#331
Re: Week 1 Analysis
Re: Week 1 Analysis
You could argue that it was "consequential" because he fell out while diving to deflect his alliance's ball back into the field, so he gained an advantage while performing the action that caused him to end up out of the zone.
#333
Re: Week 1 Analysis
Been there, seen that a million times (after welding of that particular frame joint in your pic...It certainly appears to me that much more than 50% of the weld was then quite overly ground away, seeing that the appearance of the lack of any weld bead is also present). It is a ton of work I know, and the same issues happened to our team during Rebound Rumble (we played in the finals, lost, then rebagged a known very injured bot after our first regional, and it saw us stripping our bot completely down in the pits, to a very custom and powder coated dual side intake frame, at our second regional in Las Vegas, because every single weld broke that there was to break, between (many slightly over ground welds), a lot of very active defense, and that nasty floor beam we crossed much too often. That of course, led to many other bugs after the welding was done too, and that robot reassembled in a short period of time. That bot just wasn't quite right until Q time was nearly finished (it was by then, but we had not shown the necessary reliability to that point that another team would/could trust)....Wasn't a good year for us needless to say. I hope you fare much better in your case. Not a weld on this years bot BTW, as we knew it was going to be a very defensive hard hitting game. Though last years bot was for us.....It lasted. (And that one incident caused us to learn to go much more modular in the future). You have one thing going for you...At least the carry in has luckily been increased to 45 lbs....That 50% increase should get you there. (Well that and a good pit crew I certainly hope!) Good Luck! (Weld clean, and leave the beads please). |
#334
Re: Week 1 Analysis
Ummm...Yeah Jim...Just a little closer
...That could be the easy solution. Almost every shot I saw bounce back in, was much longer than it actually needed to be. And those not willing to change can always push it into the low goal.Ok, for the ref's I might think a change is necessary (but still, to every bot choosing to be shooting the high goal). We are supposed to design to the field. Not the GDC changing the field to our design choices. See you in just a couple of weeks...Can't wait after watching all this exciting week 1 action. Tough game for all! |
#335
Re: Week 1 Analysis
I too would like to see pictures. That robot looks a little familiar.....
#336
Re: Week 1 Analysis
http://frcdesigns.files.wordpress.co.../2008_1771.jpg |
#337
Re: Week 1 Analysis
Re: Week 1 Analysis
https://www.facebook.com/photo.php?f...type=1&theater |
#339
Re: Week 1 Analysis
Re: Week 1 Analysis
Martin - we love your robot from 2008!. It was certainly a major inspiration to our bot!!! ![]() Another picture: https://www.facebook.com/photo.php?fbid=658765220825567&set=a.6587649008255 99.1073741838.320809081287851&type=1&theater |
#341
Re: Week 1 Analysis
I saw a lot of defense on the opponent's in the in-bounding zone. Several times, BLUEBALL got trapped between the REDBOT and the REDLOWGOAL while the BLUEBOT is hoping to get the first ASSIST.
More than a few times, REDBOT pushed the BLUEBALL into REDLOWGOAL or BLUEBOT pushed REDBOT into BLUEBALL and the BALL inadvertently traveled into REDLOWGOAL as a result. It took a fair amount of time to return BLUEBALL to Blue HUMAN PLAYER and then to the FIELD. I wonder: Will we see this called as a G11 or G12? |
#342
Re: Week 1 Analysis
I haven't read through this whole thread yet since I am on mobile but I was thinking to myseld. If you have a 1 ball auton and neither of your partners has one, would it be worth it to still put all 3 balls on the field? You score your one and IF you have a decently fast pickup and scoring device then to me it makes sense to keep them out to get those quick 20 points before start the cycle. Mainly thought this because if your partners don't have an auto at all, you might be running and gunning by yourself and those points will be key as proven so far.
#343
Re: Week 1 Analysis
Re: Week 1 Analysis
For later on I agree but after watching the level of some of these drivers...I wouldn't be confident they could honestly stop a decent bot. Not speaking for just our team. I believe that will be the case for almost all events after week 3 but prior to that I think it might be a viable strategy
#345
Re: Week 1 Analysis
Do you have an opinion about webstreaming at Inland Empire? Our team ran that one, and we're hoping to run it at UCD.
