Go to Post I like how we're trying to save weight when we came in at 95 pounds. - Chris is me [more]
Unread 17-02-2003, 23:59
duckshepherd's Avatar
duckshepherd duckshepherd is offline
FIRST Veteran
AKA: Jeremy Egger
FRC #0959
duckshepherd is an unknown quantity at this point
Send a message via AIM to duckshepherd Send a message via MSN to duckshepherd Send a message via Yahoo to duckshepherd
Question Pressure Switch to Relay?
The other posts about the pressure swithes didn't really clear up how the heck you hook up the pressue switch to a relay. I think I understand how to ground the pressure switch, but how do I hook the other end to a relay? What I assume is that you ground the switch to a fuse box, but how the other end is hooked up to a relay, I don't get it. Unless you hook up the whole thing to a spike... that would solve the relay problem. I just don't know! Please help!
-Jeremy Egger
Freshman-"Could you hand me that thing that makes that clickety noise when you turn it?"
Senior-"You mean the ratchet?"
No, I refuse. Wait, what? Did you say chicken and cheese? Alright then...
spike for pressure switch? Rob Colatutto Rules/Strategy 4 23-02-2003 15:42
pressure switch Michael Long Pneumatics 1 11-02-2003 11:21
pressure switch Antonio Pneumatics 10 31-01-2003 03:52
NEED HELP with Delay loop for compressor relay switch archiver 2001 10 24-06-2002 02:11
Error found in programming for the pump and pressure switch sjharobotics Programming 4 06-02-2002 17:46
