Go to Post We try to limit ourselves only by physics. As the first person on the planet to communicate over a quantum encrypted AOL instant messenger session, I try to ignore those limits as well. - EricVanWyk [more]
Unread 02-03-2014, 10:32
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: Propose possible fixes for high goals
Originally Posted by Anupam Goli View Post
To all people saying teams should deal with it:
This isn't a case of a ball hitting the top and bouncing in the goal opening. This is the ball literally going in through the whole, bouncing on the piece protecting the drive team, and bouncing back out of the hole. I don't see how a team should just design around it, it's a field issue. The backing on the ultimate ascent goals were something to take into account, and it was obvious. The balls bouncing out of these goals is something that wasn't so obvious until week 1 events. It may have happened once or twice in week 0, but there was one match at palmetto where the ball went in and then bounced out 3 times in one match.
I'm inclined to believe just some polycarb that is tilted at a slight angle would fix this issue entirely, and shouldn't be expensive.
Originally Posted by kstl99 View Post
Many times the ball would go through the high goal and settle resting on the bar in the rear until someone took it down. This must have been disruptive for the drivers in that station.
Also the field drawings did not reflect the bar in the back. To me this is a different challenge than what was presented and should be fixed.
I helped set up the field at GSDE and can say that the polycarbonate idea would be very easy to implement.
It was in the original drawing of the field.
All teams have to deal with this issue, so it is fair. I suggest, instead of wasting energy complaining about it, work to figure out a way so that your robot is less affected by it.
Griping about a field element that has been in the drawings since kickoff is wasted energy IM(NS)HO.
___________________
- Tennyson, Ulysses
Unread 02-03-2014, 10:59
MrBasse MrBasse is offline
FRC #3572 (Wavelength)
MrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond reputeMrBasse has a reputation beyond repute
It's definitely a field issue, however, it is one that a lot of teams didn't notice until now. It sounds like a lot of teams missed a crucial part of the design process. Who's fault is that?
Snip
Snip
Been there since day one on the Official Field Drawings...
This isn't really a big deal. In every sporting event there are challenges. They don't stop a baseball game because it is windy, batters just try to keep the ball low to avoid the wind. Same in football, soccer, or any sport played outside...
Adjust your shot, modify your strategy, play the game you were given.
Andrew Basse
Coach - FRC Team 3572 - Wavelength
Unread 02-03-2014, 11:10
Jibri Wright's Avatar
Jibri Wright Jibri Wright is offline
FRC #1781 (Electric Eagles)
Team Role: CAD
Jibri Wright will become famous soon enough
I think it's totally fair. It's just all part of the design challenge. It probably is hard to change the trajectory of a catapult and do all the math associated with it, but that's one of the reasons why we didn't design a catapult.
You know someone likes something when after doing it a million times, they still marvel at it as if it was the FIRST.
Greatness asks how can I make it better. Genius asks how can I make it different.
Unread 02-03-2014, 14:13
S.P.A.M.er 17's Avatar
S.P.A.M.er 17 S.P.A.M.er 17 is offline
Mentor (4118), Alumni (180)
AKA: Ralph,Ralf,Raph(I can't spell)
FRC #4118 (Roaring Riptide)
S.P.A.M.er 17 has a reputation beyond reputeS.P.A.M.er 17 has a reputation beyond reputeS.P.A.M.er 17 has a reputation beyond reputeS.P.A.M.er 17 has a reputation beyond reputeS.P.A.M.er 17 has a reputation beyond reputeS.P.A.M.er 17 has a reputation beyond reputeS.P.A.M.er 17 has a reputation beyond reputeS.P.A.M.er 17 has a reputation beyond reputeS.P.A.M.er 17 has a reputation beyond reputeS.P.A.M.er 17 has a reputation beyond reputeS.P.A.M.er 17 has a reputation beyond repute
If nothing is going to be changed about the bar, then things need to change about how cycles are ended. Refs should be able to undo cycles since the ball is literally bouncing out of the goal after it appears to be scored. Maybe have another set of lights on the human barrier station so if the cycle is undone, the human players can't inbound until those lights are lit as well. As a ref, I will not want to cause a field fault due to unscoring balls, but I also want to make sure that the next cycle is started as soon as possible. Honestly, this bar seems more unfair to refs, than to the robots.
Doing stuff for robots: just as hard as doing robot stuff.
Unread 02-03-2014, 15:50
Team Role: CAD
Even if the bar was deemed unfair by the GDC itself, nothing would be done about it, and it's not mainly because of money. The main problem is that in the week one events, the teams who participated had to deal with the bar. Changing that bar is not fair to them. If they had to deal with it, it's more fair that everyone else has to deal with it as well. They had to adjust and so do we, simple as that.
Unread 02-03-2014, 15:54
Nirvash's Avatar
Nirvash Nirvash is offline
AKA: Bryan
FRC #4676
Nirvash has a spectacular aura aboutNirvash has a spectacular aura about
I guess FIRST has never changed the field elements throughout the season before.
Team 3488 - Electrical Lead/Programming Lead 2011-2013
Team 4676 - Electrical/Programming Mentor 2013-Present
Unread 02-03-2014, 15:57
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Why would they not change the rules? They've done it before.
___________________
- Tennyson, Ulysses
Unread 02-03-2014, 16:00
Team Role: CAD
It's not a rule, it's a field element.
Unread 02-03-2014, 16:05
mott's Avatar
mott mott is offline
AKA: Mike Ott
FRC #1619 (Up-A-Creek Robotics)
mott is on a distinguished road
FIRST has changed field elements before also... this whole discussion sounds remarkably like the discussion early in 2012 when basketballs wouldn't roll out from under the bridges.
Then, FIRST made a change to the way they attached the polycarb ball ramps to the underside of the bridge assembly (if I remember correctly).
dag0620 dag0620 is offline
Because we're FiNE
AKA: David Givens
FRC #1071 (Team MAX)
dag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond reputedag0620 has a reputation beyond repute
Also about the bar...
Even if FIRST wanted to, let's think about the logistical nightmare of getting the materials to fix the fields out to all the events. This weekend alone, there were 11 fields deployed across the U.S. and Canada, and there's certainly more fields then that. Once fields leave HQ, they don't return until the end of the season. So for a fix to happen, the materials would have to be shipped all over the place. While this could be done, I'd be willing to be HQ would try to avoid it as much as possible.
Edit: Not saying it can't be done, or hasn't been done (I do remember 2012), just making sure people are aware of the logistics of making the change happen.
David Givens
Alumnus Team Max 1071 ('13) | FIRST Volunteer | NE FIRST
Away making magic for a bit...
Unread 02-03-2014, 16:06
Thad House Thad House is online now
Volunteer, WPILib Contributor
no team (Waiting for 2021)
They've changed the field before too. Remember in 2012 they changed the polycarb under the bridges after balls would get stuck under them, so only certain robots could pick them up. I'm pretty sure this was between week 1 and week 2.
Team 4488 - Mentor 2013-2016
Unread 02-03-2014, 16:17
atucker4072's Avatar
atucker4072 atucker4072 is offline
Andrew Tucker
AKA: Andrew Tucker
FTC #4968 (Rapid Robotics)
atucker4072 has a spectacular aura aboutatucker4072 has a spectacular aura aboutatucker4072 has a spectacular aura about
Honestly if it becomes a larger issue, more than refs trying to keep score and what have you, they could probably just use cardboard... I don't think it had made that big of an impact YET.
Unread 02-03-2014, 16:19
GaryVoshol's Avatar
Cogito ergo arbitro
Is having to replay a match a big impact? A match in eliminations?
(since 2004)
Unread 02-03-2014, 16:25
Woolly's Avatar
Woolly Woolly is offline
Programming Mentor
AKA: Dillon Woollums
FRC #1806 (S.W.A.T.)
Woolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond reputeWoolly has a reputation beyond repute
Maybe instead of a metal bars it should be chain (of a sturdier variety than 2013 chain) with pool noodle around it.
Team 1806 Student: 2012-2013 | Mentor: 2013-Present
Unread 02-03-2014, 16:36
Qbot2640's Avatar
Qbot2640 Qbot2640 is offline
AKA: Terry McHugh
FRC #2640 (Hotbotz)
Qbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond reputeQbot2640 has a reputation beyond repute
Why would this result in a match being replayed? Currently, if the ball bounces back out it is not a goal. It is quite clear. - if a referee or other official interpreted a "bounce out" as a reason to replay a game, then they have not followed the current rule.
This bounce potential may negatively impact my team's shot - but that doesn't change the fact that it would still be more unfair to modify now than to continue to work as is...We may modify our approach and make it a non-issue, but that is why we don't register for week one events!
2012 Palmetto Regional Winners (Thanks 2059, 2815, and 287).
2012 Newton 14th Seed
2013 Chesapeake Regional Imagery Award Winners
2014 North Carolina Regional Imagery Award Winners
2014 Greater DC Regional Team Spirit Award Winners
2015 North Carolina Regional Finalists (Thanks 3971 and 587)
