Go to Post Most of us are pretty friendly. - StephLee [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 03-03-2014, 14:57
nicholsjj's Avatar
nicholsjj nicholsjj is offline
AKA: John Nichols
no team (Devil Bots)
nicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant futurenicholsjj has a brilliant future
Re: Kitbots after Week 1
Originally Posted by Richard Wallace View Post
We used the AM14U chassis and are happy with it.
TL;DR: the 2014 kit chassis is a good starting point. It just needs to be fed some steroids, as Karthik would say.
Robotics, the only sport in the World were encouraging steroid use will land you in the Hall of Fame.
2011-FRC Team 3862, Team Captain
2012-FRC Team 3862, Strategy Mentor
2013-FRC Team 3885, Programming Mentor, Razorback Regional, Curie Inspector
2014- FRC Team 3885, Programming Mentor, Arkansas Regional, Newton inspector
2015-??? Teacher Murphysboro High School
“They call it coaching but it is teaching. You do not just tell them…you show them the reasons.”- V. Lombardi
Unread 03-03-2014, 15:20
AustinH's Avatar
AustinH AustinH is offline
FRC #4918 (The Roboctopi)
AustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to beholdAustinH is a splendid one to behold
Yeah, on the upgrade front, we definitely went with different gearboxes, different wheels, polycarb bellypan etc. We do have a fairly substantial cross brace (1.25 aluminum box tubing, 1/8in wall) that doubles as a mount for several accessories, but my worry is that the provided churros that span the interior of the robot won't cut it. I would really, really love to be proven wrong.
Some of the photos of robot damage from this year are absolutely terrifying, especially the trashed cylinders. We have spares of the things that go outside of our frame perimeter. I was not expecting to need to have spares on hand for the internal guts of our robot.
3826: 2013 Seattle Regional Industrial Design Award & Semi-Finalists
4918: 2014 PNW Glacier Peak District Event Rookie Inspiration Award & Quarter-Finalists, 2014 PNW Mount Vernon District Event Highest Rookie Seed Award, Rookie All Star & Semi-Finalists, 2015 PNW West Valley District Event Engineering Excellence Award & Semi-Finalists, 2015 PNW Mount Vernon District Event Semi-Finalists
Visit us on the web at www.team4918.org
Unread 03-03-2014, 15:25
Max Boord Max Boord is offline
FRC #0179 (The Children of The Swamp), FRC #1592 (Bionic Tigers)
Team Role: Tactician
Max Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant futureMax Boord has a brilliant future
Make sure you have a belly pan. We used ours to play D on our comp bot and in 1 hour of realistic practice the entire frame turned into a 45 degree parallelogram.
Unread 03-03-2014, 16:03
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
I was LRI at Southfield this weekend and saw a lot of kit-bot and improved kit-bots that faired very well. The architecture of the kit-bot was basically state of the art chassis for 2006-2008 if you just add in a set of shifters. A lot of great robots played really well with significantly less.
Structural bellypans are a great add on. Probably even above shifters. While it doesn't need to be made out of 1/4" steel, a good belly pan attached with rigid connection (not zip ties). If you have ever built a cheap set of shelves, the carboard panel for the back is more important than looks. It adds a ton to the structural rigidity of the shelves.
Unread 03-03-2014, 16:13
gurellia53's Avatar
gurellia53 gurellia53 is offline
word up
AKA: Andrew G
FRC #1736 (Robot Casserole)
gurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to behold
We used an AM14U with the 8wd upgrade and Vex Pro 3 CIM ball shifters. We also added a bellypan of perforated polycarbonate similar to this. It significantly stiffened our frame, was easy to bolt on, and was used as an electronics board. We also added some aluminum gussets and brackets to help add strength.
We beat our robot hard this weekend and had no issues with the drivetrain other than some field debris in one of the belts. I've been very impressed.
FRC
Robot Casserole 1736: 2007 - 2008, 2013 - present
Team Neutrino 3928: 2012
Unread 03-03-2014, 16:35
JohnFogarty's Avatar
AKA: @doctorfogarty
4901 used the kitbot with the 3CIM upgrades with a 0.125" Aluminum 3003 Belly-pan with much success. No damage whatsoever.
John Fogarty
Unread 03-03-2014, 16:46
Whippet's Avatar
Whippet Whippet is offline
MIT Class of 2020
AKA: Luis Trueba
FRC #4301 (New Tech Narcissists)
Whippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond reputeWhippet has a reputation beyond repute
Send a message via Yahoo to Whippet
Anyone have any feedback on the AM14U with the mecum upgrade package?
2010: FRC 3043, Build Assistant
2011: FRC 3043, Head of Minibot subteam; FLL 12762, Team Captain
2012: FRC 3043, Electrical; FLL 12762, Team Captain; FTC 5670, Team Captain
2013: FRC 4301, Electrical, Team Co-Captain
2014: FRC 4301, Electrical/Programming, Team Co-Captain
2015: FRC 4301, Electrical/Programming, Team Captain
2016: FRC 4301, Chief Technical Officer; FTC 10860, 10861, and 11004: Mentor. Winner, Hub City Regional (3310 & 4063)
Unread 03-03-2014, 17:53
KCmoon KCmoon is offline
FRC #0075
KCmoon is an unknown quantity at this point
From our team the only problem we had was that the wheels chipped. We will probably have to replace most of them as the treads were wearing very hard and our traction is probably different because of it.
Unread 03-03-2014, 21:30
jeremylee's Avatar
jeremylee jeremylee is offline
FRC #2526 (Crimson Robotics)
jeremylee is a jewel in the roughjeremylee is a jewel in the roughjeremylee is a jewel in the rough
Ours have some chipped lugs also, though it hasn't seemed to affect traction much. We have 3 days of practice before we bagged and a regional under our belt now. Looks like we could go another regional if we wanted to on the same set even though we may replace them. I think you could run the lugs flat if you wanted and keep going (basically be similar to a stealth wheel).
Unread 13-03-2014, 23:51
Tim Lehmann4967's Avatar
Tim Lehmann4967 Tim Lehmann4967 is offline
A Sentient Being
FRC #4967 (That O.N.E Team (Our Next Engineers))
Tim Lehmann4967 will become famous soon enough
We cut our AM14U into a square instead of long or wide. So far it has held up very well(knock on wood) and we have very minimal reinforcements. My only complaint is that the ToughBox Minis can't take three CIMs
Unread 14-03-2014, 00:51
Best Available Data
FRC #1778 (Chill Out!)
We have yet to compete, but with our fully loaded robot (110-120 lbs with bumpers & batteries) we get some bouncing on very tight radius turns with the 1/2 wide 1/2 long square AM14U configuration. Not a big problem, but a minor annoyance. I suspect the critical point is somewhere north of 100 pounds, as we never noticed it until after the bumpers went on.
Unread 14-03-2014, 07:56
hrench's Avatar
hrench hrench is offline
Mechanical build mentor
AKA: Bob Hrenchir
FRC #1108 (Panther Robotics)
hrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to allhrench is a name known to all
My team 1108 used the kit frame to win the Crossroads regional. We have stock wheels and stock gear-boxes but with up-ratio gears. We're about 28" square.
We've seen extensive wear on the wheel treads, but they don't seem to grip all that much less. Weighing 95 lbs, we're still able to push most robots, especially sideways. Across the front, we have an exposed section of the extrusion where we took a significant hit and bent it in about two inches. We bashed it back out and bolted a piece of steel bar-stock below the angle and it was okay through the finals.
With a slightly light robot, four CIMS and up-ratio gears, we've measured 110 lbs of pulling force and about 12 ft/sec. Great acceleration too. I think these numbers make you competitive in most arenas. We'll see how that works out for the Championships.
I think its' easier to build a robot on than the c-frame was, but on the downside, it takes away one more area to be creative from the kids. But we're a small team and saving the resources for the rest of the design was beneficial to us. It's also a change mounting bumpers to.
Unread 03-03-2014, 16:54
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Just to reinforce what Isaac says above, my team's previously mentioned belly pan is made of 1/8th inch aluminum with edge bends for stiffness. See pictures @averagejoes3620 on Twitter.
Richard Wallace
since 2003
Unread 03-03-2014, 17:03
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Love the new kit bot. Only complaint, picked up a lot of carpet and tape in the wheels. With everything so close to the ground it really does pick up a lot of ground debris
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 14-03-2014, 08:43
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Ike, what you consider state-of-the-art right now?
