Re: paper: grassHopper Hybrid Drive System
Apologies that it was not clear. The shifting bearing block is loose on the frame and has to be tensioned. Theraband is connected to the top of the shift plate where the pneumatic cylinder is attached and tensioned to the frame vertically. This seats the bearing block lower lip into the frame when the wheels are up. Also, when pivoting the blocks the chain is loose when up and tight when lowered. Ideally the pivot point should be moved out to reduce this issue. A small piece of theraband can be connected to the bottom of the block and tensioned to the frame. We are not using this. We just attached a small tensioner and it is working fine. The drivetrain complete w/o electronics is right around 30 pounds. I will double check the wieght when back at the build site.
Awesome job making this available to everyone. I really like this drivetrain setup.
I must admit a certain level of annoyance with this publication... we are working on a drivetrain almost identical to this one in function and theory that we thought was novel. We being Team 95, The Grasshoppers.
![]() In seriousness though - it looks great! |
Your drawings show one lift plate and bearing block on each of the articulated axles but the photos show two. Did you find that the forces on the axle cause the two lift plates to "twist" relative to each other?
Cool idea, as if Team 33's 2011 dual drive had a baby with a Nonadrive.
Game permitting, we're definitely looking into using it again! |
#7
Very neat chassis. Did you have any trouble with it being pitchy in H mode?
#8
Thank you for the compliments! |
