Go to Post Hey people, I found out the answer to my question and that one guy eric is right all you have to do is read the manual. The rules are in chapter 7.3.5.1, sections - .:) - ronald [more]
Unread 04-03-2014, 18:27
Ikillee Ikillee is offline
FRC #4733
Ikillee is an unknown quantity at this point
Pressure switch
How do you wire the pressure switch
Unread 04-03-2014, 18:38
Anthony Galea's Avatar
Anthony Galea Anthony Galea is offline
Formerly known as 3175student17
Anthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant futureAnthony Galea has a brilliant future
Re: Pressure switch
2013-2016: FRC 3175 Knight Vision, student
2014 Center Line District Finalists with 815 and 280
2016 Woodhaven District Winners with 3604 and 6116
2017-?: Rose-Hulman Institute of Technology
Unread 04-03-2014, 18:39
Chris_Ely's Avatar
Chris_Ely Chris_Ely is offline
AKA: luckof13
FRC #3414 (HackBots)
Chris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond reputeChris_Ely has a reputation beyond repute
Re: Pressure switch
Take a PWM cable. Connect the black wire to one terminal, and the white wire to the other (you don't need the red wire). Plug the other end of the PWM cable into a DIO port on digital side car.
EDIT: Anthony beat me to it.
2013: Waterford Finalist, Livonia Winner, MSC Quarterfinalist, Curie Division
2012: Waterford, Northville, Livonia
2011: Waterford Finalist, Livonia
2010: Ann Arbor Rookie Inspiration Award, Troy
Mechanical Engineering Student,
Michigan Technological University
Unread 04-03-2014, 18:41
chigskonkwo chigskonkwo is offline
FRC #0884 (Mechanical Mules)
chigskonkwo can only hope to improve
Re: Pressure switch
Use a PWM wire, remove the male end of the PWM and attach the black wire to one screw and the white wire to another screw, leaving the red wire unused. Then plug the female end of the PWM into the Digital Output 1 (DIO).
EDIT:
Both of them beat me to it lol.
Unread 04-03-2014, 19:38
FRC #4733
Sweet. Thanks! What does the limit switch in the diagram do?
Unread 04-03-2014, 19:47
Chris_Ely's Avatar
AKA: luckof13
Re: Pressure switch
It provides feedback for when a cylinder is activated. You don't need to have that.
