Go to Post FIRST is NOT just about robotics. It is about the growth of leaders - of Gracious Professionals... - MysterE [more]
  #106   Spotlight this post!
Unread 11-02-2003, 11:00
EvilInside's Avatar
EvilInside EvilInside is offline
Robots, Cars, Physics!
#0706 (APE)
EvilInside is an unknown quantity at this point
Send a message via AIM to EvilInside
Re: Re: Sigh
Originally posted by Cory
How did you come up with 25 points? two bins can be either zero, or one point. One stack of two=0 two bins on floor =2-1=1
you would need a stack of 6 and 6 bins to have a small lead against the other team. Mean while, the other alliances 2nd bot is running around getting points too.
I don't think very many teams will be able to effectively block the ramp at all.
Cory
There are 8 human bins starting on your side. 8+2=10 and 5*5=25. And with a stack of 5 and 6 bins your could have a small lead over your opponent. 8+3=11 5*6=30. And yes, teams will block the ramp effectively, but it leaves them at a strategical disadvantage.
"All your bins are belong to us" "You can't teach God anything"
  #107   Spotlight this post!
Unread 18-02-2003, 14:30
SpaceOsc's Avatar
SpaceOsc SpaceOsc is offline
16 Years of FIRST!
AKA: Oscar Vasquez
FRC #4501 (Humans)
SpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant futureSpaceOsc has a brilliant future
Send a message via AIM to SpaceOsc Send a message via Yahoo to SpaceOsc
Unhappy The dispointing truth
as anyone here been to any of the scrimages around the country..... i went to the So cal Chatsworth Sectional Last sunday.... stackers... the most disapoint display i have witness in my years in robotics... after team have worked so hard to get it going to have weird devices and stacker... wut happen?
nothing... the best kinda robot on the field is the kinda that moved... if you can go up and down the ramp and even dominate it quickly .. then you got it made.... the sectionals everywhere have soon everyone that stacker just cant function well out on the field there just no time and no place ... the key to victory is the ramp domators .....
I was expecting some action on the field with stacker.... but nothing even tho some teams did not have them operation some others did.. theree just no chance tho.. i like i siad earlier in this theard.... Fast under the bar bots will be favorite... and ram dominators will rule the game.....
seems to be the end of story...
i might sound one sides here and its true that a stacker would win... there just no time and no place on the field for a forkilift to have great advantage over anything
2014-2017: Team 4501 Coach/Lead Mentor
2002-2011: Team 702, Mentor
2001-2002: Team 702 Captain
  #108   Spotlight this post!
Unread 18-02-2003, 15:00
Joe3's Avatar
Joe3 Joe3 is offline
Joe3 has a spectacular aura aboutJoe3 has a spectacular aura aboutJoe3 has a spectacular aura about
Send a message via AIM to Joe3
who says you have to have a forklift...? It does seem that everyone is saying that it will be impossible to stack. I guess we'll just have to wait and see what happens at the regionals.
  #109   Spotlight this post!
Unread 18-02-2003, 15:21
rufu5's Avatar
rufu5 rufu5 is offline
20something
FRC #6721 (Trailblazer Robotics)
rufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud of
Send a message via AIM to rufu5
yep, we have the same problem, 152lbs with 3 days to go. My advice, metal to plastic, lots of holes, and destroy things you dont need. (ya and take out that battery, its 13lbs you dont need lol)
have no fear of perfection, you will never reach it.
-Salvador Dali
  #110   Spotlight this post!
Unread 18-02-2003, 15:37
Keith Chester's Avatar
Keith Chester Keith Chester is offline
HGFSP
FRC #0025 (Team 25)
Keith Chester is a splendid one to beholdKeith Chester is a splendid one to beholdKeith Chester is a splendid one to beholdKeith Chester is a splendid one to beholdKeith Chester is a splendid one to beholdKeith Chester is a splendid one to behold
Send a message via AIM to Keith Chester
Originally posted by sevisehda
FIRST some replies...
"Any takers? I say the multiplier will be the difference again this year."
-Paul C
It will matter in qualifiers but not in finals.
"I say the ramp position will be the key thing this year."
-Jon V
I'll talk about Team 25 thinking its the Brystol Bot with the amazing arm that could cherry pick like a GOD, if team 25 was not the Brystol Bot then whatever...
Team 25 could take control of the field, they dominated the center and at least partially blocked half the field.
If you control the ramp you elimate half of the way across the field for a lowrider and you trap a non-lowrider. Ramp-dom also scores 25 points and prevents 50 points from the opponents. That a 75 point difference.
Even if a team can make a bot that can move boxes from one side to another it will still be slow because of the fact they'd have to be moved at least 12 feet. True a stacker may be able to stack 10 high but how are they gonna do that when they only have 8 human player boxes? They'd have to import at least 12 more. Then stack 10 high to get 100 points. I doubt that the ramp-doms ally would allow that to happen.
Even if the ramp-dom loses the fight for the wall it can still push boxes over the ramp back onto his side or at least out of the opponents scoring position, and when the stacker is almost done with his stack of 10(hopefully protecting it with some cage). the ramp-dom rams the stacker knocks it(stack and/or bot) over he can go back to the ramp for a triumpant win.
As to how high a ramp-dom will be, Some pics show bots with about 4 inch paddles others I'm sure will be 2ft+.
Yea that was us. We latched on in the first 10 seconds, instead of waitng until the end. Also, it is the little things that lead to a championship. And we were and are indeed sponsored by Bristol Meyers Squibb.
25 belives in simplicity for their complexity.
A proud graduate of 25.
Students. Teammates. Brothers.
Proud member of R.I.N.O.S., Rookies In Need Of Support.
  #111   Spotlight this post!
Unread 09-03-2003, 18:35
suneel112 suneel112 is offline
AKA: the angry designer on 461
#0461 (Westside Boiler Invasion)
Team Role: Student
suneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud ofsuneel112 has much to be proud of
Send a message via AIM to suneel112
wing folding
Heey
That's MY Idea
Anyways, it was rejected in week one because it would be "too hard to build"
I would be made out of plastic and go either 8 or 12 feet long. That means a 6+ high stack
In addition, it would be able to go under the bar
Anyways, 461 did great anyways at Buckeye.
We had the FIRST STACK!!!!!!!!!!! YEAH 461!!!!!!!!
__________________________________
"Who Stacks?"
"WE STACK!!!!!!!!!!!!!"
I'm back like the greatest, from a four year hiatus,
Haters cry later, I'm just getting my paper.
  #112   Spotlight this post!
Unread 10-03-2003, 14:51
shawny963 shawny963 is offline
shawny963 is on a distinguished road
Send a message via AIM to shawny963
First team to knock over the stacks wins!!! After seeing several scrimmages and a regional, i havent seen ONE stacker that does anyting useful. And ramp doms arent gonna win every match. There is no hole in the game this year, no "3 goals" that guarantee a win. Even if one team can take the ramp every time, thats only 25 points for their alliance. But if someone can beat them to the stacks, that is a lot of bins. And if this team can go under the bar, what is the ramp dom preventing. Unless the ramp doms partner can fend off two bots by itself the ramp dom has to move from the top. This makes the game open for everyone. With the other alliance having a majority of bins and superior movement ability to the ramp dom, they guarantee a win if both get on the hdpe and can fend off the ramp dom in the later portion of the match.
  #113   Spotlight this post!
Unread 10-03-2003, 15:15
sevisehda's Avatar
sevisehda sevisehda is offline
sevisehda is an unknown quantity at this point
Send a message via AIM to sevisehda
I haven't seen any pure rampdoms in play as of yet. Maybe I missed them.
There are few teams that get to the wall in autonomous mode, let alone get there fast. I don't think anyone can argue that getting to the wall first isn't the most important thing in this years game.
However alot of teams try to shove boxes over the ramp and a ramp-dom would stop that. If a rampdom can get there and plant he'll win barring a miracle.
With the apparent failure of stackers the rampdom strategy definately got a boost. But who knows this weekend could be totally different.
King Of The Hill And Others.... Alex Cormier General Forum 18 12-03-2003 09:11
FYI: FIRST Robots at the NYC Hall of Science Rich Wong General Forum 9 11-07-2002 10:52
how effective do you think robots going under the bar archiver 2001 4 24-06-2002 00:36
Mountain Home & 'The Brawl' archiver 2000 0 23-06-2002 23:20
What about prettiest robots? archiver 2000 8 23-06-2002 23:09
