| Thread Tools |
Rating:
Display Modes |
#61
Re: New Central Illinois Regional Looking Good!
Attached are the stats from today's matches. A couple notes: these stats are to supplement our qualitative data from our Scouting Team, so it is not expected to be a complete picture of teams. We scouting every alliance for every match. I do not think there are any errors is compiling the data but I'm sure there are a couple mistakes in the raw data (especially in matches were there were multiple missed autonomous balls). We did not re-scout the two replay matches.
2014_Central_Illinois_Stats.xlsx |
#62
Not sure if FIRST regional or battlebots competition...
#63
Can anyone tell me what happened in the last match/Finals-3? Ustream went belly-up toward the end of the timeout and all I know is the score.
#64
Alliance 1 won by 20. I think it was 112-92. 3 or 4 flipped bots in the last 2 matches.
#65
Red won.
#66
From the stands it looked like one of the referees called intentional tipping on 4296, but it must have been reversed after the match.
Incredibley rough finals matches, I haven't seen so much defense since 2007. |
#67
I'd mirror Ryan's comments. The play in the elimination matches was the roughest I've ever seen allowed by a head referee in my 9 years of FIRST. Some calls were definitely not being made correctly. The whole event contact inside the frame perimeter wasn't being called even with several instances of obvious damage to our bot. CIR was otherwise a strong event with great teams. I'll be curious to see how things change as we move into district play.
#68
So, was it rough or dirty? There is a difference.
#69
IMO, it was rough. But if you were the one getting tipped, you may not see it that way.
#70
Depends on your definition of dirty. In our last elimination match, both of our lift cylinders were bent and one of the pneumatic fittings on our shooter was sheared off. None of these parts extend outside our frame perimeter, but no fouls were called. However, I don't think the bots that hit us were trying to damage us, it was just the way things at CIR were being played.
The lack of fouls for damaging opposing robots, coupled with the fact that the finals matches basically turned into a bot flipping contest, has left me worried about how the rest of the season is going to play out. I saw a number of fairly well built robots take pretty significant damage, and having your robot destroyed on the field is pretty disheartening for any team. Last edited by Sparky3D : 01-03-2014 at 20:08. |
#71
G28 was never called. ![]() ![]() |
#72
#73
We immediately took the robot to the question box and showed the damage. The refs said that they did not see the damage happen so they couldn't call it. |
#74
I think that the teams in the Finals should be held to highest standards of penalties because they have already played 8-12 matches. |
#75
For the most part those elims were very rough...I wouldn't say that they were 100% clean either.
There was a technical given in the final match for intentional tipping when 4143 was tipped over. This technical had no affect on the outcome of the match so it wasn't announced. In general contact inside the frame perimeter was not being called because the damage was not obvious at the time the contact occurred. Given the other threads on CD discussing the refs being overwhelmed it is also likely the refs were watching the human players ensuring they remained safe and didn't cross the plane of the field. They were also often interacting with there referee panel to keep track of assists and scored balls so there eyes weren't on the robot the entire time. |
