Go to Post But you are right about one thing, it is downright un-American. The Triplets are Canadian. - rourke [more]
Unread 04-03-2014, 13:14
Hibrawler Hibrawler is offline
AKA: Max Landry
FRC #1519 (Mechanical Mayhem)
Hibrawler is an unknown quantity at this point
Re: Compressor Not Activating
The first thing you are going to want to do is confirm that it is not a hardware issue. My team had the problem that it was not turning on but it might also apply for your scenario. Check the wiring on your switch and check that the PWM cable is still firmly connected.
Hope this helps.
