| Thread Tools |
Rating:
Display Modes |
Propose possible fixes for high goals
So instead of just complaining about balls bouncing out of the high goals, let's work together as a community to solve this problem for FIRST. Does anyone have any proposals for how to solve this problem? Things to consider in your answer:
- effectiveness - ease of installation and removal during field setup and teardown - cost - time to implement. If it can't be implemented by week 2 competitions, it doesn't help. - aesthetics. Should blend in with the high tech look of the field and not look like something that was duct taped on at the last minute. OK, go... |
Re: Propose possible fixes for high goals
just cover the openings behind the goals and above the drivers heads. a piece of polycarbonate would do.
Our team purchased some corrugated polycarbonate at Menards for use on our robot that only cost around $45.00 for a 4'x8' sheet. This is the same material used to cover greenhouses. It is clear and would look good. From the stands, you probably wouldn't even see it.
As for attaching it...zip ties on top of the pipes would work I think. Quick and cheap. The polycarbonate is only 1/4" thick so that shouldn't affect the ball going through the goal. Cost? If the pipes are 2' apart, 3 sheets should take care of the whole field (3 half sheets per end). Total cost of around $150 per field. Seems reasonable to me. |
Is it possible to incorporate a layer of energy absorbing netting/chains far enough back from goal mouth to avoid bounce-back?
I haven't been able to watch the matches so I don't know the geometry of the problem. What is the general angle and/or velocity of shots are most likely to bounce back out? Or does it occur on a variety of shot-types? Of course, the fix needs to avoid a new set of bounce-out problems. (I'm surprised that this problem has reappeared after last year's tendency of frisbees sliding out in high-scoring matches. Regardless of game, counting goals that are scored should be very high on the "required" specs. for field design.) |
What about just a ramp that's similar to the low goal ramp? It would make the ball more likely to stay in the goal
How about astro turf or shag carpet to absorb the energy?
#7
Has first even acknowledged that they see it as an issue? As far as I'm concerned, it's just something that teams should get used to.
#8
I agree, they gave us a huge target to put a ball through this year and I think that this is a perfect challenge for teams to have to adapt strategies to.
#9
Teams need to shoot closer & up through the goal. Those w/ a flat shot from further away or are going through the upper goal on the flat hang or down arc are the only ones that will have the problem of bounce back through the opening.
Don't fix it. Deal w/ it teams, and alter your shooting, as week one matches are already underway. |
#10
It's not changed since kickoff. |
#11
I honestly don't think this is something FIRST should fix. Frisbees bounced out of the goals last year. If a ball bounces out of the goal, the team who shot it needs to adjust their shot.
#12
To all people saying teams should deal with it:
This isn't a case of a ball hitting the top and bouncing in the goal opening. This is the ball literally going in through the whole, bouncing on the piece protecting the drive team, and bouncing back out of the hole. I don't see how a team should just design around it, it's a field issue. The backing on the ultimate ascent goals were something to take into account, and it was obvious. The balls bouncing out of these goals is something that wasn't so obvious until week 1 events. It may have happened once or twice in week 0, but there was one match at palmetto where the ball went in and then bounced out 3 times in one match. I'm inclined to believe just some polycarb that is tilted at a slight angle would fix this issue entirely, and shouldn't be expensive. |
#14
Tell that to CHAOS 131, whose close, high angle, "layup" shot got stuffed by the bar probably more than a dozen times at GSDE. It was really unfortunate, because they had a great machine, but lost matches due to this field feature.
#15
Many times the ball would go through the high goal and settle resting on the bar in the rear until someone took it down. This must have been disruptive for the drivers in that station.
Also the field drawings did not reflect the bar in the back. To me this is a different challenge than what was presented and should be fixed. I helped set up the field at GSDE and can say that the polycarbonate idea would be very easy to implement. |
