Go to Post Lexan $20.... Stock Aluminum $30.... Having a OI that is heavier than the robot PRICELESS.... - GBIT [more]
  #31   Spotlight this post!
Unread 03-03-2014, 09:07
Chris is me's Avatar
AKA: Pinecone
Re: How can you help GDC make this game better?
Originally Posted by Taylor View Post
During qualification rounds, allow 2 red and 2 blue balls in play.
During elimination rounds, allow 1 of each color (as it is now).
Honestly, this is a drastic change but I really like this suggestion despite qualifications becoming different than elims. This game has fundamental design flaws apart from the broken penalty structure and this change would fix the extreme effect of strength of schedule on seeding. This must be coupled with the addition of scorekeepers to relieve the refs of having to do even more work.
  #32   Spotlight this post!
Unread 03-03-2014, 09:14
Taylor's Avatar
Taylor Taylor is offline
Professor of Thinkology, ThD
AKA: @taylorstem
FRC #3487 (Red Pride Robotics)
The precedent has been set - 2012 bridges.
In my mind, this change will bring about two benefits - it will make the quals much more watchable, and it will reduce the amount of robot-incurred robot damage before elims begin. Not just from aggressive defensive play, but from the scrum that results from a red and blue ball, loose on the field, in the same area.
Also, JVN noted that this would be an awesome 2v2 game. I'd like to see that - even if it's during exhibition (mentor?) matches at an offseason event.
Hi!
  #33   Spotlight this post!
Unread 03-03-2014, 09:19
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
I forgot my other idea that would make arguing with the refs over scoring for assists and trussing less of an issue when teams forget to clear the autonomous balls.
PUT A WHITE STRIPE AROUND THE AUTONOMOUS BALLS!!!!!!!!!!!!!!
I can't tell you how many times teams on the field and people in the stands lost track of the fact that the ball being played was an auton ball that rebounded down the length of the field.
Just put a stripe on the ball so people can tell there is a difference.
Thank-you 294 & 67
www.bobcatrobotics.org
  #34   Spotlight this post!
Unread 03-03-2014, 09:27
orangemoore orangemoore is online now
AKA: Roger Moore
FRC #3135 (Robotic Colonels)
orangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond reputeorangemoore has a reputation beyond repute
The problem is that all of the balls are recycled in the match.
Stronghold
Student 2013-2016
3135 -- Robotic Colonels
3507 -- Robotheosis (FTC)
  #35   Spotlight this post!
Unread 03-03-2014, 09:30
AKA: Lars Kamen's Roadie
FRC #0051 (Wings of Fire (on sabbatical))
I mentioned this match in the other thread, but here is why something needs to change as far as how scorekeeping is done.
http://www.youtube.com/watch?v=_6pHN2gB_8Y
Watch the match, and determine how many points the red alliance scored. Then check out the official score. It's quite an eye opener.
EDIT: For those scoring at home, there was a truss pass with about 10 seconds left in the match that was after the video got cut, so add 10 points to your score for that.
  #36   Spotlight this post!
Unread 03-03-2014, 09:37
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
I'm going to be short and to the point here.
1. Scale back the value of the penalties. The scaling of penalties is completely out of whack when compared to the point scoring potential for an alliance. This is causing penalties to have an overwhelming impact on matches.
2. Allow for certain rule infractions to merely generate a warning for inconsequential actions. The warning will serve as a deterrent, and the match is not unnecessarily affected by an action which did not impact the result. If a team repeatedly performs the same infraction, issue an penalty. This would be similar to a yellow/red card system, but applied to fouls. Actually the better analogy is basketball where you're allowed to commit a certain number of fouls that don't affect a shot, before your opponent is awarded free throws.
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
  #37   Spotlight this post!
Unread 03-03-2014, 09:40
EricLeifermann's Avatar
EricLeifermann EricLeifermann is offline
That was a short break
FRC #2826 (Wave Robotics)
counted 125...
EDIT: I see from Spyder you only got 66 points.
2012-Present Wave Robotics Team 2826
  #38   Spotlight this post!
Unread 03-03-2014, 09:43
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
Second
We do not stop playing because we grow old;
we grow old because we stop playing.
  #39   Spotlight this post!
Unread 03-03-2014, 09:44
Originally Posted by EricLeifermann View Post
counted 125...
I counted 125 as well, yet the official score was 66...
  #40   Spotlight this post!
AKA: Roger Moore
counted 125...
Same here.
Stronghold
Student 2013-2016
  #41   Spotlight this post!
Unread 03-03-2014, 10:00
I had 135 in the video.
15 mobility
20 for 1 hot auton high
20 for 2x Auton balls scored high in teleop
80 for 2x 40 pt cycles (2 assist, truss, high goal)
Thank-you 294 & 67
  #42   Spotlight this post!
Unread 03-03-2014, 10:10
15 mobility
2 assists are only 10 points so that equates to a 30 point cycle not 40.
  #43   Spotlight this post!
Unread 03-03-2014, 10:16
Libby K's Avatar
Libby K Libby K is offline
Always a MidKnight Inventor.
FRC #1923 (The MidKnight Inventors)
Rookie Year: 1992
Libby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond reputeLibby K has a reputation beyond repute
Originally Posted by Tom Line View Post
It must be emphasized to every single ref during training that one robot cannot force another to take a penalty. This has long been a core tenet of FIRST except in very special cases. Being pushed into goals, into opposition balls, and out of field perimeter by another robot should not be a foul.
In addition, the rule regarding penetration inside the bumper perimeter needs to be enforced correctly. Damage needs to occur, or it needs to be clearly intentional to generate a foul.
This is an exceptionally good point. A few times at events I've seen, BLUEBOT would get a possession foul (for 'trapping' or 'herding' the red ball), when REDBOT was in fact pinning them to the red ball.
G12 needs two penalty levels. I can understand a 50 point penalty if a robot picks up an opponents ball, but contact with the ball that is marginal should be a smaller penalty.
^This would fix that.
Similarly, low goal incursions and extending outside the field perimeter when being pinned to the goal/wall by the opposite alliance happened quite often, and sometimes the G14 violator was not penalized, and the incursion/field perimeter foul was assessed instead.
G14
Strategies aimed solely at forcing the opposing ALLIANCE to violate a rule are not in the spirit of FRC and are not allowed. Rule violations forced in this manner will not result in assessment of a penalty on the target ALLIANCE.
Violation: TECHNICAL FOUL
I think the suggestions about scorekeepers separately from refs is a great one, because it could let the refs focus on the interactions between robots. Several inside-frame-perimeter violations went unpenalized, even when they caused damage, simply because the referees 'didn't see it happen'. If there were a scorekeeper watching the ball instead, the ref would have been able to see the robot interaction. I think it would seriously improve people's impressions of the game if there were scorekeepers dedicated to the ball/assist/scoring/pedestal tracking and the refs could focus on the robots. (This would also help with the scorekeeping errors that are being pointed out in this thread - 125 points scored vs 66 recorded is a BIG problem.)
Spot on. I've got nothing to say except 'seconded'.
Libby Kamen
Team 1923: The MidKnight Inventors
2006-2009: Founder, Captain, Operator, Regional Champion.
2010-Always: Proud Alumni, Mentor & Drive Coach. 2015 Woodie Flowers Finalist Award.
229: Division By Zero / 4124: Integration by Parts
2010-2013: Clarkson University Mentor for FLL, FTC & FRC
FIRST Partner Associate, United Therapeutics
#TeamUnither | facebook, twitter & instagram | @unitherFIRST
questions? comments? concerns? | twitter: @libbyk | about.me/libbykamen
  #44   Spotlight this post!
Unread 03-03-2014, 10:36
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Yes this, 100 times over, we need dedicated score keepers.
During our Elimination matches at Hatboro Horsham, our scores seemed to be lower than expected, due to some missed auto points, and missed assist points, but we weren't all that concerned since we were winning matches. Then, in Final 1, the posted score was 79 to 59 in favor of the Red Alliance, even though both Alliances* had been scoring in excess of 100pts in each of their previous rounds. (*Semi 1-1, #1 alliance scored 99pts.)
After an intense post match discussion with the head ref, we found out that the initial assists on either end of the field were missed for both alliances, and that some of our previous "same zone" assists (Robot A passes to B in Z1, B moves to Z2) had not been counted as assists in earlier matches... Thankfully the missed assists would have only corrected the scores on both sides and not changed who won the match, so we went to Final 2 where the scores were correct, but it makes me wonder what else may have been missed through the course of the weekend.
It seems like the ideal solution would be to have one scorekeeper for each alliance, sitting at approximately mid-field and have them track the ball. We might not get 100% perfect results, but they'd have to be better than now.
-Dustin Benedict
  #45   Spotlight this post!
Unread 03-03-2014, 10:38
Carolyn_Grace's Avatar
Carolyn_Grace Carolyn_Grace is offline
Build bridges not walls.
AKA: Carolyn Beyer
FRC #1024
Carolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond reputeCarolyn_Grace has a reputation beyond repute
It's pretty simple to tell when a ball is an autonomous ball by the way the high goals are lit up. As soon as a ball from a lit pedestal is put into play by a human player, the high goal lights up one section. If the pedestal isn't lit up at all, then the ball on the field is an auton ball.
...if the field isn't lighting up correctly in a timely fashion, than THAT needs to be fixed.
"It is change, continuing change, inevitable change, that is the dominant factor in society today. No sensible decision can be made any longer without taking into account not only the world as it is, but the world as it will be." -Isaac Asimov
