Go to Post I don't care what the team numbers said, on Friday there were no rookies there. - Taylor [more]
Unread 01-03-2014, 22:39
tophkissane tophkissane is offline
FRC #1493
tophkissane is an unknown quantity at this point
Java Gyro help
We are using a field-centric drive system this year with mecanum wheels. In autonomous we want to start with the side of the robot facing down field so instead of restarting the gyro we want it to start at 90 degrees. I am having trouble figuring out how to do this though. Any help is much appreciated
Unread 01-03-2014, 22:45
Re: Java Gyro help
Just zero it, then add 90 degrees to the value you read from the gyro.
