Go to Post We're college students. We appreciate free. - Billfred [more]
Unread 01-03-2014, 08:13
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
Propose possible fixes for high goals
So instead of just complaining about balls bouncing out of the high goals, let's work together as a community to solve this problem for FIRST. Does anyone have any proposals for how to solve this problem? Things to consider in your answer:
- effectiveness
- ease of installation and removal during field setup and teardown
- cost
- time to implement. If it can't be implemented by week 2 competitions, it doesn't help.
- aesthetics. Should blend in with the high tech look of the field and not look like something that was duct taped on at the last minute.
OK, go...
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 01-03-2014, 08:20
Bochek's Avatar
Bochek Bochek is offline
AKA: Adam Bochek
FRC #2200 (MMRambotics)
Bochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud ofBochek has much to be proud of
Re: Propose possible fixes for high goals
just cover the openings behind the goals and above the drivers heads. a piece of polycarbonate would do.
Adam Bochek - FRC 2200
http://www.mmrambotics.com
http://www.watchfirstnow.com
Unread 01-03-2014, 08:40
Mr.Paulson's Avatar
Mr.Paulson Mr.Paulson is offline
FRC #4539
Mr.Paulson has much to be proud ofMr.Paulson has much to be proud ofMr.Paulson has much to be proud ofMr.Paulson has much to be proud ofMr.Paulson has much to be proud ofMr.Paulson has much to be proud ofMr.Paulson has much to be proud ofMr.Paulson has much to be proud of
Our team purchased some corrugated polycarbonate at Menards for use on our robot that only cost around $45.00 for a 4'x8' sheet. This is the same material used to cover greenhouses. It is clear and would look good. From the stands, you probably wouldn't even see it.
As for attaching it...zip ties on top of the pipes would work I think. Quick and cheap. The polycarbonate is only 1/4" thick so that shouldn't affect the ball going through the goal.
Cost? If the pipes are 2' apart, 3 sheets should take care of the whole field (3 half sheets per end). Total cost of around $150 per field. Seems reasonable to me.
Team #4539
2015- Lake Superior Regional #1 Captain and Semifinalist (3276 & 4845)
Quality Award Sponsored by Motorola
1st Place Junkyard Robot
2015- 10,000 Lakes Regional #3 Captain and Quarterfinalist (1816 & 3081)
2014- Lake Superior Regional #4 Captain and Semifinalist (3755 & 3277)
2013- FIRST Championship Newton Division Judges Award
Lake Superior Regional Finalists(3276 & 3277), Rookie All-Star Award, Highest Seeded Rookie Award, Most Creative Junkyard Robot Award
Team #3276
2012- Lake Superior Regional Quarterfinalist (3755 & 1816)
2011- 10,000 Lakes Regional Semifinalist (141 & 3082)
2010- 10,000 Lakes Regional Rookie Inspiration Award
Unread 01-03-2014, 08:58
James3245 James3245 is offline
FRC #3245 (Ravens)
James3245 is on a distinguished road
Is it possible to incorporate a layer of energy absorbing netting/chains far enough back from goal mouth to avoid bounce-back?
I haven't been able to watch the matches so I don't know the geometry of the problem.
What is the general angle and/or velocity of shots are most likely to bounce back out? Or does it occur on a variety of shot-types?
Of course, the fix needs to avoid a new set of bounce-out problems.
(I'm surprised that this problem has reappeared after last year's tendency of frisbees sliding out in high-scoring matches. Regardless of game, counting goals that are scored should be very high on the "required" specs. for field design.)
Unread 01-03-2014, 09:18
mschwab013's Avatar
mschwab013 mschwab013 is offline
AKA: Matt Schwabenbauer
FRC #0291
mschwab013 is a name known to allmschwab013 is a name known to allmschwab013 is a name known to allmschwab013 is a name known to allmschwab013 is a name known to allmschwab013 is a name known to all
What about just a ramp that's similar to the low goal ramp? It would make the ball more likely to stay in the goal
2013 Pittsburgh- Gracious Professionalism award, 7th seed, 6th alliance captian, quarter-finalist(291,3492,4601)
2013 Queen CIty- Chairman's Award, 39th seed
2012 Pittsburgh- 23rd seed
2012 Buckeye- 34th seed, 2nd alliance, quarter-finalist(291,1241,4085)
2011 Pittsburgh- 13th seed, 5th alliance, quarter-finalist(291,337,3504)
2011 Buckeye- 18th seed, 8th alliance, quarter-finalist(279,291,3496)
2010 Finger Lakes- 15th seed, 5th alliance, quarter-finalist(291,1507,1559)
2010 Buckeye- Chairman's Award, Imagery Award, Quality Award, 4th seed, 1st pick, 1st alliance, semi-finalist(291,1014,1629)
Unread 01-03-2014, 12:41
idahorobot's Avatar
idahorobot idahorobot is offline
FRC #2130 (Alpha +)
idahorobot is a jewel in the roughidahorobot is a jewel in the roughidahorobot is a jewel in the roughidahorobot is a jewel in the rough
How about astro turf or shag carpet to absorb the energy?
Unread 01-03-2014, 15:38
eddie12390's Avatar
eddie12390 eddie12390 is offline
AKA: Eddie
FRC #3260 (SHARP)
eddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of lighteddie12390 is a glorious beacon of light
Has first even acknowledged that they see it as an issue? As far as I'm concerned, it's just something that teams should get used to.
Unread 01-03-2014, 15:56
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
I agree, they gave us a huge target to put a ball through this year and I think that this is a perfect challenge for teams to have to adapt strategies to.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 01-03-2014, 16:29
cglrcng cglrcng is offline
FRC #0060
cglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond reputecglrcng has a reputation beyond repute
Teams need to shoot closer & up through the goal. Those w/ a flat shot from further away or are going through the upper goal on the flat hang or down arc are the only ones that will have the problem of bounce back through the opening.
Don't fix it. Deal w/ it teams, and alter your shooting, as week one matches are already underway.
Unread 01-03-2014, 16:51
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
- effectiveness
- cost
OK, go...
Can we add: Leave it as is.
It's not changed since kickoff.
___________________
- Tennyson, Ulysses
Unread 01-03-2014, 17:43
wesbass23 wesbass23 is offline
FRC #1732 (Hilltopper Robotics)
wesbass23 has much to be proud ofwesbass23 has much to be proud ofwesbass23 has much to be proud ofwesbass23 has much to be proud ofwesbass23 has much to be proud ofwesbass23 has much to be proud ofwesbass23 has much to be proud ofwesbass23 has much to be proud ofwesbass23 has much to be proud ofwesbass23 has much to be proud of
I honestly don't think this is something FIRST should fix. Frisbees bounced out of the goals last year. If a ball bounces out of the goal, the team who shot it needs to adjust their shot.
Unread 02-03-2014, 07:53
Curt Henderson's Avatar
Curt Henderson Curt Henderson is offline
FRC #1501 (Team T.H.R.U.S.T)
Curt Henderson is a jewel in the roughCurt Henderson is a jewel in the roughCurt Henderson is a jewel in the rough
Send a message via Yahoo to Curt Henderson
- effectiveness
- cost
OK, go...
Ok here is my idea for a simple quick fix. Use 1/16" thick polycarbonate cut into 4" wide x 12" long strips. Bend them at 4" on the 12 " length to 45 degrees. Now screw them(on the 4" face) to the back of the goal wall along the top of the opening so the remaining 8" is hanging down towards the goal opening. These will be very flexible when the ball hits them as it is scored yet be very durable when the ball tries to bend them backwards. These fingers could be added every 12" along the goal opening to minimize the field modification time.
Unread 02-03-2014, 08:05
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
To all people saying teams should deal with it:
This isn't a case of a ball hitting the top and bouncing in the goal opening. This is the ball literally going in through the whole, bouncing on the piece protecting the drive team, and bouncing back out of the hole. I don't see how a team should just design around it, it's a field issue. The backing on the ultimate ascent goals were something to take into account, and it was obvious. The balls bouncing out of these goals is something that wasn't so obvious until week 1 events. It may have happened once or twice in week 0, but there was one match at palmetto where the ball went in and then bounced out 3 times in one match.
I'm inclined to believe just some polycarb that is tilted at a slight angle would fix this issue entirely, and shouldn't be expensive.
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
Unread 02-03-2014, 08:34
Brandon Zalinsky's Avatar
Brandon Zalinsky Brandon Zalinsky is offline
Roaming GeorgiaFIRST MC
AKA: The Mecanum Man
FRC #1058 (PVC Pirates)
Brandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant futureBrandon Zalinsky has a brilliant future
Tell that to CHAOS 131, whose close, high angle, "layup" shot got stuffed by the bar probably more than a dozen times at GSDE. It was really unfortunate, because they had a great machine, but lost matches due to this field feature.
This is our Robot. There are many like it, but this one is ours.
Measure twice, cut once, curse, buy more, and cut again.
2014- Excellence in Engineering (UNH), District Chairman's Award (NU), #8 Quarterfinalist (NECMP), Winner (Mainely Spirit)
2013- Semifinalists (Battlecry@WPI) Winner (Mainely Spirit)
2012- Regional Chairman's (GSR), Finalists as the #11 Alliance Captain (Battlecry@WPI)
2011-Xerox Creativity Award (GSR), Semifinalists (GSR) Innovation in Control (Virginia)
2010-Champion (GSR), Undefeated (Chesapeake), Coopertition Award (Chesapeake), Quarterfinalists (Galileo) 8th AC (IRI)
2008-Undefeated (GSR), Xerox Creativity Award (GSR)
Unread 02-03-2014, 09:05
kstl99's Avatar
kstl99 kstl99 is offline
AKA: Kevin
FRC #1922 (Oz-Ram)
kstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond reputekstl99 has a reputation beyond repute
Send a message via AIM to kstl99
Many times the ball would go through the high goal and settle resting on the bar in the rear until someone took it down. This must have been disruptive for the drivers in that station.
Also the field drawings did not reflect the bar in the back. To me this is a different challenge than what was presented and should be fixed.
I helped set up the field at GSDE and can say that the polycarbonate idea would be very easy to implement.
