Go to Post You can expect to see the the same old same old again this weekend! Another set of fantastic experiences for thousands of kids across the country. And once again, Mission Accomplished. - Aidan F. Browne [more]
Unread 17-02-2014, 17:01
Sh1ine Sh1ine is offline
FRC #2791
Sh1ine is on a distinguished road
3D Printed Ball Shifter Pneumatic Coupler
I know teams have been posting pictures of Shiftier Couplers that they have 3d printed. Is an ABS print holding up to the pressure of the system? The snap rings in our shiftier shaft keep failing. I would like to step up to a bigger bearing with a full snap ring, but I can't do that unless the 3d printers work for this application. What are teams finding out in the testing of these parts?
Has anyone had issues with the snap rings besides us? What have you done to remedy the situation?
Thanks in advance.
Unread 18-02-2014, 10:52
Brian_R Brian_R is offline
FRC #3710 (The Cyber Falcons)
Brian_R is a jewel in the roughBrian_R is a jewel in the roughBrian_R is a jewel in the roughBrian_R is a jewel in the rough
Re: 3D Printed Ball Shifter Pneumatic Coupler
We've been using a 3D printed coupler to use 2 pancake cylinders to shift our winch. So far, so good - I'd call it in the neighborhood of 150 shots? no signs of wear that I've seen.
Ours were printed on a Dimension BST printer in ABS - other printers and materials may not be as robust. The CAD was by user tag_groff of 4265.
Unread 02-03-2014, 19:11
Rstrzelecki Rstrzelecki is offline
FRC #0135 (The Black Knights)
Rstrzelecki is an unknown quantity at this point
At first we 3D printed a new one out of abs to fit the 1 1\16 bore cylinder we wanted to use but after about a day of use it blew out and we have since been using an aluminum one that threads on the the cylinder and is slotted to allow the bearing to slide in.
Unread 02-03-2014, 19:18
audietron's Avatar
audietron audietron is offline
Red for mediocre performance
AKA: Grayson Burgess
FRC #0965 (X3 Robotics)
audietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to beholdaudietron is a splendid one to behold
We were having problems with a 3d printed coupler so we designed a bearing block style coupler for 1-1/16 bore cylinder and have not had a problem yet. The bearing is now half inch OD and we use the same snap rings without a problem.
2015: Galileo Semifinalists
2015: North Star Regional Finalists (Thanks to 5576 and 2531)
2014: North Star Semifinalist (Thanks to 2175 & 4607)...again
2014: Central illinois Semifinalist (Thanks to 1756 & 1288)
2013: North Star regional Winner (Thanks to 2175 & 4607)
2013: Curie Semifinalist (Thanks to 2056 & 3990)
2013: IRI Semifinalist (Thanks to 359, 1477, & 148)
