Go to Post Don't you just wish life had a redo button? - DHarris [more]
Unread 02-03-2014, 21:40
JTEarley JTEarley is offline
AKA: JT E.
FRC #0624 (CRyptonite)
JTEarley is an unknown quantity at this point
Re: Game piece inflation
They were very much over inflated at Alamo on Thursday, and after many complaints, the balls were slightly deflated during lunch and they were fine throughout the event.
Unread 02-03-2014, 22:29
Jim Wilks Jim Wilks is offline
Electrical Engineer
AKA: Jim Wilks
FRC #1360 (Orbit Robotics)
Jim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond reputeJim Wilks has a reputation beyond repute
GTRW had a ball sizing ring. It was 25" in diameter and came with the field. I'm assuming other regionals had one as well. Was it being used?
Jim
Unread 02-03-2014, 22:33
Racer26 Racer26 is offline
Originally Posted by Jim Wilks View Post
GTRW had a ball sizing ring. I'm assuming other regionals had one as well. Was it being used?
If there was a ring to be used, why wasn't its size shared with teams weeks ago such that we could test robots accordingly? The inflation level of the balls completely changes how they fly from some shooter designs and changes the intakes too.
Unread 03-03-2014, 11:15
Back @ it again with the white vans
AKA: Brandon Liatys
FRC #2180 (Zero Gravity)
Officially, the balls are inflated to the point where they look about right and thats it.
Although I agree there should be a sizing box 100%, this is the first I'm hearing of it being actually used.
+1 GTRW Crew
Unread 03-03-2014, 11:43
+1 GTRW Crew
The problem though, is that many teams at GTRW had to rework their intakes and shooters as the balls at GTRW seemed to be overinflated by the official inflation method provided to teams at kickoff.
Unread 03-03-2014, 11:50
notmattlythgoe's Avatar
Flywheel Police
AKA: Matthew Lythgoe
FRC #2363 (Triple Helix)
+1 GTRW Crew
There was a sizing box used for Logomotion . Unfortunately it didn't help because people were still inflating the tubes until they were overflowing from the box and were bigger than most teams expected.
Unread 03-03-2014, 12:22
Electrical Engineer
AKA: Jim Wilks
The sizing ring had a hole exactly 25" in diameter. When a few teams at GTRW complained about the ball sizes, they were checked and a few were found to be oversized. Those ones were deflated.
Some teams cam by and used the sizing ring on their practice balls as well.
The ring went in the robot inspectors case.
Jim
Unread 03-03-2014, 12:26
Patrick Flynn Patrick Flynn is offline
Patrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond reputePatrick Flynn has a reputation beyond repute
Does anyone else think that a sizing box is not the way to go here? We have no idea the tolerances that these balls are designed at. If the balls are +/- .5in a sizing box would lead to over and under inflated balls, and then everyone would be complaining about that.
I think there is a bunch of confusion here.
Having all balls the same size in diameter would lead to different levels of inflation.
Having all balls inflated to the same PSI would lead to different sizes, in diameter.
Simply put the tolerances on there balls are not +/-.0000000001 There is no way to have all these balls be the same size and same pressure.
Unread 03-03-2014, 14:12
Flywheel Police
The rules state nothing about ball pressure, but they do state an approximate size. And assuming that all of the covers are approximately the same size the balls should be inflated to around the same size according to the inflation guide. So there is no argument backing pressures since the rules state nothing about it.
Unread 03-03-2014, 14:28
jman4747's Avatar
jman4747 jman4747 is offline
Just building robots
AKA: Josh
FRC #4080 (Team Reboot)
Team Role: CAD
jman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond reputejman4747 has a reputation beyond repute
We really should not have a problem putting a ball in a box and pumping it up till it touches the sides.
I don't see why you can't just pump them up in the morning and check them at lunch each day and be done. Or even just once a day (I'm assuming they may lose some air getting hit and squished all day).
The rules say approximately 2ft diameter. Excuse me for designing for 23"-25".
Alumni, CAD Designer, machinist, and Mentor: FRC Team #4080
Mentor: Rookie FTC Team "EVE" #10458, FRC Team "Drewbotics" #5812
#banthebag
#RIBMEATS
#1620
Unread 12-03-2014, 22:38
Annatreptic Annatreptic is offline
FRC #2910 (Jack in the Bot)
Team Role: Communications
Annatreptic can only hope to improve
They were extremely inflated at teh Glacier Peak PNW regional as well. So inflated in fact, that it started to continuously stall our motor and wouldn't allow us to gather the balls at all. We want to put some slop in our pneumatic mounts to our arm to try to fix this problem, any other teams done things to help this problem?
Unread 12-03-2014, 23:02
MarcD79's Avatar
MarcD79 MarcD79 is offline
AKA: Marc
FRC #0176 (Aces High 176)
MarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond reputeMarcD79 has a reputation beyond repute
This thread can go on and on, but the one thing to remember is that according to the Filed manual, the balls should be inflated to the point where the zipper is not touching itself, nor stretched into a football shape. They are to be inflated where the zipper is slight pulled apart where the inflating plug can be inserted. The zipper should be able to be pulled closed with some slight resistance. I did not receive any complaints at the Groton District event. I checked all balls often & they were consistent. We did have 2 balls checked at the beginning of the Eliminations & found to be slightly over-inflated by a volunteer who was just trying to keep up & was pumping them up rapidly. After that they seemed to be consistent. They will be scrutinized at the Southington District Event to be properly inflated.
Mentor & Volunteer
Field setup, Field Supervisor & disassemble Suffield Shakedown 2003- present (2015)
Connecticut Regional Field setup, disassemble & FTAA 2009, 2010, 2011, 2012, 2013 (Field reset & Assistant Field Supervisor), Field Reset Pine Tree Regional 2013, Field Supervisor, setup & take-down at Groton & Southington Districts 2014, Field Reset Hartford District 2014. Field Reset Boston District Championship 2014. FLL Judge Fall 2014
Field Supervisor/Set-up & Take-down Waterbury & Springfield , Field Reset/Set-up & take-down Hartford N/E District 2015. Field Reset NE Champs 2015. FLL Judge Fall 2015.
Suffield Shakedown 2016, Field Super 2016 Stronghold Waterbury.
Unread 13-03-2014, 11:27
tickspe15's Avatar
tickspe15 tickspe15 is offline
Purdue University
AKA: Spencer Tickman
FRC #1747 (Harrison Boiler Robotics)
tickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant futuretickspe15 has a brilliant future
we noticed that the balls were more inflated than we expected at auburn mountain view during week 1 and upon further testing found problems similar to the ones you describe. We then altered our intake by moving the roller up about an inch to decrease ball compression and avoided problems at glacier peak. Though the balls may be over inflated they have been consistent at PNW event
Unread 13-03-2014, 11:37
Has anybody out there actually measured the difference in pressure between a properly inflated ball and a slightly over-inflated (and under-inflated) one?
Is it a large enough difference that it could be reliably measured with a relatively inexpensive gauge at the events?
Unread 13-03-2014, 12:29
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Last week, 4183 lengthened their pickup arms an inch to allow the more-inflated balls to fit without stalling the motor.
Measuring the pressure would require a special fitting or gauge, although it wouldn't be too hard to make something to do it. 1/4" pneumatic tubing fits into the inflation hole in the ball.
The extent of wrinkling at the seams of the ball gives an indication of how full it is...until the wrinkles go away entirely, then who knows?
The balls aren't exactly round, either...they're sort of cube shaped.
I think this is a game where you need to take a lot of effort to make sure your robot will work with the game pieces, whatever they end up being like at the competitions. If you didn't, you're going to have problems. The low goal is a good option if you can't shoot into the high goal reliably.
