Go to Post I am just very happy that I have never been responsible for the spelling of Karthik's last name on a name tag. Seriously. - JaneYoung [more]
Thread Tools Rating: Thread Rating: 16 votes, 5.00 average. Display Modes
Unread 02-03-2014, 23:46
XaulZan11's Avatar
XaulZan11 XaulZan11 is offline
AKA: John Christiansen
XaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond reputeXaulZan11 has a reputation beyond repute
Send a message via AIM to XaulZan11
Re: Killer Bees - 2014
Since you already competed, can you share info about your drivetrain?
Unread 03-03-2014, 17:24
BJC's Avatar
BJC BJC is offline
Simplicity is Complicated!
AKA: Bryan Culver
FRC #0033 (The Killer Bees)
BJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond reputeBJC has a reputation beyond repute
Originally Posted by AllenGregoryIV View Post
Congrats on the win at Southfield.
What are you all using for a "photon cannon" this year and what exactly are you using it for? Normal aligning to wall?
Thanks, we are generally happy with the robot performance this weekend.
The flashlight basically provides a line on the ground in front of the driver which allows us to line up with stuff on the field from far away. When we initially put the light on we immediately saw an improvement in driver performance. I contribute this to the driver being able to look at the light instead of the robot while driving. Effectively, it becomes intuitive to look where the robot is going to be rather than where is currently is.
The drivetrain this year is actually has a pretty interesting story behind it. I don't have time to properly do it justice right now, but maybe sometime later this week I'll type it all out.
robot robot robot? Robot. Robot? Robot!
-----------------Team 33------------------
Unread 29-04-2014, 15:18
Answer42's Avatar
Answer42 Answer42 is offline
Answer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud ofAnswer42 has much to be proud of
Originally Posted by nathannfm View Post
I spy an Omni wheel!
So.... About that drivetrain.
My comments do not reflect the views of associated teams.
Unread 29-04-2014, 15:48
s_forbes's Avatar
s_forbes s_forbes is online now
anonymous internet person
FRC #0842 (Falcon Robotics)
This is one of the first mysteries that I set off to solve when I got to the pits in St. Louis. The answer surprised me: 4 omni wheels, each with a single gear reduction from a CIM motor, nothing more. I chatted with one of the students as they were going through inspection, and the rational for the design choice sounded reasonable. The consistency and range of their catapult seems like a big part of why they are so successful with this approach.
Unread 29-04-2014, 17:00
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
About the drivetrain:
The drivetrain is very simple. There are 6 pieces of sheet metal (0.050" 6061 T6) which make up a fairly standard square with 2 wheel bays of approximately standard width (I believe 3", don't quote me on that). At each corner, a stiffener plate (0.050" 6061 as well) is used to maintain the center-center distance between a single large CIM with Vex 11t pinion and the Vex omni wheel and 72t gear (held together with versakey parts). The axle is 1/2" 7075 round, dead, taped in the end for a 1/2-20. I can give more details on the exact fabrication if you want.
The omni wheels were replaced every 2 tournaments or sooner, we simply replaced the entire axle-bearing-wheel-gear assembly and had a complete set of identical spares (including axle spacers) in the pit.
We found that the CIM could twist, so we added wood blocks between the CIM and front/rear chassis rail to keep the gear spacing correct. This was done manually by sound, the whole drivetrain is very quiet when running.
We initially used Vex encoders with Vex 2.75" omni wheels as floating odometry wheels, but quickly removed them for weight savings and ran time-based autonomous programs (we did do voltage compensation to try to keep it reasonably consistent). There are no sensors in the drivetrain.
The catapult is a single welded frame, which bolts on top of the chassis to provide significant stiffness. With the 4-omni drive, we don't care about stiffness nearly as much as we did with drop-center traction wheel drives.
The strategy behind the drivetrain was basically to be able to maneuver out of any situation easily enough to prevent direct pushing. We believe this achieved it in the lights, simplest way possible, without any articulating systems. By preventing direct pushing, we also removed the need for a multi-speed gearbox, allowing the 'corner modules' which are extremely light, simple, and efficient.
I can answer more questions if necessary.
Kettering Motorsports
Unread 29-04-2014, 19:51
Zebra_Fact_Man's Avatar
Zebra_Fact_Man Zebra_Fact_Man is online now
]\/[ Go Blue!
AKA: Solomon
FRC #1076 (Pi Hi Samurai)
Zebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant futureZebra_Fact_Man has a brilliant future
Are there any better pictures of the drivetrain system posted anywhere?
My Journey in FIRST:
Mentor/Coach/Engineer
2014-2017: Team 1076 - Pi Hi Samurai
____ 2014: Team 5220 - The Rockets
2009-2014: Team 313 - The Bionic Union/Bionic Zebras
Student
2006-2009: Team 313 - The Bionic Union
Unread 29-04-2014, 20:14
apalrd's Avatar
More Torque!
VRC #3333
I don't have any. I'll see if anyone else does.
Unread 29-04-2014, 20:57
Jim Zondag's Avatar
Jim Zondag Jim Zondag is offline
Team Leader
FRC #0033 (Killer Bees)
Jim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond reputeJim Zondag has a reputation beyond repute
Here are a couple of pics.
As Andrew said, it is very simple. The minimalist design freed up a lot of resources we could then use on other features of the machine such as a giant spring bundle in the catapult and huge catching wings. The lack of chains or belts means we do not need much rigidity in the frame, allowing it to be even lighter. There is a single 6:1 rear reduction to each wheel.
Our priority this year was to make the best catapult possible. The drivetrain needed to take a backseat to this objective.
A lot of people thought we were crazy and/or stupid when we revealed this. Admittedly it is a bold choice. It has its pros and cons, but for this game, I think the pros were an advantage overall. It does require a very good driver, and Ellen is pretty awesome. (7 blue banners, 175/46/1 record over 2 years)
There is more than one right way to design a robot. The right choice depends on many factors including: experience, driving ability, weight, complexity, and game strategy. I think our 2014 experience proves that you can sometimes step outside the box if you have properly thought through the question.
"To learn what is possible, we must attempt the impossible." Arthur C. Clarke
Unread 29-04-2014, 21:10
jagen31 jagen31 is offline
Parameterized Type
AKA: Jared Gentner
FRC #0020 (Rocketeers)
jagen31 is an unknown quantity at this point
Nice! Very interesting design philosophy. We have a really good driver, but if I told him we were putting omni wheels on the robot he'd punch me square in the face.
Funny story, during Archimedes, whenever someone would mention 33 in the team 20 stands, a bunch of mechanical people would say, "don't worry, we can just push them around," and finally someone said, "Then do it, if its so easy."
Last edited by jagen31 : 29-04-2014 at 21:11. Reason: I realized I didn't say that quote but I really wish I did :P
Unread 29-04-2014, 21:23
Mike Marandola Mike Marandola is offline
Lead Bumper Mentor
AKA: Mike Marandola
FRC #0316 (Lunatecs)
Mike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond reputeMike Marandola has a reputation beyond repute
This is my favorite robot by far. The drivers are so good. Are you guys able to alter the trajectory of the shot with your choo-choo mechanism?
2015 - Pioneer Valley District Finalists/Upper Darby District Finalists/MAR District Championship #1 Seed and Winners with 225 and 203
2014 - Lenape Seneca District Winners/Chestnut Hill District Winners
2013 - Lenape Seneca District Winners/Chestnut Hill District Finalists
2011 - Philadelphia Regional Finalists
2009 - Finger Lakes Regional Finalists
Unread 29-04-2014, 21:26
AlecMataloni AlecMataloni is offline
Excellence is Bliss
AlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond repute
So, what's the standard bend radius on the .050 sheet you guys use? I've read that 6061-T6 bends poorly/ cracks below a bend radius of double the material thickness. Is this the rule of thumb you follow?
Unread 29-04-2014, 21:31
chiefsfan67's Avatar
chiefsfan67 chiefsfan67 is offline
AKA: Cake Jooper (Switch the C and J)
FRC #1730 (Team Driven)
chiefsfan67 is a splendid one to beholdchiefsfan67 is a splendid one to beholdchiefsfan67 is a splendid one to beholdchiefsfan67 is a splendid one to beholdchiefsfan67 is a splendid one to beholdchiefsfan67 is a splendid one to beholdchiefsfan67 is a splendid one to behold
By the way, thank you Killer Bees, from 1730 Team Driven, for all of the free bee antennae, at the buffet Saturday night, and for wishing our drive coach a happy birthday! That was awesome!
Unread 29-04-2014, 22:06
tim-tim's Avatar
tim-tim tim-tim is online now
Simplicity by Design...
AKA: Tim Miedzinski
FRC #0836 (The RoboBees)
tim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond reputetim-tim has a reputation beyond repute
I can't speak for 33, but the typical rule of thumb is twice the thickness for 6061-T6. We don't use much .050" or 6061-T6 on our robot, but at work we typically just use a 1/8" bend radius or 3/32" (.094") if we are in a pinch.
The RoboBees
Tim's Shortcuts Anderson Powerpoles and Crimper, Star/Tube Nuts
Unread 29-04-2014, 22:20
Phyrxes's Avatar
Phyrxes Phyrxes is offline
Has done the math, have you?
AKA: Dave Button
no team (No Team, Changed Schools)
Phyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant futurePhyrxes has a brilliant future
Interesting read, thank you for posting. This was our first year using a sheetmetal frame and our sponsor suggested 5052 sheet over 6061 as thats what they use for most of their paying customers and can generally make our parts of of scrap. Any insight on what alloy properties to look for in this application?
Dave Button
Physics and Mathematics Teacher
Wakefield School
The Plains, VA
“Simplify and add lightness.”
― Colin Chapman, Team Lotus
Unread 29-04-2014, 21:41
Ed Sparks Ed Sparks is offline
Engineer/Mentor/Inspector
AKA: FirstCadLibrary Guy, Inspector Dude
FRC #3959 (Formally with FRC-34)
Ed Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond reputeEd Sparks has a reputation beyond repute
Send a message via AIM to Ed Sparks Send a message via Yahoo to Ed Sparks
Originally Posted by Jim Zondag View Post
..... There is more than one right way to design a robot. The right choice depends on many factors including: experience, driving ability, weight, complexity, and game strategy. I think our 2014 experience proves that you can sometimes step outside the box if you have properly thought through the question.
Absolutely ..... and your drivers were awesome. When I first saw the bot on it's back in the pits, I kept looking for the secondary wheel system to provide traction. What are the two green omni wheels doing?
The proof is in the performance and no doubt 33 had it this year (as always). Looking forward to seeing you next time.
Ed Sparks
MECH TECH FRC-3959
