Go to Post "Mother nature does not give partial credit" -Woodie Flowers, Kickoff 2003 - TerryDolan [more]
Thread Tools Rating: Thread Rating: 6 votes, 5.00 average. Display Modes
Unread 04-03-2014, 20:46
Electronica1's Avatar
Electronica1 Electronica1 is offline
Former Design and CAD Captain 1086
AKA: Alexander Kaplan
FRC #0401 (Copperhead Robotics)
Electronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond reputeElectronica1 has a reputation beyond repute
Game Manual - Team UPDATE - 2014-03-04
http://frc-manual.usfirst.org/Updates/0#term 172
root
Game Manual
Section 2: The ARENA
Section 2.2.3: The GOALS
Note: In order to help minimize the chance of a BALL bouncing back out of a HIGH GOAL, we have modified the structure, as noted below in the update to Section 2.2.3.
Each ALLIANCE has two (2) HIGH GOALS located above their opponent’s ALLIANCE WALL. The HIGH GOALS are 11 ft. 6 in. wide and 3ft. 1 in. tall with the bottom edge of the opening located 6 ft. 10 ¾ in. above the carpet. The outside edge of each HIGH GOAL is semi-circular with a radius of 1 ft. 6 ½ in. The HIGH GOALS are separated from each other by a 1 ft. wide divider.
Horizontal pipes are installed behind the bottom of each HIGH GOAL to prevent SCORED BALLS from dropping directly on DRIVERS. These pipes are covered in ¼ in. clear polycarbonate sheet.
The perimeter of each HIGH GOAL is surrounded by Phillips Color Kinetics iColor Flex LMX LED light strings. The LEDs have several states that indicate GOAL status:
Section 3: The GAME
Section 3.1.2: MATCH Logistics
If the Head Ref determines that a BALL is becomes damaged or completely deflated, it will be replaced by a new replacement BALL of the same color will be delivered to one of the ALLIANCE’S HUMAN PLAYERS at the next safe opportunity. Once the new BALL enters the FIELD, the damaged BALL is invalidated, considered debris, and can no longer be used in MATCH play.
Section 3.2.6: ROBOT-ROBOT Interaction
Note: We have made a modification to G28 to indicate that the ROBOT committing the foul must have initiated the deliberate or damaging contact. We also clarified that the contact must be on or inside a vertical extension of the FRAME PERIMETER. The rule was already being interpreted this way with regards to the vertical extension, we just wanted to be clear.
G28
Initiating deliberate or damaging contact with an opponent ROBOT on or inside the vertical extension of its FRAME PERIMETER is not allowed.
Violation: TECHNICAL FOUL
High speed accidental collisions may occur during the MATCH and are expected. ROBOTS extend elements outside of the FRAME PERIMETER at their own risk; no penalties will be assigned for contact between two such extended elements.
A ROBOT with an element outside its FRAME PERIMETER may be penalized under this rule if it appears they are using that element to purposefully contact another ROBOT inside its FRAME PERIMETER. Regardless of intent, a ROBOT with an element outside its FRAME PERIMETER that causes damage to another ROBOT inside of its FRAME PERIMETER will be penalized, unless the actions of the damaged ROBOT are the catalyst for the damage.
Section 3.2.7: Human Actions
G31
Strategies employing TEAM member HUMAN PLAYER actions to inhibit ROBOTS are not allowed.
Violation: TECHNICAL FOUL.
G32
Strategies employing TEAM member HUMAN PLAYER actions to deflect opponents’ BALLS are not allowed.
G38
TEAM members HUMAN PLAYERS may not pass the BALL to a TEAM member HUMAN PLAYER in another HUMAN PLAYER AREA (passing the BALL within an ALLIANCE STATION or HUMAN PLAYER AREA is permitted).
Violation: FOUL
Note: We have made a modification to G40 as a compromise between a desire to mitigate the volume of G40 penalties incurred at Week 1 competitions and the fundamental objective of never allowing ROBOTS and Humans to occupy the same space at the same time during a MATCH. While this adjustment offers some reprieve for HUMAN PLAYERS who reach beyond the SAFETY ZONE during a MATCH, it maintains the SAFETY ZONE between the ROBOT and the HUMAN PLAYER when both are in the same area and stress that HUMAN PLAYERS prioritize safety and avoid the space unless necessary.
G40
During the MATCH, TEAMS may not extend any body part
in to a space defined by the Human Player Barrier Brackets, the SAFETY ZONE, and the GUARDRAIL that is either occupied by a ROBOT or adjacent to such a space occupied by a ROBOT
or,
beyond the GUARDRAIL at any time. into the SAFETY ZONE during the MATCH.
Figure 3-7
I can't wait for week 2 events now, should be a bit better.
