did pull a little to the right. But it does that regardless of what stage it's in. The timing and speed both seemed fairly accurate on the driving.
Unread 28-02-2014, 23:37
FRC #4840
Opps. That was not supposed to be commented out. It's uncommented in the actual code. It seemed like changing the delays did not have much of an effect.
Unread 28-02-2014, 23:40
Are we confident that the argument for Timer.delay() is in seconds and not milliseconds? I don't remember off hand.
FRC #4840
Hmm... I think I may have figured out the problem. Would I also need to have the setSafetyEnabled method with the shooter object and the driver object?
I feel like that is the problem. When I changed the timer delays between on shooter and off shooter, it had not effect. I wonder if the setSafetyEnabled method has anything to do with that.
Unread 28-02-2014, 23:41
FRC #4840
It should be. It's viewed as seconds in the driving portion.
Unread 28-02-2014, 23:48
I think you're right. Just making sure though, since some timer functions are measured in ms.
Unread 28-02-2014, 23:50
mwtidd's Avatar
mwtidd mwtidd is offline
AKA: mike
FRC #0319 (Big Bad Bob)
Ideally you wouldn't disable the safety enable. Now, given that you're at comp, i'm not going to suggest enabling it at this point. However, we can rearrange your code to ensure that the drive is updated enough.
Time is in milliseconds. Unlike other programming platforms, the crio really does not like long delays. Thus it's better for you to manage time, and adjust your motor outputs based on time.
        long startTime = System.currentTimeMillis();
        while(isAutonomous() && isEnabled()){
            long timePassed = System.currentTimeMillis() - startTime;
            if(timePassed < 3500){
            }else if (timePassed < 5000){
            }else if (timePassed < 8500){
            }else{
                //stopAll();
            Timer.delay(0.01);
        stopAll();
Unread 28-02-2014, 23:56
FRC #4840
            }else{
                //stopAll();
            Timer.delay(0.01);
        stopAll();
Thank you! I am a little bit confused though. You said time is in miliseconds, but it seemed like the Timer.delay worked fine with seconds with the mydrive.
Another question about the code. For the time conditions in the else statements, are the last two statements supposed to be greater than signs instead of less than signs? *Nevermind, I believe I understand this now.
Lastly, what do you think was the problem with the original code?
Unread 01-03-2014, 04:52
pblankenbaker pblankenbaker is offline
FRC #0868
pblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of lightpblankenbaker is a glorious beacon of light
Is it possible that your shooter takes more than 3.5 seconds to reach it's raised state? If it is mechanically OK to raise your shooter while you are driving you could start raising it at the start of auton at the same time as you start driving forward and let it run longer:
    // Start driving and lifting the launcher immediately
    // Stop driving after 3.5 seconds
    Timer.delay(3.5);
    // Stop raising launcher after 4.5 more seconds (8 seconds total
    // raising launcher)
    Timer.delay(4.5);
    stopAll();
You should be able to use your buttons in teleop mode to experiment with how long the total time should be in order to raise the shooter (don't assume the 8 seconds shown in the example above is the correct value).
Good Luck.
