Thank you very much for the detailed reply! It helped a lot to understand how the command/subsystem framework works. I should have realized that the commands were suppose to be recursion based (that's what it looks like is happening) based on some sample code I was using.
Either way thanks for the reply again. This should definitely be enough info to finish the code up. Andrew |
