Go to Post Hundreds of teams. Thousands of students. Countless memories. Infinite fun. You'll love it, I promise you that. - smurfgirl [more]
Unread 01-03-2014, 18:07
bbradf44's Avatar
bbradf44 bbradf44 is offline
AKA: Brad
FRC #3344 (Robocopz)
Team Role: Driver
bbradf44 is just really nicebbradf44 is just really nicebbradf44 is just really nicebbradf44 is just really nice
Variable thrower
We have a motor driven thrower arm driven by a 2 cim gearbox on jags. We are trying to make it so a camera of some sort reads the distance and adjusts the power of the thrower accordingly. How would we go about doing that in both electrical and programing?
We have an axis camera, kinect, rasbery pi(were not entirely sure how to legally use it so instructions for that would be helpful as well) and an encoder on the gearbox running the thrower
2011: FRC 1922 Team Member
2012 (Build weeks 1-3): FRC 1922 Team Member
2012 (Weeks 4-Competition): FRC 3344 Mechanic and Pit Crew
2013: FRC 3344 Mechanical Lead and Head Driver
2014: FRC 3344 Team Captain and Head Driver
Record as driver: 7-11-0 and Proud of it
Unread 01-03-2014, 19:09
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Re: Variable thrower
My understanding of how a camera distance sensing works:
1. Use a light to light up the retro reflective material.
2. Use camera and software to detect and measure the size of the retro reflective material
3. use this data to triangulate your distance
OR I suggest you use an ultrasonic sensor
The process
1. mount sensor high
2. read voltage from signal
3. use calibration factor to know how far you are.
These sensors are pretty darn accurate.
I would find another supplier than robotmarketplace because of ship time, but other than that, this is a great sensor.
OR
Create a mechanism with the so called "sweet-spot" so that you can use the same power, but score from many locations with the same exact shot pattern.
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 01-03-2014, 19:41
rwkling1's Avatar
rwkling1 rwkling1 is offline
FRC #2977 (Sir Lancer Bots)
rwkling1 has a spectacular aura aboutrwkling1 has a spectacular aura about
I would say (like Jeffy did above), make a sweet spot for your shooter, I realize you guys made this device so you can shoot from multiple places, but you can get the same effect by creating a good arc from your ball. It simplifies everything and yet is very effective
Unread 01-03-2014, 21:56
bbradf44's Avatar
AKA: Brad
Team Role: Driver
Because of weather we actually created our thrower in our 45lb withholding allowance. We weren't expecting to be able to vary the power but after finishing and testing today we found it has far more speed and power than we thought. Do you know of any way we can use a kinect and rasbery pi?
Unread 01-03-2014, 22:23
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
It'd be hard to put together quickly.....when's your first regional?
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 01-03-2014, 22:27
bbradf44's Avatar
AKA: Brad
Team Role: Driver
We have until Peachtree. I wasn't sure if we would be able to pull it off but we have some very skilled programmers and Linux guys so I figured it was worth a shot. We also need to know how to get the pi to communicate with the crio legally
Unread 01-03-2014, 22:31
bbradf44's Avatar
AKA: Brad
Team Role: Driver
We are also planning to use a different laptop for our driver station so if it would be easier to put our classmate on the robot and do it that way we can look into that. I don't know how to do that legally either though. This is the first time my team has experimented with raspi or on board computers for processing
Unread 01-03-2014, 22:38
geomapguy's Avatar
Centenary '18
AKA: Graham Maxwell
FRC #1818
You could have the pi send I2C(not sure if Pi does this), analog voltage proportional to a distance or even use DIO to use timing and see how long the time between pulses is (similar to what a true ultrasonic does)..
many options....I'm not too good with network tables but you could also use network tables as an option..
EDIT: and yes you could put your classmate on the robot
Unread 01-03-2014, 22:42
bbradf44's Avatar
AKA: Brad
Team Role: Driver
How would we put the classmate on the robot? Is there a paper or something I can go to where it explains it in detail?
Unread 01-03-2014, 22:46
geomapguy's Avatar
Centenary '18
AKA: Graham Maxwell
FRC #1818
Not sure but if you want to do RPi processing....I think Yash101 has created code to determine distance to the retroflective tape
http://www.chiefdelphi.com/media/photos/39569
Driver side code might be a bette roption
Unread 01-03-2014, 22:51
Jeffy's Avatar
Retired, for now
AKA: Jeff Gier
Using camera (or kinect) vision is seriously over complicating this problem. You only need to know distance to the wall. So, don't use something designed to give you distance, shapes and color.
If you are going for the hot goals though, vision could be helpful. I bet you could detect them without it though.
2010 GKC Finalists
2010 OKC Champions
2012 CO Finalists
Unread 01-03-2014, 22:53
geomapguy's Avatar
Centenary '18
AKA: Graham Maxwell
FRC #1818
*cough* kinect *cough*
Unread 01-03-2014, 22:54
bbradf44's Avatar
AKA: Brad
Team Role: Driver
All I need is distance to the wall. But we don't have funds to get a fancy range sensor so we were thinking we could get that data from the kinect. We actually don't need any video at all
Unread 01-03-2014, 22:55
Jeffy's Avatar
Retired, for now
AKA: Jeff Gier
I don't get it. The kinect is surely an option. But as I said, I think it is a more complex solution than is needed.
Are we having a conversation, or are we just saying words?
The sensor is not "fancy" by any means of its implementation. And some ultrasonic sensors cost as little as 5 dollars.
2010 GKC Finalists
2010 OKC Champions
2012 CO Finalists
Unread 01-03-2014, 23:09
geomapguy's Avatar
Centenary '18
AKA: Graham Maxwell
FRC #1818
You don't have to use the kinect in a complex situation for hot goal detection...you can just use human eyes
And yes many teams forget that we got a $35 voucher to a sonar sensor company...maxbotix
