Go to Post In real life (IE when you go to apply your engineering skills to tasks in industry) there will be constraints on all sorts of things - many of which may or may not be "fair" or even "intelligent". You must learn to either work around them or use them to your advantage - preferably a bit of both. - OScubed [more]
Unread 02-03-2014, 22:23
Re: 2014 OPR After Week One Events
Originally Posted by dellagd View Post
Could you possibly run the calculation again with Sunday data for us Hatboro-Horsham teams?
There is no Twitter data available for Hatboro-Horsham.
Unread 02-03-2014, 22:29
Anupam Goli's Avatar
Anupam Goli Anupam Goli is offline
PCH Q&A co-founder/Scouting Mentor
AKA: noops
FRC #1648 (G3 Robotics)
Anupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond reputeAnupam Goli has a reputation beyond repute
You know, I'm actually quite surprised at how accurate OPR is for Palmetto. What we're seeing in the data matches our team's scouting data for the most part. I was under the impression that OPR would not be a good indicator, but I suppose that is dependent on the strength of every team at an event. I suppose the stronger the event is, the less accurate OPR becomes as a statistic.
Team 1002: 2008-2012
Team 1648: 2012-2016
Georgia Tech Class of 2016
Unread 03-03-2014, 01:24
Ed Law's Avatar
Ed Law Ed Law is offline
no team (formerly with 2834)
Ed Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond reputeEd Law has a reputation beyond repute
The OPR/CCWM week 1 numbers have been updated. Please go to
http://www.chiefdelphi.com/media/papers/2174
There are a number of points I would like to make:
1) Team Standings for Centerline is not posted on FIRST website. I posted what the FTA gave me but I am not certain the subscores are in the right columns. There were only two columns in the FTA report and I guess they are for Autonomous points and Teleop points. I will update them once the Team Standings are posted on the FIRST website.
2) Team Standings for Greater Toronto West has incomplete data. I did not include these data in Query.
3) I added the Adjusted OPR in column AE for each event, which removes the Foul Points from the total score before computing OPR. The foul points came from Twitter data. I did not use the match score from Twitter data because they are not 100% accurate. For events without twitter data, no Adjusted OPR is computed.
4) World ranking is computed using OPR because some events do not have twitter data to calculate Adjusted OPR.
5) I added a tab called Adjusted OPR Results. Events without twitter will show 0 for Adjusted OPR.
If you find any error or have any questions, please let me know.
Please don't call me Mr. Ed, I am not a talking horse.
Unread 03-03-2014, 07:37
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Originally Posted by efoote868 View Post
Would anyone like to speculate on how OPR fits true robot scoring abilities or alliance contributions this year compared to previous years?
One thing I see that is different this year is that any particular alliance can do much better (or much worse) than the sum of the individual teams since robots can't do their own thing for an entire match.
It should be pretty excellent at giving a rating for a team's contributions this year, and in fact should be fantastic at finding teams who contribute to their alliance without doing the prestige tasks. A team that adds two assists on every ball but doesn't shoot it through the goal will get a good OPR.
However: even moreso than in past years, you won't want to scout with it. A team might get a 60-70pt OPR without ever firing a ball. If you also don't shoot a ball, you probably want to find a shooter or a low-goal specializer. If you already have a fantastic shooter, you may not want to pick a team that earned their OPR with a shooter. In past years you could maybe get away with picking the top 3 in OPR for an alliance, but with such different functionalities and roles, you'll want to make sure that everyone is compatible.
Also, keep in mind that you can't always compare across events with OPR - an event where everyone tends to play offense and keep to themselves will elevate all their robots OPRs, compared to an event with heavier defense.
Another thought about the penalties: It would be interesting to not only remove the penalties from scores (as has been done), but to actually subtract them from the team that caused them when putting inputs into an OPR-solver. This would help find teams that are racking up a lot of penalties, since their OPRs would go much lower.
tl,dr: OPR will be great for entertainment purposes to do comparisons across robots who do different tasks, but poor for scouting.
Unread 03-03-2014, 09:42
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Any particular reason that GSDE isn't included in this data?
Unread 03-03-2014, 10:39
Or you could just do an "OPR" on foul points.
(Note: This uses Twitter data. The usual Twitter data caveats apply).
Unread 03-03-2014, 11:51
markmcgary's Avatar
markmcgary markmcgary is offline
Software Mentor
FRC #4322 (Clockwork Oranges)
markmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nicemarkmcgary is just really nice
Just so I understand the "OPR" on foul points, is lower OPR a good thing?
(Thanks to all contributors for this data. Very interesting stuff.)
Unread 03-03-2014, 12:07
Since the point of the computation was to try to estimate the fouls committed by each team, lower is better.
See cell G1 in the spreadsheet.
Unread 03-03-2014, 12:31
markmcgary's Avatar
Software Mentor
Sigh... I can no longer complain about my customers who do not read the instructions.
Thank you.
Unread 03-03-2014, 13:51
Citrus Dad's Avatar
Citrus Dad Citrus Dad is offline
Business and Scouting Mentor
AKA: Richard McCann
FRC #1678 (Citrus Circuits)
Citrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond reputeCitrus Dad has a reputation beyond repute
At Inland Empire, we had a robot that only had a drive train playing only defense--no shooter or pick up mechanism with a middling OPR (and ended up an alliance captain), and another that was having quite an offensive day (our 3rd alliance member) with a low OPR despite showing high in our scouting data. The OPR this year seems to be greatly influenced by the schedule and win-loss record. And with 13 matches apiece, this was the best possible statistical mix of any event.
Unread 03-03-2014, 14:05
Debbie's Avatar
Debbie Debbie is offline
AKA: Debbie May
FRC #1023 (Bedford Express)
Debbie has a reputation beyond reputeDebbie has a reputation beyond reputeDebbie has a reputation beyond reputeDebbie has a reputation beyond reputeDebbie has a reputation beyond reputeDebbie has a reputation beyond reputeDebbie has a reputation beyond reputeDebbie has a reputation beyond reputeDebbie has a reputation beyond reputeDebbie has a reputation beyond reputeDebbie has a reputation beyond repute
Thanks Ed, and Jim, and everyone that is working on this. Ed, is the Center Line data updated yet? Thanks for taking out the penalty points. They were ridiculous! (and that's all I will say on that subject here) Can you please let me know when it is?
Thanks!!!
FRC 1023 - Bedford Express - Coach, 2009 - present
FTC 160 - Dana Broncobytes Coach - 2007 - 2009
FLL - Dana Unicorns Coach - 2000 - 2006
Bedford Express Varsity Letter Video BX Facebook
Unread 03-03-2014, 18:18
dellagd's Avatar
dellagd dellagd is offline
Look for me on the field!
AKA: Griffin D
FRC #2590 (Nemesis) #2607 (The Fighting Robovikings)
dellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond reputedellagd has a reputation beyond repute
Im not that good at using excel, but I can't find the adjusted OPR for Hatboro even though the regular OPR data is there. Is this due to the lack of twitter data as Ether said?
Check out some cool personal projects in computers, electronics, and RC vehicles on my blog!
2016 MAR DCMP Engineering Excellence Award
2016 MAR Westtown Innovation in Control Award
2016 MAR Hatboro-Horsham Industrial Design Award
2015 Upper Darby District Winners - Thanks 225 and 4460!
2015 Upper Darby District Industrial Design Award
2015 Hatboro-Horsham District Winners - Thanks 2590 and 5407!
2014 Virginia Regional Winners - Thanks so much 384 and 1610, I will never forget that experience!
2014 Virginia Quality Award
2014 MAR Bridgewater-Raritan Innovation in Control Award
2014 MAR Hatboro-Horsham Gracious Professionalism Award
2013 MAR Bridgewater-Raritan Innovation in Control Award
2012 MAR Lenape Quality Award
Unread 03-03-2014, 18:32
Yes. The Twitter data has foul points. The Team Standings data lumps foul points together with TeleOp Goal points.
Unread 03-03-2014, 19:06
JohnGilb JohnGilb is offline
Programming Mentor, Drive Mentor
FRC #0488
JohnGilb has a spectacular aura aboutJohnGilb has a spectacular aura aboutJohnGilb has a spectacular aura about
As regards teams with negative "Foul OPR:"
Does that essentially mean that not only do they rarely (if ever) commit fouls, but also that their presence on an alliance reduces the chance/severity of their allies committing fouls as well?
If so, we should really be asking teams 2493 and 4981 what they're doing to keep the game clean. =]
Unread 03-03-2014, 20:09
Statistically, yes. But all the usual OPR caveats apply.
