Go to Post Whatever you do, make it idiot-proof. Not because your drivers are idiots, but because the fewer precision maneuvers they have to do, the more awesome driving (and scoring!) they have time to do. - Ian Curtis [more]
Unread 02-03-2014, 14:13
shades23's Avatar
shades23 shades23 is offline
AKA: Christian
FRC #0175 (Buzz)
shades23 is an unknown quantity at this point
Watch Dog Not Fed...
Any help?
Unread 02-03-2014, 14:17
jmartin jmartin is offline
AKA: Joseph Martin
FRC #0172 (Northernforce)
jmartin is on a distinguished road
Re: Watch Dog Not Fed...
Can you give more information? What language are you using, when does it happen, etc.
Unread 02-03-2014, 14:19
shades23's Avatar
AKA: Christian
FRC #0175 (Buzz)
Java happens almost every time we run the whloe robot seems to drop comm.. compresser "flickers" as does the drive and everything else
Unread 02-03-2014, 14:21
PandaHatMan's Avatar
PandaHatMan PandaHatMan is offline
AKA: Wallpe
FRC #1747 (Harrison Boiler Robotics)
PandaHatMan is an unknown quantity at this point
Check for wireless interference. It may help to move your D-Link to somewhere else on your bot.
Unread 02-03-2014, 14:22
Michael Hill's Avatar
Does it happen when tethered directly to the cRio? directly to the d-link? wireless?
Unread 02-03-2014, 14:23
shades23's Avatar
AKA: Christian
FRC #0175 (Buzz)
Happens when we run wireless
Unread 02-03-2014, 14:26
Chris_Ely's Avatar
Chris_Ely Chris_Ely is online now
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
Is your router located away from things like motors, power converters, and metal?
Is the router wired as shown in this diagram?
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 02-03-2014, 14:37
AKA: Wallpe
Most likely positioning of router.
Also, make sure your router is powered by the transformer plugged into the 12V port on the bottom of the PD board. Most teams don't know this, but that port on the bottom of the PD board will provide a constant supply of 12V until the battery is around 4V or lower.
Unread 02-03-2014, 16:09
If it is system WD errors you are seeing, I'd flip to the Charts tab where you can view packet loss and latency. You can post a photo of the chart if it doesn't make sense.
You should be able to use this to compare different mounting options and different settings of the radio.
Greg McKaskle
Unread 02-03-2014, 16:31
mega900997's Avatar
mega900997 mega900997 is offline
FRC #0263 (Sachem Aftershock)
mega900997 is on a distinguished road
Honestly, I would just disable watchdog. I haven't gotten it 'fed' enough and its just easier to not deal with it. As far as I know, there is no difference in not having watchdog. I haven't used it for the year's I have been a programmer and the programmer before me hasn't either.
If there is a benefit to having watchdog enabled or a disadvantage to having it disabled, would someone please tell me?
Suffield Shakedown Winners & Most Points Scored
South Florida Regional 6th Seed, #5 Alliance Captains, Regional Winners w/ 2383 & 386, Innovation in Control Award
NY Tech Valley Regional 5th Seed, QF, Excellence in Engineering Award
SBPLI Long Island Regional 4th Seed, Finalists
Hopper Division 14th Seed, QF
Unread 02-03-2014, 16:51
I deleted the portion of my post about the User Watchdog errors. It is off by default and I assumed that you were probably talking about System ones.
The System WD cannot be turned off. It is one of the primary safety features. Code on the robot cannot control outputs unless the DS is in relatively consistent communication with the robot.
Greg McKaskle
