Go to Post Think about the other teams...today your opponent, today your teammate. - Al Skierkiewicz [more]
Unread 01-03-2014, 23:14
pfreivald's Avatar
AKA: Patrick Freivald
Re: Variable thrower
Don't forget that the best sensors for teleop belong to the driver. Make one or more shots with the biggest sweet spot you can, and then take advantage of the multiple buttons on your joystick/controller--and then train, train, train your driver!
Patrick Freivald -- Mentor
Team 1551
"The Grapes of Wrath"
I write books, too!
Unread 01-03-2014, 23:15
bbradf44's Avatar
bbradf44 bbradf44 is offline
AKA: Brad
FRC #3344 (Robocopz)
Team Role: Driver
bbradf44 is just really nicebbradf44 is just really nicebbradf44 is just really nicebbradf44 is just really nice
Originally Posted by Jeffy View Post
I don't get it. The kinect is surely an option. But as I said, I think it is a more complex solution than is needed.
Are we having a conversation, or are we just saying words?
The sensor is not "fancy" by any means of its implementation. And some ultrasonic sensors cost as little as 5 dollars.
Where can we get one for that cheap and does it work well? And with shipping time will we get it in time?? I completely forgot we had a voucher. I'll look into that. How do we program it and hook it up? You guys are very helpful
2011: FRC 1922 Team Member
2012 (Build weeks 1-3): FRC 1922 Team Member
2012 (Weeks 4-Competition): FRC 3344 Mechanic and Pit Crew
2013: FRC 3344 Mechanical Lead and Head Driver
2014: FRC 3344 Team Captain and Head Driver
Record as driver: 7-11-0 and Proud of it
Unread 01-03-2014, 23:21
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
Find the maxbotix voucher in your kit..
It's for $35... The EZ1 (best option is like $30)...shipping will cost you like $6...should get it in at most 5 days...
It wires into the analog module...then just read the voltage and scale of accordingly...what language are you guys using?
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 01-03-2014, 23:23
Jeffy's Avatar
Jeffy Jeffy is offline
Retired, for now
AKA: Jeff Gier
FRC #2410 (Metal Mustang Robotics) #159 (Alpine Robotics)
Jeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant futureJeffy has a brilliant future
Ill let you search for a sensor you like yourself.
But i can give you a starting point on how to utilize a sensor.
-Supply a voltage to the sensor (5volts or 3.3 volts most of the time).
-Read the voltage from the sensor using an input in the digital sidecar
-Use a calibration factor (should be in the manual for the sensor) to convert the voltage to distance
The programming is simple, but different for every language. I'm sure a small search would yield a tutorial for programming sensors in your language of choice.
Good luck!
Metal Mustang Robotics 2410 (2008-2011)
2008 STL Rookie All-Star
2010 GKC Finalists
2010 OKC Champions
Alpine Robotics 159 (2012-)
2012 CO Finalists
700 miles from home, 2 miles from FRC. Life is good.
Unread 01-03-2014, 23:25
geomapguy's Avatar
Centenary '18
AKA: Graham Maxwell
FRC #1818
Good luck!
Analog breakout not digital sidecar unless they plan on using a pulsing (ping/return) ultrasonic.
Unread 01-03-2014, 23:28
bbradf44's Avatar
AKA: Brad
Team Role: Driver
Thanks for the help! I believe we are using c++. Do we connect the sensor to a transformer to get the 5v?
Unread 01-03-2014, 23:30
geomapguy's Avatar
Centenary '18
AKA: Graham Maxwell
FRC #1818
So if you get a Maxbotix Analog Sonar...
5V goes to + on breakout
Gnd goes to - on breakout
AN goes to SIG on breakout
and the code should be as easy as reading the analog voltage and then scaling the returned value..
Unread 02-03-2014, 17:27
bbradf44's Avatar
AKA: Brad
Team Role: Driver
We've decided on going with a maxbotics sensor. I'm not extremely knowledgeable in this field though. We are trying to sense distance to the wall and, if possible, ignore other robots that may be in range. Which sensor would you guys recommend?
