Go to Post In the real world nothing is ever to spec. Just another part of the challenge. - Koko Ed [more]
Unread 10-02-2014, 17:54
danielms853 danielms853 is offline
Lead Programmer 2013&2014 seasons
AKA: Dan S.
FRC #4122 (O-Bots)
danielms853 is an unknown quantity at this point
Making 2014 Vision Sample Work
Hi All,
I have tried to run this modified version of vision 2014 code and it doesn't work. I am trying to simply detect a vision target, and print on the screen if it's hot or not. The code is basically stock 2014 code, with print statements added. In order to ensure a fresh image, I have added a waiting loop before the variable vision is assigned. The issue is that the size of reports is always 0, and it quits. I have been using the sample images displayed on a laptop screen in front of the axis camera, and the view I am seeing on the screen of the laptop running the driver station looks pretty realistic (the vision targets are bright). Here is the code. Could somebody help me determine why the size of reports is 0, and the if statement doesn't execute?
#include "WPILib.h"
#include "Vision/RGBImage.h"
#include "Vision/BinaryImage.h"
#include "Math.h"
 * Sample program to use NIVision to find rectangles in the scene that are illuminated
 * by a LED ring light (similar to the model from FIRSTChoice). The camera sensitivity
 * is set very low so as to only show light sources and remove any distracting parts
 * of the image.
 * The CriteriaCollection is the set of criteria that is used to filter the set of
 * rectangles that are detected. In this example we're looking for rectangles with
 * a minimum width of 30 pixels and maximum of 400 pixels.
 * The algorithm first does a color threshold operation that only takes objects in the
 * scene that have a bright green color component. Then a small object filter
 * removes small particles that might be caused by green reflection scattered from other
 * parts of the scene. Finally all particles are scored on rectangularity, and aspect ratio,
 * to determine if they are a target.
 * Look in the VisionImages directory inside the project that is created for the sample
 * images.
//Camera constants used for distance calculation
#define Y_IMAGE_RES 480		//X Image resolution in pixels, should be 120, 240 or 480
//#define VIEW_ANGLE 49		//Axis M1013
//#define VIEW_ANGLE 41.7		//Axis 206 camera
#define VIEW_ANGLE 37.4  //Axis M1011 camera
#define PI 3.141592653
//Score limits used for target identification
#define RECTANGULARITY_LIMIT 40
#define ASPECT_RATIO_LIMIT 55
//Score limits used for hot target determination
#define TAPE_WIDTH_LIMIT 50
#define VERTICAL_SCORE_LIMIT 50
#define LR_SCORE_LIMIT 50
//Minimum area of particles to be considered
#define AREA_MINIMUM 150
//Maximum number of particles to process
#define MAX_PARTICLES 8
class VisionSample2014 : public SimpleRobot
	//Structure to represent the scores for the various tests used for target identification
	struct Scores {
		double rectangularity;
		double aspectRatioVertical;
		double aspectRatioHorizontal;
	struct TargetReport {
		int verticalIndex;
		int horizontalIndex;
		bool Hot;
		double totalScore;
		double leftScore;
		double rightScore;
		double tapeWidthScore;
		double verticalScore;
	RobotDrive myRobot; // robot drive system
	Joystick stick; // only joystick
	Relay relay;
public:
	VisionSample2014(void):
		myRobot(1, 2),	// these must be initialized in the same order
		stick(1),		// as they are declared above.
		relay(1)
		myRobot.SetExpiration(0.1);
		myRobot.SetSafetyEnabled(false);
	 * Image processing code to identify 2013 Vision targets
	void Autonomous(void)
		Scores *scores;
		TargetReport target;
		int verticalTargets[MAX_PARTICLES];
		int horizontalTargets[MAX_PARTICLES];
		int verticalTargetCount, horizontalTargetCount;
		Threshold threshold(105, 137, 230, 255, 133, 183);	//HSV threshold criteria, ranges are in that order ie. Hue is 60-100
		ParticleFilterCriteria2 criteria[] = {
				{IMAQ_MT_AREA, AREA_MINIMUM, 65535, false, false}
		};												//Particle filter criteria, used to filter out small particles
		AxisCamera &camera = AxisCamera::GetInstance();	//To use the Axis camera uncomment this line
		DriverStationLCD*Lcd1=DriverStationLCD::GetInstance();
			Lcd1->Clear();
			Lcd1->PrintfLine(DriverStationLCD::kUser_Line1, "Vision::Enter Loop");
			Lcd1->UpdateLCD();
			Wait(1);
             * Do the image capture with the camera and apply the algorithm described above. This
             * sample will either get images from the camera or from an image file stored in the top
             * level directory in the flash memory on the cRIO. The file name in this case is "testImage.jpg"
			ColorImage *image;
			//image = new RGBImage("/testImage.jpg");		// get the sample image from the cRIO flash
			Lcd1->Clear();
						Lcd1->PrintfLine(DriverStationLCD::kUser_Line1, "Vision::GetImage");
						Lcd1->UpdateLCD();
						Wait(1);
						//To get the images from the camera comment the line above and uncomment this one
						while(!camera.IsFreshImage()){;}
						image = camera.GetImage();
			BinaryImage *thresholdImage = image->ThresholdHSV(threshold);	// get just the green target pixels
			//thresholdImage->Write("/threshold.bmp");
			Lcd1->Clear();
						Lcd1->PrintfLine(DriverStationLCD::kUser_Line1, "Vision::Threshold Image");
						Lcd1->UpdateLCD();
						Wait(1);
			BinaryImage *filteredImage = thresholdImage->ParticleFilter(criteria, 1);	//Remove small particles
			//filteredImage->Write("Filtered.bmp");
			Lcd1->Clear();
						Lcd1->PrintfLine(DriverStationLCD::kUser_Line1, "Vision::Filtered Image");
						Lcd1->UpdateLCD();
						Wait(1);
			vector<ParticleAnalysisReport> *reports = filteredImage->GetOrderedParticleAnalysisReports();  //get a particle analysis report for each particle
			Lcd1->Clear();
									Lcd1->PrintfLine(DriverStationLCD::kUser_Line1, "Vision::AnRep");
									Lcd1->UpdateLCD();
									Wait(1);
			verticalTargetCount = horizontalTargetCount = 0;
			//Iterate through each particle, scoring it and determining whether it is a target or not
			Lcd1->PrintfLine(DriverStationLCD::kUser_Line1, "Vision::RepSize %i",reports->size());
									Lcd1->UpdateLCD();
									Wait(1);
			if(reports->size() > 0)
				Lcd1->Clear();
														Lcd1->PrintfLine(DriverStationLCD::kUser_Line1, "Vision::IfReportsize");
														Lcd1->UpdateLCD();
														Wait(1);
				scores = new Scores[reports->size()];
				Lcd1->Clear();
										Lcd1->PrintfLine(DriverStationLCD::kUser_Line1, "Vision::Scores");
										Lcd1->UpdateLCD();
										Wait(1);
				for (unsigned int i = 0; i < MAX_PARTICLES && i < reports->size(); i++) {
					ParticleAnalysisReport *report = &(reports->at(i));
					Lcd1->PrintfLine(DriverStationLCD::kUser_Line1, "Vision::ParticLoop %i",i);
											Lcd1->UpdateLCD();
											Wait(.3);
					//Score each particle on rectangularity and aspect ratio
					scores[i].rectangularity = scoreRectangularity(report);
					scores[i].aspectRatioVertical = scoreAspectRatio(filteredImage, report, true);
					scores[i].aspectRatioHorizontal = scoreAspectRatio(filteredImage, report, false);
					//Check if the particle is a horizontal target, if not, check if it's a vertical target
					if(scoreCompare(scores[i], false))
						//printf("particle: %d  is a Horizontal Target centerX: %d  centerY: %d \n", i, report->center_mass_x, report->center_mass_y);
						horizontalTargets[horizontalTargetCount++] = i; //Add particle to target array and increment count
					} else if (scoreCompare(scores[i], true)) {
				//		printf("particle: %d  is a Vertical Target centerX: %d  centerY: %d \n", i, report->center_mass_x, report->center_mass_y);
						verticalTargets[verticalTargetCount++] = i;  //Add particle to target array and increment count
					} else {
				//		printf("particle: %d  is not a Target centerX: %d  centerY: %d \n", i, report->center_mass_x, report->center_mass_y);
				//	printf("Scores rect: %f  ARvert: %f \n", scores[i].rectangularity, scores[i].aspectRatioVertical);
				//	printf("ARhoriz: %f  \n", scores[i].aspectRatioHorizontal);
				//Zero out scores and set verticalIndex to first target in case there are no horizontal targets
				target.totalScore = target.leftScore = target.rightScore = target.tapeWidthScore = target.verticalScore = 0;
				target.verticalIndex = verticalTargets[0];
				for (int i = 0; i < verticalTargetCount; i++)
					ParticleAnalysisReport *verticalReport = &(reports->at(verticalTargets[i]));
					for (int j = 0; j < horizontalTargetCount; j++)
						Lcd1->PrintfLine(DriverStationLCD::kUser_Line1, "Vision::VertTGT %i",j);
												Lcd1->UpdateLCD();
												Wait(.1);
						ParticleAnalysisReport *horizontalReport = &(reports->at(horizontalTargets[j]));
						double horizWidth, horizHeight, vertWidth, leftScore, rightScore, tapeWidthScore, verticalScore, total;
						//Measure equivalent rectangle sides for use in score calculation
						imaqMeasureParticle(filteredImage->GetImaqImage(), horizontalReport->particleIndex, 0, IMAQ_MT_EQUIVALENT_RECT_LONG_SIDE, &horizWidth);
						imaqMeasureParticle(filteredImage->GetImaqImage(), verticalReport->particleIndex, 0, IMAQ_MT_EQUIVALENT_RECT_SHORT_SIDE, &vertWidth);
						imaqMeasureParticle(filteredImage->GetImaqImage(), horizontalReport->particleIndex, 0, IMAQ_MT_EQUIVALENT_RECT_SHORT_SIDE, &horizHeight);
						//Determine if the horizontal target is in the expected location to the left of the vertical target
						leftScore = ratioToScore(1.2*(verticalReport->boundingRect.left - horizontalReport->center_mass_x)/horizWidth);
						//Determine if the horizontal target is in the expected location to the right of the  vertical target
						rightScore = ratioToScore(1.2*(horizontalReport->center_mass_x - verticalReport->boundingRect.left - verticalReport->boundingRect.width)/horizWidth);
						//Determine if the width of the tape on the two targets appears to be the same
						tapeWidthScore = ratioToScore(vertWidth/horizHeight);
						//Determine if the vertical location of the horizontal target appears to be correct
						verticalScore = ratioToScore(1-(verticalReport->boundingRect.top - horizontalReport->center_mass_y)/(4*horizHeight));
						total = leftScore > rightScore ? leftScore:rightScore;
						total += tapeWidthScore + verticalScore;
						//If the target is the best detected so far store the information about it
						if(total > target.totalScore)
							target.horizontalIndex = horizontalTargets[j];
							target.verticalIndex = verticalTargets[i];
							target.totalScore = total;
							target.leftScore = leftScore;
							target.rightScore = rightScore;
							target.tapeWidthScore = tapeWidthScore;
							target.verticalScore = verticalScore;
					//Determine if the best target is a Hot target
					target.Hot = hotOrNot(target);
				if(verticalTargetCount > 0)
					//Information about the target is contained in the "target" structure
					//To get measurement information such as sizes or locations use the
					//horizontal or vertical index to get the particle report as shown below
					ParticleAnalysisReport *distanceReport = &(reports->at(target.verticalIndex));
					double distance = computeDistance(filteredImage, distanceReport);
					if(target.Hot)
					//	printf("Hot target located \n");
					//	printf("Distance: %f \n", distance);
						Lcd1->Clear();
									Lcd1->PrintfLine(DriverStationLCD::kUser_Line1, "HOT d%f",distance);
									Lcd1->UpdateLCD();
									Wait(1);
						relay.Set(Relay::kOn);
					} else {
						relay.Set(Relay::kReverse);
						Lcd1->PrintfLine(DriverStationLCD::kUser_Line1, "Not d%f",distance);
						Lcd1->UpdateLCD();
						Wait(1);
						//printf("No hot target present \n");
						//printf("Distance: %f \n", distance);
			Lcd1->Clear();
			Lcd1->PrintfLine(DriverStationLCD::kUser_Line1, "Vision::EndLoop");
			Lcd1->UpdateLCD();
			Wait(1);
			// be sure to delete images after using them
			delete filteredImage;
			delete thresholdImage;
			delete image;
			Lcd1->Clear();
						Lcd1->PrintfLine(DriverStationLCD::kUser_Line1, "Vision::Del1");
						Lcd1->UpdateLCD();
						Wait(1);
			//delete allocated reports and Scores objects also
			delete scores;
			Lcd1->Clear();
									Lcd1->PrintfLine(DriverStationLCD::kUser_Line1, "Vision::DScores");
									Lcd1->UpdateLCD();
									Wait(1);
			delete reports;
			Lcd1->Clear();
						Lcd1->PrintfLine(DriverStationLCD::kUser_Line1, "Vision::EndCode");
						Lcd1->UpdateLCD();
						Wait(1);
	 * Runs the motors with arcade steering.
	void OperatorControl(void)
		myRobot.SetSafetyEnabled(true);
		while (IsOperatorControl())
			Wait(1);
			relay.Set(Relay::kOff);
			Wait(1);
				// wait for a motor update time
	 * Computes the estimated distance to a target using the height of the particle in the image. For more information and graphics
	 * showing the math behind this approach see the Vision Processing section of the ScreenStepsLive documentation.
	 * @param image The image to use for measuring the particle estimated rectangle
	 * @param report The Particle Analysis Report for the particle
	 * @return The estimated distance to the target in feet.
	double computeDistance (BinaryImage *image, ParticleAnalysisReport *report) {
		double rectLong, height;
		int targetHeight;
		imaqMeasureParticle(image->GetImaqImage(), report->particleIndex, 0, IMAQ_MT_EQUIVALENT_RECT_LONG_SIDE, &rectLong);
		//using the smaller of the estimated rectangle long side and the bounding rectangle height results in better performance
		//on skewed rectangles
		height = min(report->boundingRect.height, rectLong);
		targetHeight = 32;
		return Y_IMAGE_RES * targetHeight / (height * 12 * 2 * tan(VIEW_ANGLE*PI/(180*2)));
	 * Computes a score (0-100) comparing the aspect ratio to the ideal aspect ratio for the target. This method uses
	 * the equivalent rectangle sides to determine aspect ratio as it performs better as the target gets skewed by moving
	 * to the left or right. The equivalent rectangle is the rectangle with sides x and y where particle area= x*y
	 * and particle perimeter= 2x+2y
	 * @param image The image containing the particle to score, needed to perform additional measurements
	 * @param report The Particle Analysis Report for the particle, used for the width, height, and particle number
	 * @param outer	Indicates whether the particle aspect ratio should be compared to the ratio for the inner target or the outer
	 * @return The aspect ratio score (0-100)
	double scoreAspectRatio(BinaryImage *image, ParticleAnalysisReport *report, bool vertical){
		double rectLong, rectShort, idealAspectRatio, aspectRatio;
		idealAspectRatio = vertical ? (4.0/32) : (23.5/4);	//Vertical reflector 4" wide x 32" tall, horizontal 23.5" wide x 4" tall
		imaqMeasureParticle(image->GetImaqImage(), report->particleIndex, 0, IMAQ_MT_EQUIVALENT_RECT_SHORT_SIDE, &rectShort);
		//Divide width by height to measure aspect ratio
		if(report->boundingRect.width > report->boundingRect.height){
			//particle is wider than it is tall, divide long by short
			aspectRatio = ratioToScore(((rectLong/rectShort)/idealAspectRatio));
		} else {
			//particle is taller than it is wide, divide short by long
			aspectRatio = ratioToScore(((rectShort/rectLong)/idealAspectRatio));
		return aspectRatio;		//force to be in range 0-100
	 * Compares scores to defined limits and returns true if the particle appears to be a target
	 * @param scores The structure containing the scores to compare
	 * @param vertical True if the particle should be treated as a vertical target, false to treat it as a horizontal target
	 * @return True if the particle meets all limits, false otherwise
	bool scoreCompare(Scores scores, bool vertical){
		bool isTarget = true;
		isTarget &= scores.rectangularity > RECTANGULARITY_LIMIT;
		if(vertical){
			isTarget &= scores.aspectRatioVertical > ASPECT_RATIO_LIMIT;
		} else {
			isTarget &= scores.aspectRatioHorizontal > ASPECT_RATIO_LIMIT;
		return isTarget;
	 * Computes a score (0-100) estimating how rectangular the particle is by comparing the area of the particle
	 * to the area of the bounding box surrounding it. A perfect rectangle would cover the entire bounding box.
	 * @param report The Particle Analysis Report for the particle to score
	 * @return The rectangularity score (0-100)
	double scoreRectangularity(ParticleAnalysisReport *report){
		if(report->boundingRect.width*report->boundingRect.height !=0){
			return 100*report->particleArea/(report->boundingRect.width*report->boundingRect.height);
		} else {
			return 0;
	 * Converts a ratio with ideal value of 1 to a score. The resulting function is piecewise
	 * linear going from (0,0) to (1,100) to (2,0) and is 0 for all inputs outside the range 0-2
	double ratioToScore(double ratio)
		return (max(0, min(100*(1-fabs(1-ratio)), 100)));
	 * Takes in a report on a target and compares the scores to the defined score limits to evaluate
	 * if the target is a hot target or not.
	 * Returns True if the target is hot. False if it is not.
	bool hotOrNot(TargetReport target)
		bool isHot = true;
		isHot &= target.tapeWidthScore >= TAPE_WIDTH_LIMIT;
		isHot &= target.verticalScore >= VERTICAL_SCORE_LIMIT;
		isHot &= (target.leftScore > LR_SCORE_LIMIT) | (target.rightScore > LR_SCORE_LIMIT);
		return isHot;
START_ROBOT_CLASS(VisionSample2014);
Unread 10-02-2014, 21:35
Re: Making 2014 Vision Sample Work
How did you decide on your threshhold values? Can you enable the image Write statements briefly to see where in the process the targets are being lost?
Unread 11-02-2014, 14:20
AKA: Dan S.
FRC #4122 (O-Bots)
Thanks for your prompt response! threshold values are default ones. Would you mind explaining what they each mean (so I can make it tolerate more shades of green)? Also, where could I find a sample filtered image (last step before reports, so the first step I would like to debug)? Thanks
Dan S.
Unread 11-02-2014, 15:39
You might want to play around with the Vision Assistant. It will let you tweak color threshhold values, try different processing steps, and generally experiment with making it work the way you want it to. Then you can tell it to generate C++ code that will do what you've designed.
Unread 25-02-2014, 20:14
mhaeberli mhaeberli is offline
FRC #3045
mhaeberli is on a distinguished road
Thanks for the explanations.
That said, I am trying the same thing, more or less, and am getting 0-sized images out of the Axis camera.
I'd encourage the First / WPILib owners to actually try out the vision sample code with an Axis camera and advise. Also, I found that the output pathnames work better if they are fully specified; that is "/tmp/threshold.bmp", "/tmp/Filtered.bmp"
Best,
Martin
Unread 25-02-2014, 23:17
FRC #3045
So, one more update - it appears that the camera needs to be set very carefully according to the setup instructions.
I am now able at least to get some images out of the camera.
At the same time, I am only able to get 320 x 240 images out of the camera, even though I have set the camera to generate 640 x 480 images.
Thanks,
Martin
Unread 05-03-2014, 14:28
Sparkyshires Sparkyshires is offline
AKA: Michael Shires
FRC #0384 (Sparky)
Sparkyshires is an unknown quantity at this point
For starters, make sure the image your expecting and the image you are writing are the same size. Second, something you can try is using the "Write" function and write the threshold-ed image to the cRIO, then FTP to it and take a look at how accurate it is. If its not to your liking, play around with the angle the cameras set to and the brightness setting.
"Measure with a micrometer, mark with chalk, cut with an axe."
Unread 15-03-2014, 12:25
dowster dowster is offline
Breathes Code
AKA: Brady
FRC #1091 (Oriole Assault)
dowster is an unknown quantity at this point
I'm wondering if any of you would be able to help me. We're trying to get vision working from the camera. We can use the sample, and it works great for the test images provided. However, when we try to switch it to take feed from the camera it compiles fine but on transfer complains about "pcre_exec" and "pcre_compile" symbols not found. I looked through and it looks like the pcre.h file is included (wouldn't have built otherwise). I went through everything I could think of to try and get it to run. Building from WPILib source, re-imaging the cRio multiple times.
Also, could this be an issue with us not having Net Console enabled?
