Go to Post As they say... I'd rather be lucky than good any day (especially Saturdays). :) - JVN [more]
Unread 03-03-2014, 11:38
Rohawk1's Avatar
Rohawk1 Rohawk1 is offline
MC and GA :D
AKA: Patrick Jung
FRC #3824 (RoHAWKtics)
Rohawk1 will become famous soon enough
Joystick vs. Controller?
We have seen an increase in controller use recently and were wondering what are the differences? What are the pros and cons of each and we would like to hear what you guys like to use best!
Unread 03-03-2014, 11:39
Arpan Arpan is offline
Olin class of 2019
FRC #3061 (Huskie Robotics)
Arpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud ofArpan has much to be proud of
Re: Joystick vs. Controller?
Our team uses controllers. One of our sponsors (Create, Cut, and Invent) builds bomb disposal robots for SWAT teams and he claims that using a controller massively improves your reflexes. That said, it's really driver preference.
Unread 03-03-2014, 11:49
PandaHatMan's Avatar
PandaHatMan PandaHatMan is offline
AKA: Wallpe
FRC #1747 (Harrison Boiler Robotics)
PandaHatMan is an unknown quantity at this point
Controllers are not as restrictive as joysticks because you can use them in the air as opposed to on a tabletop. They also have more axis, which our programmers really like.
Unread 03-03-2014, 11:55
Damiaen_Florian's Avatar
Damiaen_Florian Damiaen_Florian is offline
Do It Until You Can't Get It Wrong
FRC #0195 (The Cyber Knights)
Damiaen_Florian is a name known to allDamiaen_Florian is a name known to allDamiaen_Florian is a name known to allDamiaen_Florian is a name known to allDamiaen_Florian is a name known to allDamiaen_Florian is a name known to all
In all honesty it's just driver preference, I can almost guarantee you any driver that's using an Xbox controller is because they play Xbox a lot at home. Personally I prefer driving with 1 Attack3 joystick, or Arcade as it's called, because it just seems easiest to steer with and get the most precise movements out of. Also since the buttons are much larger on joysticks the probability of you pressing the wrong button on a joystick is much less.
There's always more than one way to win a game.
FRC Team 195 2011-current
Unread 03-03-2014, 12:03
cjl2625's Avatar
cjl2625 cjl2625 is offline
apel py
AKA: Cory Lynch
FRC #2067 (Apple Pi)
cjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to beholdcjl2625 is a splendid one to behold
For swerve drive we were using an Xbox controller and it worked pretty well.
But yesterday, we tried using a Attack3 joystick for strafing and a 3d joystick for rotating.
I'm glad we tried that; I actually like the dual joysticks better.
For a tank drive last year, we used one 3d joystick
Unread 03-03-2014, 13:06
indubitably's Avatar
indubitably indubitably is offline
AKA: Ryan Guinn
FRC #2338 (Gear It Forward), FRC #1732 (Hilltoppers)
indubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond reputeindubitably has a reputation beyond repute
A controller is generally used because the driver will be more familiar with it, there is a second set of triggers (bumpers), and the driver can move around a bit more with it. That being said, thumbsticks generally feel a little awkward for tank drive control but are more comfortable for arcade and omnidirectional control. Also, even though drivers may be comfortable with the controller itself, the amount of time from input to a robot's response is significantly larger than in most video games so there is still some things to get used to.
Joysticks offer a larger range of motion which can prevent the driver from being as erratic as they might be with a controller. They are usually the preferred input for tank controls but still feels comfortable for arcade/omni. Also, drivers usually feel like they can emphasize their input a bit more which is satisfying in intense FRC games.
FRC 1732 (Hilltoppers): Mentor
FRC 2338 (Gear It Forward): Mentor/Alumnus
FRC 4096 (CTRL-Z): Mentor
Unread 03-03-2014, 13:31
Mark Sheridan's Avatar
Mark Sheridan Mark Sheridan is offline
Head Mentor
FRC #3476 (Code Orange)
Mark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond reputeMark Sheridan has a reputation beyond repute
Entirely driver preference. I am used to controllers, my brother prefers joysticks.
Team 3476| Mentor| 2014 - Current
Team 3309| Mentor| 2011 - 2016
Team 766 | Mentor| 2006 - 2011 | Alumnus | 2002-2005
Unread 03-03-2014, 13:39
Racer26 Racer26 is offline
I used to be in the die-hard two joystick tank drive camp.
This year, 4343s robot is configured with an Xbox controller, and is completely intuitive to drive if you've ever played an Xbox racing game. Pulling the right trigger is gas, left trigger is reverse, left thumbstick to steer. I picked it up and was racing around our shop in seconds.
Unread 03-03-2014, 15:54
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Driver preference. Though I will say that this year we have implemented a drive controls transform and scaling on a single xbox controller stick and it's the best-driving robot our team has ever made.
Unread 03-03-2014, 16:43
Canon reeves Canon reeves is offline
FRC #4490
Canon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud ofCanon reeves has much to be proud of
I really prefer strait up two joystick tank drive, we tried cheesey but I didn't like the turns as much, the only way I would try a controller was if it was tank. The only major question we had was whether or not to have an operator use a controller or should it be the triggers on the joysticks. I must say, it is easier to not have them on the joysticks but we felt it was necessary for it to flow properly during matches.
Unread 03-03-2014, 16:52
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
As our driver, I like to drive, shoot, and collect. Our operator does catching so I don't have to worry about it. It seems to flow really well. I must also note that we're using an Xbox controller and a custom control box.
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 03-03-2014, 16:57
FRC #4490
My only beef with using an Xbox controller is just that I am afraid I won't have as much finite control, because the joysticks move further, and I like the attack three because I can hold them near the bottom and drive better. I'm probably completely wrong, but we didn't have time for me to get adjusted to a controller so we went with joysticks, but it is definitely and offseason project.
Unread 03-03-2014, 16:59
geomapguy's Avatar
Centenary '18
AKA: Graham Maxwell
FRC #1818
Also look in creating a control box in the offseason...dm me after Arkansas if you want to get some help with this..
Unread 03-03-2014, 17:05
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
3-axis joysticks for me all the way. We're using field-oriented mecanum this year, and no gamepad could ever provide the precision and ease with which we can drive our robot.*
*for us. YMMV.
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 03-03-2014, 18:41
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
I cannot understand why people want to use two joysticks to drive a tank-style robot. Why require a driver to do all of the math to control the robot in their head when you can use the cRIO to do it?
I really like the idea of using race-style controls... with triggers for forward/reverse and steering on a joystick.
With the right drive transform they work brilliantly. I was a long-time believer in the single-joystick drive control, until our programmers came up with the drive transform we're using this year. It made me a believer in the xbox controller.
