Go to Post When you score a Supercell on your own alliance it has a tendency to sway a match... - EricLeifermann [more]
Thread Tools Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Unread 03-03-2014, 19:14
Andrew Lawrence
Posts: n/a
Re: Team 254 Presents: Barrage
Originally Posted by Torrance View Post
The material is 1" OD Polyurethane tubing from McMaster-Carr. It's a bit tricky to get on the shaft, but it usually works wells and doesn't wear too easily.
What keeps the tubing spinning on the shaft? Is the friction alone enough to get the job done or is there some kind of mechanical latch holding it on?
