| Thread Tools |
Rating:
Display Modes |
#391
Re: Week 1 Analysis
Great post Greg. This will help us out when we have another problem with connecting and get back in the game much quicker.
#392
Re: Week 1 Analysis
It says a CATCH is worth 10 points. Again, the definition is above. Therefore, if any of the above three happens, Catch points should be awarded, since if those are defined as catches, they should be worth 10 points once per cycle. |
#393
Re: Week 1 Analysis
A CATCH occurs when a BALL SCORED over the TRUSS by a ROBOT’S ALLIANCE partner is POSSESSED by that ROBOT before contacting: 1. the carpet, 2. the ROBOT which SCORED the TRUSS, 3. or HUMAN PLAYER. |
#394
Re: Week 1 Analysis
"A CATCH occurs when a BALL SCORED over the TRUSS by a ROBOT’S ALLIANCE partner is POSSESSED by that ROBOT before contacting the carpet, the ROBOT which SCORED the TRUSS, or HUMAN PLAYER." The 'before contacting' bit is applied to the carpet and the robot that scored the truss and a human player. So a catch only occurs when the ball is caught by another robot before contacting the carpet or the tossing robot or a human player. Last edited by Andy A. : 04-03-2014 at 12:36. Reason: Added clarification. Maybe. |
#395
Re: Week 1 Analysis
Suggest reading your post very carefully again. Catch is by a ROBOT possessing a ball scored over the truss by it's alliance partner BEFORE touching the carpet, the robot which scored the truss or the human player. Self catch and human catch do not score the catching points
#396
Re: Week 1 Analysis
#397
Re: Week 1 Analysis
Wow. FIRST needs to work on their syntax XD. I was reading it as: A catch occurs when A, B, and C were met rather than A catch occurs when if it is caught by a robot before A, B, and C. |
#398
Re: Week 1 Analysis
I may be wrong, but i don't think a robot to human player pass earns catch points. I have seen some teams throw the ball over the truss and have a human player catch it but that is primarily to have a reliable way to maintain control of the ball after a truss toss. It also greatly reduces the amount of time it would take to retrieve the ball after a truss toss if a human player were to catch it.
#399
Re: Week 1 Analysis
.Last edited by pabeekm : 04-03-2014 at 19:07. |
#400
Re: Week 1 Analysis
Re: Week 1 Analysis
This is great advice that I want to share with my team... Thanks for your time and wisdom!
Re: Week 1 Analysis
If you read the catch rule, there are three interpretations that are (according to the english language) completely valid.
The text "CATCH: the event when a BALL SCORED over the TRUSS by a ROBOT’S ALLIANCE partner is POSSESSED by that ROBOT before contacting the carpet, the ROBOT which SCORED the TRUSS, or a HUMAN PLAYER." can mean two things 1.) a catch is when a "BALL SCORED over the TRUSS by a ROBOT'S ALLIANCE partner is POSSESSED by" a.) "that ROBOT before contacting the carpet" b.) "the ROBOT which SCORED the TRUSS" c.) "or a HUMAN PLAYER" --------------------------- 2.) a catch is when a "BALL SCORED over the TRUSS by a ROBOT’S ALLIANCE partner is POSSESSED by that ROBOT before contacting the" a.) "carpet" b.)"the ROBOT which SCORED the TRUSS" c.) "or a HUMAN PLAYER" 3.) (somebody else came up with this one) a catch is when a "BALL SCORED over the TRUSS by a ROBOT'S ALLIANCE partner is POSSESSED by that ROBOT before contacting" -a.) "the carpet" -b.) "the ROBOT which SCORED" ---i.) "the TRUSS or" ---ii.) "a HUMAN PLAYER" I'm not sure how to score the truss or a human player though. ![]() |
#403
Re: Week 1 Analysis
That's probably why they had to clarify it in a Q & A, too many interpretations ... Q134 Q. "A CATCH occurs when a BALL SCORED over the TRUSS by a ROBOT’S ALLIANCE partner is POSSESSED by that ROBOT before contacting the carpet, the ROBOT which SCORED the TRUSS, or HUMAN PLAYER." is confusing: Should we read "... is POSSESSED by 1 2 or 3", or "...before contacting 1 2 or 3"? A. Before contacting 1, 2, or 3. |
#404
Re: Week 1 Analysis
Of course, regardless, catching your own ball has its benefits in the form of maintaining possession |
#405
Re: Week 1 Analysis
Guidelines for teams setting up streaming: - Get the scoreboard in the frame somewhere, and be sure the scores are not washed out from overexposure. Especially this year, you can't tell what is happening unless you can see the scoreboard with the green assist bullets. - If you can, get the audio feed from the announcer. If not, at least have some sort of audio pickup. Video with no audio is very confusing. - A stationary camera located center field, with a nondistorted view of the entire field is best. Those courtside gopro videos are pretty much useless because they are so distorted you can't tell what's going on. - Stream in letterboxed HD video (at least 720p, 1080p is better). The viewer should be able to read the bumper numbers of the robots, and everything on the scoreboard. - Test your setup on Thursday to make sure things are working BEFORE the qualification matches start. Periodically check the stream to be sure it doesn't get messed up during the course of the day. I highly suggest that you have someone who isn't onsite checking the stream quality remotely and texting in QC checks at least every hour. - Post links to your streams in a thread titled "Week XX streams" on CD, so people can find your stream to watch it. Last edited by ToddF : 04-03-2014 at 20:14. |
